Drives: 2013
Just bought a used GT86, i noticed that some part is missing, next to the air filter box? What is it and should i go to Toyota and buy the missing part ASAP?
Regards ![]() https://imgur.com/a/FTkQyn7 |
#2 |
Thanks
You are missing part of the intake, was yhe car wrecked? Mine broke from a minor front end hit. That or the previous owner likely had an aftermarket intake.
Air Inlet Duct - Subaru (46012CA000) Air Cleaner Body - Subaru (46059CA000) I'd take the bumper off and looks
| The Following User Says Thank You to ZionsWrath For This Useful Post: | norcalpb (11-07-2018) |
#3 |
Drives: 2013
I know that the car was in a minor parking accident and the front bumper was repainted. Going to the dealer to order a new one.. thanks for the reply!
Edit: is it dumb to drive like that? |
#4 |
Also plug the flange for the sound tube, you can get a rubber cap from a auto shop for a couple of bucks.
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
#5 |
Drives: 2013
#6 |
The pic is missing a sound generator tube, its useless and a gimmick.
The issue with it being removed is that it leaves a hole in the airbox, that hole will suck in hot air from under the bonnet, thus to a point adding to higher intake temps, this is bad. As you are missing the snorkel to it seems, this will also suck hot air to a point. Google: 1.Toyota 86 sound tube delete 2. Toyota 86 Snorkel mod Both these searches will give you a better idea of the parts. The rubber plug is a easy fix, a plug and a cable tie will fix that. The missing snorkel may be found at a breakers yard, cost is ????, or you can easily fabricate something, it really only needs to be a couple of inches long, that will put the intake just inside the front bumper, and get the intake cleaner, read: not under bonnet, air. And...... .Google
#7 |
Weight Weenie
Drives: 15 FR-S
Is the foam gasket between the air box and bumper there?
#8 | |
Drives: 2016 BRZ
He is NOT missing the sound generator tube. He is missing one of the resonators in the intake system. I've attached a picture and the item circled in red is the sound generator tube and the item in green is the resonator he's missing. |
| The Following User Says Thank You to Joon525 For This Useful Post: | ls1ac (11-06-2018) |
#9 |
Drives: 2013
Thanks for all of the replys! I went to the local junkyard and found the Air Cleaner Duckt for 45 bucks! Going to install it tomorrow and Also make my own ”tube” so the engine wont suck in hot air.
Got this https://www.ebay.com/itm/OEM-2013-20...-/202284404124 Yes it seems like the foam gasket is still there
#10 | |
Drives: 2013
#11 | |
Same cheap fix though.
#12 | |
#13 |
Drives: 2016 Steel AT FRS
| The Following User Says Thank You to Weigaldo For This Useful Post: | gravitylover (11-06-2018) |
#14 |
| The Following 2 Users Say Thank You to Grady For This Useful Post: | bcj (11-06-2018), gravitylover (11-06-2018) |
| Missing??? | Papi | BRZ First-Gen (2012+) — General Topics | 17 | 06-23-2015 02:08 PM |
| Florida: Trade Silver hood for Black hood | 555 | Exterior Parts (Aero, Lighting, Etc.) | 0 | 05-06-2015 10:52 AM |
| So... am I missing something? | BirdTRD | Issues | Warranty | Recalls / TSB | 10 | 11-04-2013 04:52 PM |
| missing my FRS :( | 20valvewynn83 | Southern California | 36 | 08-29-2012 03:12 AM |
