| Software Tuning Discuss all software tuning topics. |
#29 | |
Drives: brz
i honestly wish i could get my wot log as good as the first graph it look way nicer than my datalog, i have added 15% more fuel on transient and as i step on throttle i get 13.8 then 11.98 then 13.6 then 11.2 then 12.1 then 12.8 so its random the swing is larger than 4% and i cant get it close enough to ignore it |
#30 |
Drives: brz
https://datazap.me/u/fahad-alali/log...0&data=7-25-42
this is an old delicious tuning datalog https://datazap.me/u/fahad-alali/log...&data=23-24-29 this is pi only you can see fuel cut at first wot https://datazap.me/u/fahad-alali/log...?log=0&data=25 this is di only same maf scale stock injectors scale Last edited by QTR FMS; 10-15-2018 at 10:25 PM. |
#31 | |
Drives: Toyota GT86
The MAF values at high rpm in the delicious log are too low with 120 g/s. Whether, it's a sensor issue or a tune issue. Same car as in the other screenshots (running Gruppe-S header): ![]() Another car with Gruppe-S header (my own):
#32 | |
Drives: brz
do you think the maf sensor might be the issue? |
#33 | |
Drives: Toyota GT86
I see you added two more logs in the post above.
Well, the sensor appears to be working. It's not leveling off like it won't read higher. Also it reads fine in your own logs - 132 g/s at 6500 rpm seems like a reasonable value. So no, I think it's a MAF scaling issue. Going back to your previous post: Quote:
Do you have a log running on that scale running both PI and DI?
#34 |
Drives: Toyota GT86
One of your logs was without the AVCS being active:
https://datazap.me/u/fahad-alali/log...zoom=9464-9700 If you scaled injectors based on a log with inactive AVCS, it's going to have messed things up. Don't forget to let the AVCS activate before you do any logging: [ame]https://www.youtube.com/watch?v=oGUOXcYrn8A[/ame]
| The Following User Says Thank You to Tor For This Useful Post: | Apoc (10-17-2018) |
#35 |
Drives: brz 2017 hksv2
i see no fuel cut, what you mean is just the normal fuel cut as no throttle in, afr goes up to 20 and indicates that you have your foot out of the pedal acc and no fuel is injecte
you have 7% of PI at high rpm, you can t max out injector, i didnt maxed out stck injector while supercharged and 40% of PI |
| The Following User Says Thank You to tomm.brz For This Useful Post: | hegreer1 (07-09-2021) |
#36 | |
Drives: brz
i forgot to wait for avcs to activate, it takes to long to activate is there any way to speed up the process |
#37 | |
Drives: brz
https://datazap.me/u/fahad-alali/log...5739-5733-5745 i have highlighted the fuel cut in this link |
#38 | |
Drives: FT86
If you running petrol on stock injectors and intake, NA, just load in a completly stock petrol tune and then you will be able to start diagnosing what happening. dont change anything in tune use stock maf pi/di fueling, i think your just confusing yourself with all your changes. no way your going to max out fueling even on E85 NA, ive run it for years no issues. you very likely have a hardware problem. start from stock tune, diagnose then fix the problem then move on. |
#39 |
Drives: UK GT86
I can't confirm but I would expect the OEM PIs to max out before hitting the upper RPM. It's not fuel cut but lack of fueling capacity.
He's logging in seconds rather than ms. That doesn't help matters.
.: Stealth 86 :.
#40 | |
Drives: FT86
Yeah didnt even realise logging injector times in seconds not milliseconds was an option :-) I don't think runnong 100% port would be good for the direct injectors either as being in combustion chamber i would think that running fuel through them would keep them cool, id be concered about damage with zero di fueling Also strange that fuel system status logging 0 as well as stft and ltft and ecutek closed loop 0 Last edited by steve99; 10-16-2018 at 08:53 PM. |
#41 |
There is a ecutek bug in some roms for example in A02G when racerom v10 is installed, fu el system status will show 0 no matter what
ltft at 0 i guess he zeroed out the 2 long term min max, stft at 0 is strange maybe he zeroed the 2 af #1 correction min/max |
#42 | |
Drives: UK GT86
That's rectified on v10.1, or it is on the A01G.
.: Stealth 86 :.
| Mann Engineering 2nd Quarter Tuning Days April 25th & 26th by Bill (Delicious Tuning) | DesertFrs | Northern California | 14 | 04-24-2014 03:15 AM |
| Element Tuning FRS/BRZ Hydra EMS Stand-Alone Turbo 400 whp Injector Limited | Element Tuning | Engine, Exhaust, Transmission | 40 | 12-17-2013 01:12 AM |
| Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) | DeliciousTuning | Announcements, Contests, Giveaways | 6 | 09-19-2013 05:55 PM |
| Injector Seals went Bad while tuning my car | whitefrs | Forced Induction | 128 | 08-20-2013 12:19 PM |
