Drives: 2017 Toyota 86
Do coilovers need "supporting mods?"
Hey everyone, it's no secret that I'm a car noob.
1. I was simply wondering what kind of supporting mods I would need to drop my car around 2.0"-2.5" if any. 2.Do the stock struts and other suspension related parts give out when you lower your car on coilovers that much? 3. Also, I was wondering what a good all around coilover would be. I was thinking Tein Flex A. There's a new thread discussing the BC Racing BR coils and they seem terrible as far as comfort goes. I don't mind a rough and bumpy ride all that much, but I do want some semblance of comfort if possible while lowered 2.0"+. |
Drives: MY20 Hakone Toyota 86
I can say at 2"+ of a drop you'll probably want adjustable front endlinks, i knocked like hell on slow turns until i got them. I got rear lower control arms at the same time as my Tein Flex Z's so i could adjust the camber in the rear, but depending on how much camber you want you may be able to live with just using crash bolts.
As far as comfort goes. I was happy with Tein's suggested dampener settings, nice sporty stiffness, but my girlfriend would constantly curse at me over the slightest bump. I went two clicks softer all around and it rides like stock if not still slightly stiffer but enough to keep her quiet. |
| The Following User Says Thank You to redhalo For This Useful Post: | HachiRokuX (09-04-2018) |
Country Boy 4 Life
Yes, coilovers need supporting mods to go as low as you want.
My plan is to get coilovers, adjustable sway bar endlinks, LCA, adjustable rear trailing arms, and front camber plates at the same time. You can get lower control arms that have a different mounting point for the shock so that you keep some of the shock travel.
I LIKE TIRES! |
| The Following User Says Thank You to Leonardo For This Useful Post: | HachiRokuX (09-04-2018) |
1) Rear lower control arms for camber.
Possibly rear toe arms for toe.. some people get away without but personally for me I needed them to bring the toe back to spec. Roll center adjuster if you care about suspension geometry. Possibly adjustable end links. Again, some people can get away without them. 2) If you're replacing with coilovers you wouldn't be using the stock struts anymore. Your endlinks are going to be under tension, hence why adjustable end links are something you should look into. 3) Can't go wrong with Tein Flez Z/A.. Fortune Auto 500s go pretty low with better comfort than BC in my opinion.
AVO Stage 2 Turbo Build Thread
https://wheelwell.com/tyler-nguyen-1...014-scion-fr-s |
| The Following 2 Users Say Thank You to tyler_win_photo For This Useful Post: | HachiRokuX (09-04-2018), Leonardo (09-04-2018) |
Thanks so much for your help guys. I'm quickly realizing that this is not a "one and done" job, it's going to be a lengthy install and will be roughly $1500-$2000, just to get it done.
What if I just drop the car about 1.5-2.0 (MAX) inches on Tein Flex A coils? Would I still need all the supporting parts? I'm curious because they already sell springs like the eibach sportlines that drop the car 1.4 inches, but not sure how the ride is on those. I already have the TRD springs but quite frankly, I don't think they lower the car enough for me. It's barely enough and my new wheels will probably raise the car a little bit. |
Buddyclub and Megan make some. They're becoming more sparse though.
The Angry Brown Guy
Drives: 2016 Tacoma & 2018 86 GT Black
anything below -1.5", you will need to correct your steering geometry (roll center/bump steer). if you are upgrading your rear toe to adjustable, you will need lock-out bushings because the mounting holes in the subframe for the toe arms are slots (stock toe arms use eccentric bushings for adjustment). bearings, bushings, etc. will get worn out faster due to the strain that they are subjected to.
i have a set of eibach pro-kit springs (-1" drop), spc adjustable lcas, spc front camber bolts, spc adjustable rear toe arms, and spl rear toe lock-out bushings all waiting for install. this setup will allow me to get the adjustment i need without getting fucked up from normal (shitty) road conditions. this is also my interim/backup setup before i finally get tein flex-a coils. |
#9 | |
The Angry Brown Guy
| The Following User Says Thank You to BasementN3k0 For This Useful Post: | smg1138 (09-05-2018) |
#10 |
Don't forget to do periodical maintenance in the pillow bals on the top of the struts, I know of quite a few people who complain about worn and clunky struts, when asked if they have greased them I tend to get strange looks.
| The Following 3 Users Say Thank You to 86MLR For This Useful Post: |
#11 |
I would correct geometry at that level of drop.
| The Following 4 Users Say Thank You to CSG Mike For This Useful Post: |
#12 | |
I have an email from them stating late summer/fall was the target for it. Hoping they get it out soon!
#13 |
The Angry Brown Guy
| The Following User Says Thank You to BasementN3k0 For This Useful Post: | wparsons (09-05-2018) |
#14 |
Drives: 2019 BMW ///M4
My car is dropped roughly 1.5 Inches with Tein Flex A. The only supporting mod you might want is rear LCA for camber adjustment. I have SPC Rear LCA with the Toe Kit and the Toe kit helped bring the toe to a slight toe in with 0.08 and the LCA helped me remove some rear negative camber (from -2 to -1).
I tried to increase front negative camber to about -2 and I kept having toe out, so I'm stuck to around -1.2 degree camber for the front with 0 toe.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
| FS: RS-R "moto spec" Sportsi Coilovers + RS-R Rear Adjustable LCA's + Camber Bolts | skylinekin | Brakes, Suspension, Chassis | 10 | 06-23-2017 04:48 PM |
| Five Years Later - My 2013 Scion FR-S "Frisky" Mods | irxproductions | Member's Car Journals | 0 | 05-27-2017 06:01 PM |
| The "This is how it shouldve come from the factory." Mods | jaorocks1 | Scion FR-S / Toyota 86 GT86 General Forum | 107 | 08-16-2015 07:58 PM |
| "Should have been stock" mods | Jimmy817 | Engine, Exhaust, Transmission | 78 | 12-22-2014 05:46 PM |
| "Required" mods | KarMa14 | Cosmetic Modification (Interior/Exterior/Lighting) | 24 | 07-27-2013 12:44 PM |
