Old 09-14-2018, 05:06 PM   #1
RenegadeReaper
Drives: 2013 Frs
Won't start after clutch change
I have a 2013 Frs. Several weeks ago I put a new ACT street clutch and LW flywheel in it. After putting it all back together It won't cranks but won't start. I've already checked a lot of things:
No ECU codes
has fuel pressure
no blown fuses
all connectors securely reconnected
no pinched wires
crank sensor replaced
It ran perfectly before, but now when I turn the key it just cranks, it will pop kind of like a backfire every few seconds. It seems like the timing got thrown off but I was hoping someone here could give me some more info before I pull the cover. While I have heard that turning the flywheel backwards (I did this while torquing the FW) could cause a timing belt to skip is that even possible with the chain on these engines?
RenegadeReaper is offline   Reply With Quote
Old 09-14-2018, 05:38 PM   #2
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
"no ecu codes"
"crank sensor replaced"
If you've got an obd scan tool, did you check the engine rpm PID while cranking?
Old 09-14-2018, 09:35 PM   #3
Hello RenegadeReaper and welcome to - The Forum -
We have some pretty smart folks on the forum that may be able to help you out - but, I ain't one of them -
Someone will be along soon.
Old 09-14-2018, 11:36 PM   #4
RenegadeReaper
Drives: 2013 Frs
@RZNT4R
"no ecu codes"
To be more specific, I have and Open Flash Tablet which will give any cel codes. after checking my wires and making sure the fuel pump was working I replaced the crank sensor because with what info I could gather it seemed like the most likely culprit. It wasn't.
"If you've got an obd scan tool, did you check the engine rpm PID while cranking? "
Are you referring to the realtime data through obd2? Does the ecu use the crank sensor to calculate this? I didn't think of that before, but it's always matched the gauge roughly so i guess that would mean it's reading properly. or am I wrong?
@humfrz
Thank you and I hope you're right. None of the mechanics in my area are familiar with these cars.
Old 09-14-2018, 11:45 PM   #5
Take it all back apart and flip the crankshaft position scale around. The teeth are supposed to face forward, away from the flywheel.
It's a common mistake.
Old 09-15-2018, 07:53 AM   #6
RZNT4R
Originally Posted by RenegadeReaper View Post
@RZNT4R
"no ecu codes"
@humfrz
Yes, the engine rpm PID in obd live data is a direct reading of the crankshaft position sensor.
It's easy to check as it requires no disassembly.
The Following User Says Thank You to RZNT4R For This Useful Post:
Ultramaroon (09-15-2018)
Old 09-15-2018, 07:27 PM   #7
RenegadeReaper
Drives: 2013 Frs
Well I have confirmed that the problem is not the sensor, but what are you referring to by the "scale?" The only thing I remember with "teeth" was the flywheel itself, and the plate behind it was definitely facing away.
Old 09-15-2018, 07:40 PM   #8
Yeah. The crown shape on that plate should be facing in, toward the crankshaft sensor. Phew!
People do install it backward.
Try RZNT4R's idea of reading the RPM.
Old 09-15-2018, 10:08 PM   #9
RenegadeReaper
Drives: 2013 Frs
TBH I'm not sure what reading the rpm is supposed to tell me other than that the crank sensor is working. I originally thought that I might have damaged the sensor while replacing the flywheel but since I already replaced it, that apparently wasn't the case. I was hoping to get some other ideas as to what might be wrong. the short version is: still have fuel, air, spark, and no cel codes but it won't start and the timing doesn't sound right.
Old 09-15-2018, 11:49 PM   #10
Ah, but replacement doesn't confirm operation. Might be the connector. Might be a bum part.
Old 09-16-2018, 02:31 AM   #11
Well, that just leaves compression and timing -
OK, folks, how does one check the timing on these new fangled machines??
I was good with a couple of lengths of wire and a 12V light bulb and later on a timing light - but, today, I have no idea.
The OP needs help!
Anyone?
Old 09-16-2018, 07:01 AM   #12
RZNT4R
By looking at the live data you're looking for a low or intermittent reading. The crank sensor is (surprisingly) a pretty old school AC voltage generator, if it or it's reluctor are misaligned, sufficiently high AC voltage can't be generated.
Ultramaroon (09-16-2018)
Old 09-16-2018, 08:28 PM   #13
RenegadeReaper
Drives: 2013 Frs
After going over what I did with a rather knowledgeable mechanic in my town I think I figured it out. If the crown plate that Ultramaroon mentioned is what the crank sensor is reading then I probably didn't put it back properly, there should be marks that I have to line up right? So atm even though the rpm is right the sensor is picking up the wrong crank position.
Old 09-16-2018, 08:53 PM   #14
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Check out my build. I have pics of my clutch install and the correct plate orientation.
Help! Is there anyway to change the 2017 cluster start up image? slashlee DIY (Do-It-Yourself) Guides 2 11-17-2018 05:36 PM
No-start after clutch install chargedup Engine, Exhaust, Transmission 11 03-27-2017 05:22 PM
car won't start after clutch installed aquaman Issues | Warranty | Recalls / TSB 4 07-19-2016 01:29 AM
How to change the start up screen on 2014 head unit? Choob Electronics | Audio | NAV | Infotainment 9 08-03-2014 06:24 PM
GTS Sat Nav Start Up Screen change? MacTec AUSTRALIA 6 12-31-2012 04:10 AM
