Old 11-02-2018, 01:42 PM   #197
NCtoBRZ
Drives: 2017 Subaru BRZ PP WRB
Originally Posted by DandoX View Post
I like to cling to the unlikely hope they can offer a new motor.
Not gonna happen... it would be exponentially more expensive for them to replace the engine than to replace the valve springs. They aren't going to be paying for a bunch of 5 year old cars to get entirely new engines because of bad valve springs. That would be saying that you hope they'll install a new transmission because your shift knob fell off.
NCtoBRZ is offline   Reply With Quote
Old 11-02-2018, 02:01 PM   #198
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
aw.... Well at this point Im probably going to just deal with it for a while and risk it. Maybe later if I see some leakage or a research a dealership that is known for competent work then I may take it in.
The comment from Ermax detailed what sort of work is involved with replacing the springs certainly made me nervous though.
DandoX is offline   Reply With Quote
Old 11-02-2018, 03:04 PM   #199
Lantanafrs2
Drives: 2013 frs red
There are tools available that act in lieu of compressors for removing/installing valve springs. They are useful especially when there is a bucket bore to be dealt with.
Lantanafrs2 is offline   Reply With Quote
Old 11-02-2018, 03:05 PM   #200
ermax
ermax's Avatar
Drain oil and coolant, evacuate the AC, pull the engine, remove the accessories, pull the manifold, remove the harnesses and coolant lines, remove the timing cover and clean up all the packing material, pull the timing chains, remove the valve covers and clean the packing, remove the cam subassemblies and clean the packing, remove the heads and clean the surfaces, replace the springs, put it back together and reapply the packing for the cam subassemblies, check the valve clearance, pull it back apart and clean the packing again, replace shims and then reapply the packing, reapply packing for the valve covers, reinstall the timing chains, reapply packing and install timing cover, install accessories, reinstall the engine, recharge the AC, refill oil and coolant.
I'm recalling off the top of my head and obviously leaving out a lot of detail. But it's a lot of work.
On an inline 4 you could do this job without pulling the engine, removing accessories or cleaning up packing seal that is used all over the place. When I replaced my short block I spent at least 10 hours (spread over 2 weeks) simply cleaning packing seal off the pans, cam assemblies, cam endplate, HP fuel pump and timing cover.
The Following 2 Users Say Thank You to ermax For This Useful Post:
DandoX (11-02-2018), Trap63 (11-02-2018)
Old 11-02-2018, 03:10 PM   #201
ermax
ermax's Avatar
I've been trying to think of how you could make a tool that compresses the spring while also keeping the valve fully closed without having the head off. I've never seen such a tool. Do you have any links to a tool like this? I'm really curious how this could be done.
Old 11-02-2018, 03:29 PM   #202
KL
Drives: 2013 SWP BRZ
So if you're confirmed to have this recall done at a Subaru dealership, is there anything else you would recommend doing at the same time, either in the way of preventative maintenance or mods, while they've got the heads/timing cover/whatever apart replacing the valve springs? If I'm gonna have this work done for free, I wouldn't mind chipping in another few hours of labour out of pocket if there's a benefit to be had.
For context, I'm at 100k km on the BRZ, spark plugs already done 6k ago (dammit).
Thoughts?
KL is offline   Reply With Quote
Old 11-02-2018, 03:39 PM   #203
Lantanafrs2
Use a leak down fitting and pump air into cylinder.
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
ermax (11-02-2018)
Old 11-02-2018, 03:43 PM   #204
nico_rsx
Drives: BRZ 2017 Pure Red, MT
I would take that with a grain of salt. He also said I could see the IAM value(Ignition advance multiplier) with Techstream, but turns out that's absolutely not the case. 40$ for nothing...
nico_rsx is offline   Reply With Quote
Old 11-02-2018, 03:47 PM   #205
HunterGreene
Hail Magnet
HunterGreene's Avatar
Thoughts?
This crossed my mind as well.
It has priests in it?
Old 11-02-2018, 04:03 PM   #206
ermax
ermax's Avatar
You absolutely can data log IAM in Techstream.
Old 11-02-2018, 04:05 PM   #207
ermax
ermax's Avatar
That would keep the valve from dropping but still not sure how you would get it compressed. Lets just say there is a way to replace the springs without pulling the head, your hardly saving time. The only steps you would be saving would be unbolting the heads and then cleaning up the head surface which is fairly insignificant in comparison to the rest of the job. You can't get to the springs until the cams come off.
Old 11-02-2018, 04:25 PM   #208
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Checked last night, my car is affected.
Description
The valve springs located inside the engine of the affected vehicles may fracture, which may cause an abnormal noise or engine malfunction. In the worst case, this may result in the engine stalling during driving and the inability to restart the vehicle. An engine stall during driving could increase the risk of a crash.
Remedy
Toyota is currently preparing the remedy for this condition. When the remedy becomes available, Toyota dealers will replace the engine valve springs with new ones of an improved design FREE OF CHARGE.
They actually did the all caps on the "free of charge" thing themselves.
Old 11-02-2018, 04:37 PM   #209
EXCellR8
FR-S Driver (MT)
EXCellR8's Avatar
Drives: 2013 Whiteout FR-S
Going to check my VIN tonight but my guess is I'm in for the recall... which sucks.
How did they discover this though btw? I guess I'd like to know how likely it would be that there is actually an issue w/ springs. Like, was this tested and/or confirmed under normal driving conditions or was someone ripping up the 'ring while it happened?
I only read the first 6 or 7 pages of this thread.
EXCellR8 is offline   Reply With Quote
The Following User Says Thank You to EXCellR8 For This Useful Post:
humfrz (11-03-2018)
Old 11-02-2018, 04:45 PM   #210
PWBRZ
PWBRZ's Avatar
Drives: 2013 BRZ 6MT
Well, I’m in the date range - will check VIN later. Hmmm time for a 718 Cayman engine swap
Of course just kidding...
PWBRZ is offline   Reply With Quote
Broken Valve Spring sybrite Engine, Exhaust, Transmission 45 11-02-2018 04:20 AM
Valve spring swap rcmf5525 Engine, Exhaust, Transmission 6 05-19-2018 03:12 PM
Jrsc replacement diverter valve issue Brzxton Forced Induction 6 12-08-2017 09:39 AM
GSC FA20 Valve Spring Kits MAPerformance Engine, Exhaust, Transmission 41 07-20-2015 10:22 AM
Skunk2 Dual Valve Spring and Titanium Retainers limitedblkwrx Engine, Exhaust, Transmission 0 01-04-2015 11:12 PM
