Old 11-03-2013, 01:55 AM   #1
Choob
Choob's Avatar
Drives: 2013 Firestorm MT, 2004 Celica Gt
How to change the start up screen on 2014 head unit?
Exactly as the title describes, I've been trying to figure this out for forever but no luck. I tried uploading a picture from a USB but that doesn't work. Maybe it has to be in a specific format.
Choob is offline   Reply With Quote
Old 11-03-2013, 06:52 AM   #2
Calavera
Calavera's Avatar
Drives: Scion FR-S Whiteout
I don't think you can. Would be nice though.
If my calculations are correct, when this baby hits 88 miles per hour... you're gonna see some serious shit.
Calavera is offline   Reply With Quote
Old 11-03-2013, 02:48 PM   #3
P@ul
Apostle
P@ul's Avatar
Drives: Fast Microwave
Try this: http://toyota-entune.com/forum/viewt...p?p=1818#p1818
P@ul is offline   Reply With Quote
Old 11-04-2013, 01:30 AM   #4
Choob
Choob's Avatar
No luck, ): someone please help!
Sent from my Nexus 4 using Tapatalk
Old 11-04-2013, 03:40 AM   #5
wrb
frank
wrb's Avatar
Drives: Subaru BRZ WRB
hmm have you seen someone do it before?
I know for sure you can do it with BRZ head unit.. but not sure with FR-S..
I've never run into FR-S start-up image change.
2013 SUBARU BRZ WRB LIMITED M/T
Los Angeles, CA
Build Photo Album - http://bit.ly/brz_wrb
SoCal LA 86 Club Member
wrb is offline   Reply With Quote
Old 11-04-2013, 04:08 AM   #6
Choob
Choob's Avatar
No I haven't, but I know there must be a way. I just don't know how.
Old 11-04-2013, 12:07 PM   #7
Mandy
I came from a motorbike
Mandy's Avatar
Drives: Firestorm 2013 FR-S 6MT
I don't believe that it's doable unless you get the Entune module instead of the BeSpoke one with Aha.
Even then, I'm not sure if it's doable.
Mandy is offline   Reply With Quote
Old 01-20-2014, 08:24 PM   #8
MemphisR
Memphis
MemphisR's Avatar
Drives: 1989 MR2 S/C, 2014 Scion FR-S
Is anyone working on this?
"It's ok... It's not structural."- Mikey
MemphisR is offline   Reply With Quote
Old 01-20-2014, 09:35 PM   #9
Choob
Choob's Avatar
I still want this to happen );
Old 08-03-2014, 06:24 PM   #10
Roadie
Drives: 2014 Pearl White BRZ - Sport Pack
http://www.buddssubaru.com/assets/br...tem-Manual.pdf
this link is for the 2014 BRZ Nav manual, page 278-280 have info on how to change the opening screen.
Update 1:
doesn't work with the USB drive, have to try the SD card method. not an overly detailed process in the manual.
Update 2:
doesn't work with PNY 16GB SDHC card, going to try loading a pic direct to the map SD card
Roadie is offline   Reply With Quote
2013 FR-S with 2014 Head Unit Exorcized Electronics | Audio | NAV | Infotainment 5 09-09-2013 02:12 PM
2014 MY head unit details? watts? Pablitomarrero Electronics | Audio | NAV | Infotainment 1 06-17-2013 08:38 PM
FR-S Premium head unit startup/run screen can you modify it? OICU812 Electronics | Audio | NAV | Infotainment 0 05-13-2013 02:07 AM
GTS Sat Nav Start Up Screen change? MacTec AUSTRALIA 6 12-31-2012 04:10 AM
HOW-TO: Disable "Caution" screen on the head unit? ZILLA Electronics | Audio | NAV | Infotainment 5 06-20-2012 04:49 PM
