Old 09-27-2018, 10:23 AM   #15
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Originally Posted by Icecreamtruk View Post
Well, I though it was the EPS cutting out for me, until I realised that all the plastic from the fender was gone and it was in fact contacting the strut tower from below (metal). It had already taken all of the paint out and had a nice polish surface on it already
Does it happen to look like this? lol. Just found this after a day at NYST.
I am almost still certain that its your EPS cutting out bc that has been a known issue. But the fact that our tires are hitting the chassis can't be good either.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 09-27-2018, 10:25 AM   #16
lutfy
lutfy's Avatar
Drives: 2022 LR Defender, 2015 FRS_ST5/TT5
Originally Posted by Takumi788 View Post
Yep happens to me while entering turn 7 at the glen. There is a lot of compression making the electric motor work harder than it wants to.
OMG DejaVu. Same here, Glen T7. First time it scared the s*** out of me but then I got used to it after realize its a common problem.
This was with R888R 255/40/17 however since then I have moved to R7 225/40 and been tracking at different locations and no issues. Unsure if its a Glen thing or a big wider taller tire thing or both.
Lutfy
2015 FRS NASA ST/TT5
2022 LR Defender
2023 BMW M2
lutfy is offline   Reply With Quote
Old 09-27-2018, 10:41 AM   #17
Icecreamtruk
Drives: Track preped NA FRS
Looks exactly like that. Its not the EPS cutting out. Raise the car about an inch for a test, go at it and watch it not cut or feel different from anywhere on track.
@lutfy 255/40 has a lot more sidewall than 225/40. Specially since the R888R has so much tread (9/32). Pretty sure your issue was this same thing.
Edit: grammar correction.
Icecreamtruk is offline   Reply With Quote
Old 09-27-2018, 10:54 AM   #18
Takumi788
JHerbert Racing
Takumi788's Avatar
@lutfy 255/40 has a lot more sidewall than 225/40. Specially since the R888R has so much thread (9/32). Pretty sure your issue was this same thing.
The fender rubbing just started this year bc I lowered the ride height. I had the same size tires on last year with plenty of clearance and the steering issue happened then as well.
Ur issue could be the fender, it may not but just know the EPS cutting is also a known issue.
Sent from my SM-G965U using Tapatalk
Old 09-27-2018, 12:31 PM   #19
lutfy
lutfy's Avatar
Did not think it was related but YES YES YES my fenders were rubbed pretty badly and we had to raise it 1/2 inch. This all makes sense now.
Cheers guys.
Lutfy
2022 LR Defender
2023 BMW M2
The Following User Says Thank You to lutfy For This Useful Post:
Icecreamtruk (09-27-2018)
Old 09-27-2018, 01:16 PM   #20
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
It's tread, not thread.
idk why this has been popping up more and more recently but it bothers me.
https://www.tirerack.com/tires/tiret...e.jsp?techid=9
ineedyourdiddly
Old 09-27-2018, 03:38 PM   #21
7c8
This has happened to me before. In my case, I can see a mark on the inner wall of the wheel well where the back of my end link was hitting it under high compression sweeping turns.
7c8 is offline   Reply With Quote
Steering issue under braking ! AJ PwR Tracking / Autocross / HPDE / Drifting 146 04-25-2023 05:47 PM
Possible Steering Issue ? TJB_902 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 06-24-2015 01:38 AM
Watkins Glen HPDE - 4/25/15 - 4/28/15 Takumi788 Tracking / Autocross / HPDE / Drifting 23 04-21-2015 08:30 AM
Watkins Glen Sunday ! GT86Dan NY / NJ / CT / PA 0 06-25-2014 11:31 AM
Steering wheel issue Khalis Issues | Warranty | Recalls / TSB 1 05-04-2013 01:19 AM
