Old 10-30-2018, 11:25 AM   #1
GrabTheWheel
Drives: 16' BRZ
Wheel and tire combo for 500 hp
I already have 2 sets of 17x9 wheels and I really don’t want to make the switch to 18’s. Does anyone make a good 17x10 so I can just buy 2 for the rear? I run nitto nt01’s 255’s right now. If I can’t find any 17x10’s would it be beneficial to put a 275 on a 9 inch wheel in the rear? This is for autoX and track use.
GrabTheWheel is offline   Reply With Quote
Old 10-30-2018, 11:43 AM   #2
Icecreamtruk
Drives: Track preped NA FRS
I do not think 275 in the rear will be a good thing. 255 is already a bit bulged and feels sloppy when compared to 235 and 245 in a 9". If you do find any decent (read light and strong but not costing and arm and a leg) 17x10 wheels I would be interested in buying those as well, so please do share.
Icecreamtruk is offline   Reply With Quote
Old 10-30-2018, 12:01 PM   #3
ZionsWrath
Thanks
ZionsWrath's Avatar
I opened this thread and read "Grab the ice cream truck wheel"
Old 10-30-2018, 12:14 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I'd also really consider changing your suspension setup based on what you're using this power for. You're going to want to be soft, and compliant in the rear.
For what it's worth, I've seen 17x10 RPF1's run on a Factory818 setup. Not sure if they make them in a 5x100 though...putting a 275 on a 9" wheel will bulge a little, this shouldn't hurt its performance. Just be sure you're not hellaflushdope1337CR3W
Old 10-30-2018, 12:20 PM   #5
Racecomp Engineering
We can have BRAID make some 5x100 17x10 wheels. Any offset. Let me know if you're interested.
- Andrew
Old 10-30-2018, 12:36 PM   #6
GrabTheWheel
Drives: 16' BRZ
- Andrew
Hi Andrew, yes I'd be interested. Could I order just 2 or would I need to buy a set? I guess if I could pick the offset then it would be possible to make them fit in the front as well? I'm not looking to spend 3K plus on forged wheels just need something that's strong enough to handle some abuse!
Old 10-30-2018, 12:40 PM   #7
You could just buy 2 if you like. Could also 2 at 17x9 and 2 at 17x10. About $650 each for the 17x10 and 17x9 (sadly they're cheaper for 18's in the same sizes).
Very strong wheels and what I chose to run on my own car.
- Andrew
Old 11-01-2018, 12:16 PM   #8
G-Man
G-Man's Avatar
Drives: 1980 corvette, 2014 Subaru BRZ
I am guessing you want to run SM. Here is a very good build thread about someone doing the same thing
http://www.ft86club.com/forums/showthread.php?t=25212
towards the end he was running "I had 275/35R17 Hoosier A7s on 17x9et45 RPF1s." with some fender rolling and probably every other possible thing he could do?
G-Man is offline   Reply With Quote
Help me identify tire/wheel combo Last Lemming Alive Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-13-2017 08:08 AM
Best Wheel/Tire Combo based on these choices? leevanf Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-11-2017 08:00 PM
Anybody taken their wheel/tire combo off their FR-S and... cfordart Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 09-05-2013 01:47 PM
Winter Wheel/Tire Combo... Wes B. Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 09-10-2012 08:33 AM
