#29 |
Well if you want the least drop, get the 1 and mount it sideways.
The 915 has a tiny amount more capacity than the 619, but overall capacity, for all intents and purposes, are identical. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Trust86 (10-10-2018) |
#30 | |
Drives: Crapcan
Asking for........a friend. |
#31 |
Drives: Subaru BRZ
^ Would most likely need to be installed at an angle and/or involve some crash bar trimming.
#32 |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Code Monkey (10-10-2018) |
#33 |
#34 | |
#35 |
Drives: Crapcan
Curiosity.
What would you recommend? Sent from my Moto E (4) Plus using Tapatalk
#36 |
Drives: 2015 BRZ CWP
Oil Cooler FI
I have the jdl crash bar and was able to fit a setrab series 9 25 row which has been doing well on my harrop supercharger setup. Fabbed up custom brackets and made it fit nicely. ![]() ![]() Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to byun For This Useful Post: | NoHaveMSG (10-11-2018) |
#37 |
With the AVO turbo would the JR dual radiator be a good option for a MY17?
#39 |
Thanks Mike! Just curious is it the thickness of the radiator or the placement of the oil lines on the radiator? Or something else?
#40 | |
If you can come up with a different charge pipe, or different oil line routing, you can make it work, but it will not be a plug and play system. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Grady (10-12-2018) |
#41 | |
Drives: 2013 Black FR-S
in each of the side vent areas. At the track: Oil temps max at 240-250F in the summer 100F+ days In milder temps it is sub 230F Coolant stays around 200F. 300+ whp E85. I would overheat if I didn't run this setup. Its important to remove the oil cooler core from in front of the radiator/intercooler if you want to keep coolant and iat temps in check.
| The Following 3 Users Say Thank You to sw20kosh For This Useful Post: |
#42 |
How does it work with 2 cores.. do you have a pump to help? Or if not how do the lines flow.. and is there any pressure drops with 2 cores?
@sw20kosh Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
| The Following User Says Thank You to jflogerzi For This Useful Post: | Icecreamtruk (12-13-2018) |
| WTB: Perrin Oil Cooler vs Jackson Racing Radiator/Oil Cooler | TheMedakaBox | Northern California | 4 | 08-09-2017 10:16 PM |
| Oil cooler | mynameis940 | Engine, Exhaust, Bolt-Ons | 9 | 05-12-2017 11:38 PM |
| WTB: FBM Oil Cooler Kit | asnatlas | Want-To-Buy Requests | 0 | 10-07-2015 12:36 AM |
| Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. | mike the snake | Engine, Exhaust, Bolt-Ons | 1 | 01-31-2014 05:46 PM |
