Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 10-15-2018, 12:11 AM   #1
Subsonic
Subsonic's Avatar
Drives: Toyota 86 GTS
Diff oil service
Hi Guys,
My Australian delivered 86GTS requires a diff oil change at 45,000km. The manual gives us two options:
"Toyota Genuine Differential Gear Oil LT" or
"Other LSD gear oil that meets API GL-5 and SAE 75W-85".
Do you think I should put the Toyota stuff in or if not, what is a good alternative?
No complaints with how the diff is working with the factory fill, just looking for alternatives from those who may have some experience.
Subsonic.
Subsonic is offline   Reply With Quote
Old 10-15-2018, 01:30 AM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Chose whatever gear oil you want. Or what ever your wallet says.
I for one used mobile 1 gear oil, just because it's available at any auto parts store and it's cheap compared to oem gear oil and saves me a 30 minute drive to the dealership.
And if you don't like it, it's simple to drain and fill with whatever oil you chose.
Old 10-15-2018, 01:57 AM   #3
Use any equivalent. I used Castrol in mine. It's right as rain. Zero noise and the Torsen bites like new.
Avoid using the combo GL-4/GL-5 stuff.
Subsonic (10-17-2018)
Old 10-16-2018, 10:38 PM   #4
ZZT86
ZZT86's Avatar
Drives: BR86
mmm, why do you say that ? I've been using Gear 300 for years, seems fine I think.
ZZT86 is offline   Reply With Quote
Old 10-16-2018, 10:50 PM   #5
alan.chalkley
Drives: 4wd zooks
Dealership oil and service are very expensive.
The only reason i keep going back , is to keep my 6 year warranty.
alan.chalkley is offline   Reply With Quote
Old 10-17-2018, 01:32 AM   #6
Additives in dual rated lubes are "good enough" to provide GL-5-ish protection without corroding soft metal, but not as good as an actual GL-5 lube.
I suggest that, unless one is concerned about minimizing inventory, there's no reason to choose in-between stuff over the good stuff. Use GL-4 in the transmission, GL-5 in the diff, and call it a day.
Subsonic (10-17-2018), ZZT86 (10-17-2018)
Old 10-17-2018, 03:05 AM   #7
86MLR
86MLR's Avatar
Penrite Pro Gear GL-5 75W-85 in mine
So far no kittens, or gears have been killed.
$25 Ltr at Stupercheap
The Following User Says Thank You to 86MLR For This Useful Post:
Old 10-17-2018, 09:06 AM   #8
ZZT86
ZZT86's Avatar
Drives: BR86
^ Sweet, Penrite ProGear looks a good oil that matches the Toyota LX spec - full synth too
The Following User Says Thank You to ZZT86 For This Useful Post:
Ultramaroon (10-17-2018)
Diff and gear oil. Fill to overflow, or service manual capacity?? Crunk81us Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 08-18-2021 06:59 PM
Which is better? Reaplcing rear diff bushings? or installing rear diff brace? Frs30 Engine, Exhaust, Transmission 22 04-13-2020 11:23 AM
Difference between Whiteline Diff Outrigger Bushings and Diff Cradle kits? mistople Engine, Exhaust, Transmission 10 09-21-2018 07:01 PM
Diff Mount Inserts install - Diff won't lower??? ChRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-17-2017 01:07 AM
Rear diff service JoeBoxer Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 11-06-2012 11:23 PM
