Old 10-10-2018, 03:30 PM   #29
CSG Mike
CSG Mike's Avatar
Well if you want the least drop, get the 1 and mount it sideways.
The 915 has a tiny amount more capacity than the 619, but overall capacity, for all intents and purposes, are identical.
Trust86 (10-10-2018)
Old 10-10-2018, 11:29 PM   #30
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Would you recommend going to the 625 if you have the room?
Asking for........a friend.
Old 10-10-2018, 11:38 PM   #31
Code Monkey
Drives: Subaru BRZ
^ Would most likely need to be installed at an angle and/or involve some crash bar trimming.
Code Monkey is offline   Reply With Quote
Old 10-10-2018, 11:46 PM   #32
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Custom crash bar is on the table as far as options
Code Monkey (10-10-2018)
Old 10-11-2018, 12:56 AM   #33
CSG Mike
CSG Mike's Avatar
I'd ask why you want to
Old 10-11-2018, 01:18 AM   #34
truth
CSG Mike (10-11-2018), Trust86 (10-11-2018)
Old 10-11-2018, 06:58 PM   #35
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Curiosity.
What would you recommend?
Sent from my Moto E (4) Plus using Tapatalk
Old 10-11-2018, 09:19 PM   #36
byun
byun's Avatar
Drives: 2015 BRZ CWP
Oil Cooler FI
I have the jdl crash bar and was able to fit a setrab series 9 25 row which has been doing well on my harrop supercharger setup. Fabbed up custom brackets and made it fit nicely.
byun is offline   Reply With Quote
The Following User Says Thank You to byun For This Useful Post:
NoHaveMSG (10-11-2018)
Old 10-11-2018, 10:47 PM   #37
Grady
Grady's Avatar
Your AVO kit precludes you from using any off-the-shelf oil cooler, except the AVO oil cooler. Sorry, but you gotta build your own, or modify one to work for you, if you want to go a different route.
PM me to order the AVO oil cooler.
With the AVO turbo would the JR dual radiator be a good option for a MY17?
Old 10-12-2018, 12:47 AM   #38
CSG Mike
CSG Mike's Avatar
The JR DROC is not compatible with the AVO turbo. I recommend you get the AVO oil cooler with the AVO turbo, or consider a different FI kit that has other options.
Grady (10-12-2018)
Old 10-12-2018, 12:23 PM   #39
Grady
Grady's Avatar
Thanks Mike! Just curious is it the thickness of the radiator or the placement of the oil lines on the radiator? Or something else?
Old 10-12-2018, 05:00 PM   #40
CSG Mike
CSG Mike's Avatar
Oil line placement. Charge pipes occupy the same space.
If you can come up with a different charge pipe, or different oil line routing, you can make it work, but it will not be a plug and play system.
Grady (10-12-2018)
Old 12-11-2018, 06:06 PM   #41
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by Trust86 View Post
Bump for questions.
Setrab 619 or Setrab 915?
Asking bc the 2 kits I’m considering are the Jackson racing and racer x. Car is not a daily and will see track and drifting. @sw20kosh @CSG Mike
*edit*
Car is turbocharged.
FYI I run 2x 25 row series 6 https://www.pegasusautoracing.com/pr...asp?RecID=8949
in each of the side vent areas.
At the track:
Oil temps max at 240-250F in the summer 100F+ days
In milder temps it is sub 230F
Coolant stays around 200F.
300+ whp E85.
I would overheat if I didn't run this setup.
Its important to remove the oil cooler core from in front of the radiator/intercooler if you want to keep coolant and iat temps in check.
The Following 3 Users Say Thank You to sw20kosh For This Useful Post:
byun (12-12-2018), Icecreamtruk (12-13-2018), Trust86 (12-11-2018)
Old 12-13-2018, 10:24 AM   #42
jflogerzi
jflogerzi's Avatar
How does it work with 2 cores.. do you have a pump to help? Or if not how do the lines flow.. and is there any pressure drops with 2 cores?
@sw20kosh
Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
WTB: Perrin Oil Cooler vs Jackson Racing Radiator/Oil Cooler TheMedakaBox Northern California 4 08-09-2017 10:16 PM
Oil cooler mynameis940 Engine, Exhaust, Bolt-Ons 9 05-12-2017 11:38 PM
WTB: FBM Oil Cooler Kit asnatlas Want-To-Buy Requests 0 10-07-2015 12:36 AM
Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. mike the snake Engine, Exhaust, Bolt-Ons 1 01-31-2014 05:46 PM
