Old 09-26-2018, 12:32 PM   #1
milhouse
Because Racecar
milhouse's Avatar
Drives: 2013 Lightning Red Subaru BRZ
Steering Issue at Watkins Glen
I just got back from Watkins Glen where I had a relatively successful track weekend. I had an issue that I was wondering if anyone else has had, and if so, knows whether a fix is required.
When turning hard on the Outer Loop on the first day, my steering wheel felt "notchy" at one point through the turn. I could certainly steer through it, but I could definitely feel a stop during the turn, such that I had to add additional steering input to get through. At first it was light, and not a huge issue, but as the weekend progressed, the notch became harder to steer through and by the middle of day two I had to add a ton of input, such that when it released the car got completely unbalanced. The weird thing is that it only happened on that turn, and in pretty much the same spot every time.
We removed the wheels and didn't see anything wrong with the stock bushings, tie rods or control arms, and when driving normally (and even on other turns), the issue doesn't happen. In addition, I don't feel anything when the car isn't moving and I turn the wheel.
Anyone have any thoughts? My local shop said its actually normal as the car is driven harder, so I wanted to check here and see if anyone else had the issue and if they were able to resolve it.
Thanks.
milhouse is offline   Reply With Quote
Old 09-26-2018, 12:35 PM   #2
tony_r
tony_r's Avatar
Drives: '15 STX
Probably electronic power steering cut. It happens with higher loads on turn in to mid corner. I've only felt it once, and only at the track but I know of others who feel it a lot more.
tony_r is offline   Reply With Quote
Old 09-26-2018, 01:05 PM   #3
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Yeah, I agree that it sounds like power steering cut-out. Especially if it's happening in the same spot. I've had it happen to me on certain autocross courses - always at the exact same spot. Usually a very tight, higher-speed turn, and often where the curve of the road surface causes additional load. There's some sort of load limiter that prevents the electric motor from overheating, and it seems that those combinations can overpower the motor enough for it to very briefly give up to "protect itself." I heard that the refreshed vehicles (2017+) received some adjustments to the power steering programming to resolve that issue.
Either way, it's really annoying and distracting when it happens. You should also be seeing a flashing light on the dash when it occurs, IIRC, albeit only briefly.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 09-26-2018, 02:14 PM   #4
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Yep happens to me while entering turn 7 at the glen. There is a lot of compression making the electric motor work harder than it wants to.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 09-26-2018, 03:06 PM   #5
Icecreamtruk
Drives: Track preped NA FRS
Are you guys sure it isnt just the tire hitting the upper part of the fender inside? Have you checked the plastic there to see if there are marks?
Old 09-26-2018, 03:19 PM   #6
tony_r
tony_r's Avatar
Drives: '15 STX
Plastic splash guard is not strong enough to make the steering feel like it does when EPS cuts. Even still there are no witness marks on my car.
There are differences with some cars in terms of caster and end links as well. Running a lot of caster and having endlinks that are less than optimal make this worse.
Old 09-26-2018, 03:39 PM   #7
kch
Senior Misanthrope
kch's Avatar
Must be a T7 thing, as it also happened at T7 at Texas World Speedway (rip)
Old 09-26-2018, 04:37 PM   #8
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Drives: Toyota 86 Vortech SC
I have that often. Doesn't worry me any more.
I run 255/40R17 Bridgestone RE11S semi slicks, and it mostly happens with hard trail braking into slower, tighter corners.
Pretend you're a truck driver, and just muscle it.
Fish Eagle is offline   Reply With Quote
Old 09-26-2018, 04:51 PM   #9
milhouse
Because Racecar
milhouse's Avatar
Thanks, everyone. While its not ideal, at least it won't cost me anything to fix...
Old 09-26-2018, 08:15 PM   #10
Molez93
Scott M
Molez93's Avatar
Drives: '13 BRZ (DocWalt's old car)
Clearly I wasn't pushing hard enough as the outer loop for me at the same event didn't produce any weird steering. ;-) ...or in any turn for that matter.
13 BRZ (DSTprep)
14 Lotus Evora S; 08 Exige S240
06 BMW Z4M Roadster, 20 M850
Molez93 is offline   Reply With Quote
Old 09-26-2018, 08:22 PM   #11
Joesurf79
Joesurf79's Avatar
Drives: 2016 White Pearl BRZ Premium
TWS turn 7 might be the single greatest turn I've ever driven.
It's been bulldozed
Joesurf79 is offline   Reply With Quote
Old 09-27-2018, 12:07 AM   #12
Pat
Pat's Avatar
Drives: 2023 BRZ
Yeah, this is a common issue. I think the sticker the tire the more of an issue it becomes. There are probably other factors at play, too.
Old 09-27-2018, 07:56 AM   #13
Icecreamtruk
Well, I though it was the EPS cutting out for me, until I realised that all the plastic from the fender was gone and it was in fact contacting the strut tower from below (metal). It had already taken all of the paint out and had a nice polish surface on it already
Old 09-27-2018, 09:26 AM   #14
Pat
Pat's Avatar
Drives: 2023 BRZ
How wide are your tires? What is your wheel offset?
Steering issue under braking ! AJ PwR Tracking / Autocross / HPDE / Drifting 146 04-25-2023 05:47 PM
Possible Steering Issue ? TJB_902 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 06-24-2015 01:38 AM
Watkins Glen HPDE - 4/25/15 - 4/28/15 Takumi788 Tracking / Autocross / HPDE / Drifting 23 04-21-2015 08:30 AM
Watkins Glen Sunday ! GT86Dan NY / NJ / CT / PA 0 06-25-2014 11:31 AM
Steering wheel issue Khalis Issues | Warranty | Recalls / TSB 1 05-04-2013 01:19 AM
