Old 08-30-2018, 04:54 PM   #85
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Originally Posted by new2subaru View Post
I yanked everything out in minutes when I had the carpet out. not much glue. I'm doing the rest when I pull the dash in the winter. I actually like the extra engine noise. It's not much but it's there.
Ahh I was hoping I could just cut around stuff to get out without taking out the dash. taking out glove box on passenger side to get to that side is easy. Every last ounce must be gone!
SuperTom is offline   Reply With Quote
Old 08-30-2018, 05:00 PM   #86
new2subaru
Weight Weenie
Drives: 15 FR-S
It may be possible. I didn't even try because I new I was pulling the dash. I want to know how much that dash beam/support weighs
Yanking the dash video. I thank all these people that did tutorials!
[ame]https://www.youtube.com/watch?v=ucaiC7Jth7s[/ame]
Old 08-30-2018, 05:33 PM   #87
SuperTom
SuperTom's Avatar
Oh your taking out the beam running across? On my 3000gt years ago I swiss cheezed mine. Keeps it usefull but you can get most of the weight off it.
Also there is a useless plate under the steering column. Just take the plastic cover off its sitting there doing nothing supporting nothing. Good for free 1.5lbs !
Also plan to take the welds off the mounting plate for stock 2pc driveshaft since its useless with a one piece. Theres always more free weigh if you keep looking!
The Following 2 Users Say Thank You to SuperTom For This Useful Post:
new2subaru (08-30-2018), q335r49 (02-23-2019)
Old 08-30-2018, 07:48 PM   #88
new2subaru
Weight Weenie
Drives: 15 FR-S
Oh your taking out the beam running across? On my 3000gt years ago I swiss cheezed mine. Keeps it usefull but you can get most of the weight off it.!
I'm going to take it out and get a weight on it first. I haven't seen one out there yet. Could be 10lbs, could be 20 . We'll see
Also there is a useless plate under the steering column. Just take the plastic cover off its sitting there doing nothing supporting nothing. Good for free 1.5lbs !!
I found that thanks to one of your posts. I had no clue what you were talking about until I removed the plastic.
Did you get the washer bottle and the metal bracket? I'm still wanting to keep it so I can return it to stock but it's looking more and more like a track car lol
Old 08-30-2018, 08:10 PM   #89
SuperTom
SuperTom's Avatar
Yep washer bottle was one of the first things I did last year. Neighbors must have thought I was crazy taking my front bumper off a brand new car haha.
Drilling out the welds on that Driveshaft mount will be the most drastic thing ive done. I still have all the stock parts to return to stock (besides shocks/struts, sold them to pay for coilovers). Once I start cutting and drilling though it will be the point of no return.
Also my Mishimotor slim fan kit arrived according to another member not any weight loss over stock. But Im going to run only with the passenger fan since the drivers fan is for AC equipped cars (no more AC in mine). Should take a few lbs off the front driver side. The hardest side to lose weight. Im going to weight when I get home from work.
The Following User Says Thank You to SuperTom For This Useful Post:
Old 10-24-2018, 01:12 PM   #90
SuperTom
SuperTom's Avatar
Don't know if you ever got to this but I just ordered a used one for $100. Was heavier than expected at 17lbs. Im going to swiss cheese the FK out of this thing! Then I can just swap with stock one
The Following 3 Users Say Thank You to SuperTom For This Useful Post:
Icecreamtruk (10-24-2018), new2subaru (10-24-2018), Tristor (10-24-2018)
Old 10-24-2018, 06:13 PM   #91
new2subaru
Weight Weenie
Drives: 15 FR-S
Thanks Tom! Can't wait to see what else is back there.
I just pulled mine off the road unless we get a nice day. Once the snow flies it's being torn apart
Old 10-24-2018, 06:15 PM   #92
SuperTom
SuperTom's Avatar
mine is going to be my snow machine so wont happen till after winter. I know the insulation back there is worth about 5lbs. Would be nice to chop this brace down from 17 to 7. That would be 15lbs total
Old 10-24-2018, 06:26 PM   #93
new2subaru
Weight Weenie
Drives: 15 FR-S
I think that's realistic. I'll wait to get mine out to see how I'm going to go about it. I can't afford CF doors but will be using dimple dies extensively. I plan on recreating steel/metal parts out of aluminum too.
I have a tendency to get lazy in the winter months. I'm hoping this will keep me more active
Old 10-24-2018, 06:38 PM   #94
SuperTom
SuperTom's Avatar
yeah swiss cheesing this brace is going to take some time hence why I bought a used one to work on.
Think I may also get a used headlight radiator support and dimple die that might get a few more pounds off the nose since it bolts off and on
https://www.partsgeek.com/12txsg7-sc...r-support.html
Old 10-24-2018, 06:48 PM   #95
new2subaru
Weight Weenie
Drives: 15 FR-S
That's piece is on my list to dimple die also. The rear deck and inside door panels as well. I don't think it'll add up to be substantial but every little bit counts and it free! I had it corner balanced a few weeks ago and I'm at 2,574. My interior is gutted though.
The Following User Says Thank You to new2subaru For This Useful Post:
SuperTom (10-24-2018)
Old 02-23-2019, 08:35 PM   #96
q335r49
Drives: 2013 scion fr-s
Good call on that metal bracket under the steering wheel Supertom!
Have you guys thought about also removing the metal bracket that holds the OBD2 port? It's doesn't seem structural at all and to be honest is a hinderance in connecting the obd2. Would rather just have it hang free. However, I'm not quite sure how involved the process is.
Edit: Nevermind -- that bracket extends all the way across behind the climate control knobs to under the glovebox
q335r49 is offline   Reply With Quote
Old 02-24-2019, 04:01 PM   #97
q335r49
Also, although it's incredibly minor, drilling the handbrake lever would be a minor weight savings as the peice is over-engineered and non-structural. I have my center console removed and it's out in the open, so it'll be a cosmetic thing for me too.
The Following User Says Thank You to q335r49 For This Useful Post:
SuperTom (01-05-2020)
Old 02-24-2019, 06:06 PM   #98
new2subaru
Weight Weenie
Drives: 15 FR-S
All of these are minor weight losses but they add up. I'd like to see you ebrake drilled out.
Here is my rad support. 1/4lb loss and still very strong. It looks cool too IMO. I still need to clean it up and paint it.
The Following 2 Users Say Thank You to new2subaru For This Useful Post:
q335r49 (02-24-2019), SuperTom (01-05-2020)
Making the BRZ ever lighter Alabang BRZ Cosmetic Modification (Interior/Exterior/Lighting) 10 04-16-2014 08:57 AM
Are dry carbon fiber front 1/4 panels lighter than OEM? Superhatch Cosmetic Modification (Interior/Exterior/Lighting) 5 05-27-2013 03:47 AM
Better to go wider or lighter? BRAWL Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 08-02-2012 09:48 PM
Increased whp by having lighter wheels mechaghost Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 07-03-2012 12:46 AM
What return from going with lighter wheels? bazguitarman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 30 06-01-2012 09:35 AM
