| AUSTRALIA Australia and New Zealand |
Drives: White 86 GTS MT
GTS Sat Nav Start Up Screen change?
Hi all. I'm curious to know if we (Aussies) can change the start up screen on our GTS sat Nav units? I have followed the DIY from the general DIY section for this, but the browse and start up screen buttons are greyed (not selectable) out for me.....
Have Toyota Aus locked this down perhaps, or am I just doing it wrong and need to keep persevering? Cheers. |
Drives: GTS 86 6AT
I managed to change mine (im in sydney), so I don't think it is locked.
I vaguely remember seeing greyed buttons too..jsut make sure you have your graphic file in the correct format. Keep persevering? |
Drives: 86 GTS
Yep, I copied a jpg into the root of a clean SD card (not the card with the maps on it) stuck it in and it worked straight away
Drives: IS200/AE86 2dr/White 86 GTS 6MT
I followed the DIY and changed it just then (used a clean 4gb SD card).
It's also in the user manual for the radio on page 271, same instructions. |
Ok thanks for that, I'll keep trying. Might delete everything from the 16gb sd and try again with a clean card, or I may have a smaller card somewhere incase the size of the card is an issue.
Im pretty sure the book said it only supports 512mb up to 8gb only (page 14)
Drives: 86 GTS
| Customizing BRZ Navigation Start Up Screen | GrimmSpeed | DIY (Do-It-Yourself) Guides | 318 | 01-24-2021 11:26 PM |
| nav screen protector | wallace03 | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 02-14-2013 12:56 AM |
| Push Start Rough Engine Start Up | joergasm | Engine, Exhaust, Transmission | 3 | 12-12-2012 03:44 AM |
| NAV startup screen | brett_g | Electronics | Audio | NAV | Infotainment | 1 | 07-22-2012 07:16 AM |
