Old 09-05-2018, 10:04 PM   #15
wparsons
wparsons's Avatar
Originally Posted by N1rve View Post
I tried to increase front negative camber to about -2 and I kept having toe out, so I'm stuck to around -1.2 degree camber for the front with 0 toe.
Uhhhhhhh, there should be TONS of adjustment on the front tie-rods to get 0 toe with -2* camber. I've got -3.2 and 0 toe up front, zero issues.
flickr
The Following 3 Users Say Thank You to wparsons For This Useful Post:
CSG Mike (09-06-2018), Racecomp Engineering (09-06-2018), strat61caster (09-05-2018)
Old 09-06-2018, 10:54 AM   #16
KnightRyderx2
Drives: 2014 FR-S
Ill throw this out first, I'm not detracting from what anyone has said as they are all valid points and should be considered.
I have Tein Flex Z dropped to about 2+ inches all around. I have had them for about a year now and currently they are the only suspension mod I have on the car. I will throw this out there that the car is only driven on the weekends and the most it sees is some spirited driving, no track time. I do plan on getting more supporting mods in the future; rear toe and LCA, adjustable end links all around, and possibly a roll center kit.
With that I do believe you can do it in stages over a period of time. Just keep in mind that you do run the risk of certain things wearing out faster (bushing) and possibly bending (end links), that is the risk I'm taking right now. The best thing to do is get everything needed and go at it all at once with an alignment and be done with it. It all depends on what you are doing and your budget. If you can wait till you get that $2000+ do it, great, if not then that fine too, but you take on some risk.
KnightRyderx2 is offline   Reply With Quote
Old 09-06-2018, 11:33 AM   #17
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Time for me to try another shop....
N1rve
Old 09-06-2018, 12:18 PM   #18
The best supporting mod is a shop that actually knows how to set up these cars.
- andrew
The Following 5 Users Say Thank You to Racecomp Engineering For This Useful Post:
CSG Mike (09-06-2018), finch1750 (09-07-2018), Tcoat (09-06-2018), Tristor (09-07-2018), wparsons (09-06-2018)
Old 09-06-2018, 09:56 PM   #19
Dee86
Drives: 2018 Toyota 86 GT Thunder
I’m new to the forum and came upon your post while stuck in traffic but figured this might help
https://my350z.com/forum/brakes-and-...ion-101-a.html
The link is to a 350z forum I used to be on when I owned one but I catch myself going back to it because the information on it is useful and in theory I can apply it to my own vehicle. It’s a lot of information but bare with it , it’s worth a read and should point you in the right direction of what you’re looking for . Hope this helps ✊
Btw thanks for having me on the forum.
Dee86 is offline   Reply With Quote
FS: RS-R "moto spec" Sportsi Coilovers + RS-R Rear Adjustable LCA's + Camber Bolts skylinekin Brakes, Suspension, Chassis 10 06-23-2017 05:48 PM
Five Years Later - My 2013 Scion FR-S "Frisky" Mods irxproductions Member's Car Journals 0 05-27-2017 07:01 PM
The "This is how it shouldve come from the factory." Mods jaorocks1 Scion FR-S / Toyota 86 GT86 General Forum 107 08-16-2015 08:58 PM
"Should have been stock" mods Jimmy817 Engine, Exhaust, Transmission 78 12-22-2014 06:46 PM
"Required" mods KarMa14 Cosmetic Modification (Interior/Exterior/Lighting) 24 07-27-2013 01:44 PM
