Old 12-05-2017, 09:12 PM   #1
Brzxton
Drives: 2015 Subaru Brz
Jrsc replacement diverter valve issue
I just got and installed a rkx splitter diverter valve to replace the plastic one jackson racing uses on their kits. They are the exact same thing, except the rkx is made of aluminum and higher quality than the plastic one. I inspected them and they look exactly the same. When i put it on, however, all i would hear was turbo flutter. I tried softening the spring, and ran every combination you can with it, including the bov configuration. It wouldnt even blow off any boost pressure, it just did the same fluttering noise. Plz help!!
Video of not working/ making flutter sound-
Link to rkx splitter valve- https://www.amazon.com/gp/aw/d/B01N6...236_SY340_QL65
Brzxton is offline   Reply With Quote
Old 12-05-2017, 09:38 PM   #2
I'm not sure how it's higher quality than a OEM grade valve. You replaced your JR supplied bypass with a cheaper model.
You will destroy your Rotrex if you continue to use the RKX splitter. You need to set it to open with ANY level of vacuum.
Brzxton (12-05-2017)
Old 12-05-2017, 09:48 PM   #3
Brzxton
Ok sorry for so many questions but what is the difference between the rkx valve on full recirculation vs the oem grade one included with the kit? And as you can tell i dont know much about this stuff so how would i set it open with any level of vacuum? Thanks
Old 12-05-2017, 10:20 PM   #4
That's a good question. I don't know. You'd have to either read the manual that came with your valve, or ask the vendor that sold the valve to you.
I was unable to get the release I wanted when I briefly tried the RKX, no matter how I adjusted.
Don't fix what's not broken.
Old 12-05-2017, 10:38 PM   #5
Brzxton
Yup im gonna run the one the kit came with for now. Thanks for your help!
Old 12-06-2017, 01:07 PM   #6
kimcheefists
kimcheefists's Avatar
Drives: 2017 BRZ PP
I’m not familiar with this BOV but it looks like you can open up the BOV (3 screws on the bottom) and see the configuration of the springs. I installed the GReddy Type S BOV and had the same flutter and when I opened it up, there were 2 springs (one inside of the other) so I removed the inner spring. I also adjusted the BOV to the softest setting and no problems
If there’s only one spring in the BOV, I’d maybe take a chance of opening up the OEM JRSC BOV and try to install it’s spring into the metal BOV you bought. As long as the inner housing height dimensions are similar, the stiffness shouldn’t change.
Also, I highly doubt you’re doing any damage by VTA (venting to atmosphere) Since the outlet of the BOV recirculates before the MAF, the ECU should have no problem adjusting the AFR. If the recirculated air were to blow into the intake system AFTER the MAF then you’d have potential stalling issues and run rich for a second or two whenever you let off the throttle/BOV opens.
kimcheefists is offline   Reply With Quote
Old 12-08-2017, 09:39 AM   #7
ozone42
Drives: SSM BRZ Limited
Several JSRC owners switched to the XS-Power aluminum bypass valve after the one jackson racing supplied failed (stops closing, cause vacuum leak, etc). It's got 3 different springs, go with the lightest.
ozone42 is offline   Reply With Quote
The Following User Says Thank You to ozone42 For This Useful Post:
Sleepless (12-08-2017)
PCV Valve Replacement with STI Valve apelpapa Forced Induction 30 06-03-2022 08:23 PM
JRSC E85 Delicious Issue loiselle1987 Forced Induction 28 07-24-2018 01:14 PM
Jrsc intercooler and bypass valve upgrade questions Brzxton Forced Induction 4 11-28-2017 08:01 PM
Heart valve replacement surgery mike the snake Off-Topic Lounge [WARNING: NO POLITICS] 94 09-17-2014 01:45 PM
FS: Synchronic Diverter Valve Kit FReSh_86 Engine, Exhaust, Bolt-Ons 0 11-26-2013 02:21 PM
