Old 05-17-2018, 11:01 PM   #1
rcmf5525
Drives: 2017 Toyota 86
Valve spring swap
Has anyone done a valve spring swap with the engine in the car? Is there a tool that I don't know about, like the Company 23 spring compressor, that would make the task easier?
By the looks of it, the driver side seems to have a little more room than the passenger side, but that all relative. There isn't much on either side.
rcmf5525 is offline   Reply With Quote
Old 05-17-2018, 11:21 PM   #2
sid94
Drives: 2013 frs
Pull the engine it’s easier....
When you pull off cam carrier you’ll probably end up dropping all the rockers and make a huge mess and it’ll be a pain cleaning old three bony off the side with the engine still in.
However do as you’d like and if you are going to do it in car post about it please I would wanna see how that goes for you
sid94 is offline   Reply With Quote
Old 05-18-2018, 12:40 AM   #3
rcmf5525
Damn, I was trying not to pull the engine for a spring swap...
If I'm going to do that, I should just throw some rods and pistons in it...
Old 05-18-2018, 08:50 AM   #4
HawaiianMike
Drives: 2015 Brz Limited
Not trying to thread-jack, sorry.
But, do you need to pull the heads to swap valve springs+retainers.
I was looking at this set:
https://www.maperformance.com/collec...rz-frs-gsc5056
I think 9k rpm would be a nice change haha.
Thanks!
HawaiianMike is offline   Reply With Quote
Old 05-18-2018, 12:46 PM   #5
rcmf5525
No, the head can stay on the block, but you have to pull the cams, of course and that is a difficult order in the car. Pulling them is probably easier than reinstalling them in the engine bay.
Old 05-18-2018, 05:29 PM   #6
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Yes, it would require a lot of work. Not only would you have to remove the cams and cam cage/carriers, but obviously the timing chains. Which means you need to pull off the front engine cover. Which means you need to pull off all the accessories and pulleys on the engine. Which means getting new gaskets as well as scraping off all the old sealant and laying down some new one. Then torquing everything properly. A lot easier with the engine out of the car. Pulling the engine is a hell of a lot easier than pulling the cams out.
JimmyMac is offline   Reply With Quote
Old 05-19-2018, 03:12 PM   #7
sid94
Drives: 2013 frs
The rockers might fall out of place when you’re trying to put it back together and you probably won’t notice it, also might not get the sealant on right so it’s possible it’ll leak
Another thing is you might have a hard time putting the keepers back on
Broken Valve Spring sybrite Engine, Exhaust, Transmission 45 11-02-2018 04:20 AM
WK V3 - Spring Swap Question Stang70Fastback Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 07-18-2016 08:29 PM
GSC FA20 Valve Spring Kits MAPerformance Engine, Exhaust, Transmission 41 07-20-2015 10:22 AM
Skunk2 Dual Valve Spring and Titanium Retainers limitedblkwrx Engine, Exhaust, Transmission 0 01-04-2015 11:12 PM
Any recommendations on a shop in San Diego to do spring swap? 355rockit Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-11-2014 02:43 PM
