Old 11-02-2018, 09:20 AM   #183
funwheeldrive
Originally Posted by mswbrz View Post
Where did you research that more info will be avail nov 5 if I may ask ? Who will be posting more details ?
It was in the article posted previously in the thread. Looks like we got the details a little earlier than that though.
Just for reference, I was one of the first to pick up a Monogram and the build date on the car is 01/14. Hopefully all the Monograms are outside the recall range.
Old 11-02-2018, 09:23 AM   #184
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
My Canadian Subaru VIN will not come up on the NHTSA site.
krayzie is offline   Reply With Quote
The Following User Says Thank You to krayzie For This Useful Post:
Tcoat (11-02-2018)
Old 11-02-2018, 09:33 AM   #185
Believe the reports from NHTSA or Toyota/Subaru over the news.
Search Vin in
NHTSA https://vinrcl.safercar.gov/vin/vinLookup
Toyota (Canada) https://www.toyota.ca/toyota/en/my-toyota/recalls
Toyota (USA) https://www.toyota.com/recall
Subaru (Canada) https://www.subaru.ca/WebPage.aspx?W...ebPageID=21091
Subaru (USA) https://www.subaru.com/vehicle-recalls.html
Rely on these not date ranges, news reports, etc. since there could be gaps in the production where other parts were used.
My FRS did (no recall) did you try the Canadian Subaru site?
Old 11-02-2018, 09:43 AM   #186
krayzie
Drive From Home
krayzie's Avatar
That site is only good for the Takata seatbelt recall.
None of the sites listed would recognize my VIN. Maybe that's a good thing.
EDIT: Well looks like I'm just out of range.
http://www.ft86club.com/forums/showthread.php?t=131169
DBA-ZC 6 "BRZ" ZC 6-002002 to ZC 6-010144
March 9, 2012 to July 2, 2013 7,803
The one model that goes to September 2013 is the SJ Forester.
Old 11-02-2018, 09:45 AM   #187
Something wrong with what you are entering then. If nothing you should get a description of the car and the "no recalls" note.
OH ya I forgot to add that Subaru makes it a bit more difficult. You have to use the My Subaru app listed on the page I linked.
aceangel (11-22-2018)
Old 11-02-2018, 09:47 AM   #188
SLVRSRFR
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
Same; none of the sites listed recognized my VIN.
I'll keep my fingers crossed on this one; I have a June 2012 build date, but my last 6 digits of my VIN are 602685, which appears to fall outside of the specified VIN range...
Time will tell.
@bpennerz
SLVRSRFR is offline   Reply With Quote
Old 11-02-2018, 09:51 AM   #189
Time will tell.
Canadian BRZs don't exist!
I knew it!!!!
Old 11-02-2018, 10:00 AM   #190
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
My son's 2013 FR-S is affected. Purchased in June 2013. Currently 26,500 miles on it. It has never had an issue of any kind and has only had oil changes and the original set of tires recently replaced. We put RCE Yellows, a TRD air filter and a TRD exhaust on it. No other mods.
He will probably have the work done and have them put in new spark plugs while they are at it just to forestall having to do that himself at some point in the future.
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Old 11-02-2018, 10:03 AM   #191
FLYFISHR
FLYFISHR's Avatar
Drives: 2014 BR"ZED" Sport-tech DGM MT
This is what I found on how to read our vin numbers
Manufacturers code JF1, Line Z, body C, engine A, Model/Trim C, Restraint 1, Check Digit 1, Year E, Month 9, Day 6, Serial Number xxxxx
Old enough to know better but young enough to do it again
FLYFISHR is offline   Reply With Quote
Old 11-02-2018, 12:02 PM   #192
96z2
Drives: N/A
I had a 2013 FR-S that I bought in June 2012 (car was manufactured in April 2012) when they first arrived in the US. Kept it until November 2016 when it had a valve spring break on the passenger side head, dropping a valve and seizing the engine while I was in 5 mph stop and go traffic (lucky).
Car was bone stock its entire life (imagine that) and had about 35k miles on it at the time of failure. I took it to HPDEs 4 times but otherwise it was my DD and treated well, never even close to being abused. Engine sounded fine the entire time I had it. There were no odd noises leading up to the valve spring failure. It simply broke and the engine stalled, unable to be restarted of course. My Toyota dealer initially did not want to cover the repair under warranty, saying that I had tracked the car based on the wear patterns on my Michelin PSS tires. After some back and forth and me showing them dashcam video that the car failed in stop and go traffic, they decided to cover it under warranty. They were unsurprisingly inexperienced with boxer engines and it took them several weeks to get the install of the new head correct. If it had not been under warranty, the repair would've been ~$10k.
I feel for you FR-S guys that are gonna have to have this repaired by a Toyota dealer.
96z2 is offline   Reply With Quote
The Following 7 Users Say Thank You to 96z2 For This Useful Post:
bhmax (01-05-2019), funwheeldrive (11-02-2018), nikitopo (11-02-2018), notout86 (11-16-2018), RallySport (11-03-2018), Rampage (11-02-2018), Trap63 (11-02-2018)
Old 11-02-2018, 12:48 PM   #193
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
I just checked my Series-10 on the Toyota Recall Search site, but nothing came up.
MJones_RB is offline   Reply With Quote
Old 11-02-2018, 01:07 PM   #194
Zyo81
Drives: '13 Firestorm FR-S, 99 Mustang GT
I won (lost) the lottery. Yay?
My car is one of the affected.
Zyo81 is offline   Reply With Quote
Old 11-02-2018, 01:15 PM   #195
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
I like to cling to the unlikely hope they can offer a new motor.
DandoX is offline   Reply With Quote
Old 11-02-2018, 01:30 PM   #196
Abandon it. They are not going to replace whole engines for some springs that could potentially break. This is not their first nor will it be their last recall and replacing engines has never been in the cards before.
Broken Valve Spring sybrite Engine, Exhaust, Transmission 45 11-02-2018 04:20 AM
Valve spring swap rcmf5525 Engine, Exhaust, Transmission 6 05-19-2018 03:12 PM
Jrsc replacement diverter valve issue Brzxton Forced Induction 6 12-08-2017 09:39 AM
GSC FA20 Valve Spring Kits MAPerformance Engine, Exhaust, Transmission 41 07-20-2015 10:22 AM
Skunk2 Dual Valve Spring and Titanium Retainers limitedblkwrx Engine, Exhaust, Transmission 0 01-04-2015 11:12 PM
