Old 08-29-2018, 06:29 PM   #1
displacedTexan
displacedTexan's Avatar
Drives: '13 FR-S 10 Series
Grinding noise while braking
My car just started making a rhythmic grinding noise while braking firmly. From inside the cabin it sounds like it's coming from the front driver side. The noise definitely is tied to braking. When braking, there's no noise until I press firmly on the brake pedal. It gets more quiet and goes away as I let off the brake pedal. The noise also slows down as the car comes to a stop.
I took the front wheels off and inspected the brakes/rotors and didn't see anything that looks broken. Anybody have an idea what this could be? Warped rotor, maybe? I'm parking the car in the garage until the weekend when I'll have more time to focus on fixing it.
You can hear the noise clearly in the video below as I come to a stop in the first 10 seconds.
[ame]https://www.youtube.com/watch?v=fBx7_eUeVBM&[/ame]
displacedTexan is offline   Reply With Quote
Old 08-29-2018, 06:36 PM   #2
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Sounds like rotor to me. I've had badly out of round tires make similar noise while braking.
humfrz (08-29-2018), Ultramaroon (08-29-2018)
Old 08-29-2018, 07:05 PM   #3
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Might be slight warpage of the rotors. Car is totaled. j/k
If you can measure the runout on the rotor you can see if the rotors need replacing.
Intent > Content
Old 08-29-2018, 07:27 PM   #4
Do you feel it in the steering wheel, or in your butt? It can be tricky to identify the source of the noise.
Old 08-29-2018, 07:50 PM   #5
displacedTexan
The car isn't pulling left or right while braking. There's no difference in the steering feel now that this noise has shown up. My best guess was that it's coming from the front driver side because it's noticeably louder in my left ear and sounds like it's forward of me in the car.
Can't say that I feel it in my butt.
I switched the front wheels and torqued to spec in a star pattern to see if there was any affect on the noise. No change.
Old 08-29-2018, 08:13 PM   #6
Yep, I'll go along with the warped rotor theory.
I'd suggest you take your car to a brake shop and have them replace the front two rotors, at a minimum.
humfrz is online now   Reply With Quote
Old 08-29-2018, 08:21 PM   #7
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
........ oh boy.
Your inner brake pad is gone. You need new pads. Turn those rotors or get new ones.
Simple shit.
Old 08-29-2018, 08:39 PM   #8
displacedTexan
........ oh boy.
Simple shit.
I didn't check the depth of the compound on the pads when I inspected them (should have), but the inner pads were by no means gone. Still had a lot of compound on the pads.
Old 08-29-2018, 09:52 PM   #9
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Alright, gotta ask if anything has happened in the last month or two? Car up on a lift for any reason? Any mods or maintenance? Heavy braking followed by a stop? Unusual tire wear?
Also, I would not assume it's the fronts because of the sound. Sound does weird things in an oddly-shaped metal box. I would check out the rears as well.
It's possible that a caliper has seized (or at least gotten sticky) heating up one or more pads to the point where, when you stop, the pad material sticks to the rotor and creates an uneven film. If it's bad, you can feel the heat coming off the problem wheel after you've parked.
Old 08-29-2018, 11:06 PM   #10
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Yep. But only on one side. You'll know when you pop the pads off.
Unless it's totally unrelated to brakes. But eh, who knows, until you start unbolting stuff.
Old 08-30-2018, 09:23 AM   #11
displacedTexan
I pulled the caliper off and pulled the pads out when I inspected them.
Old 08-30-2018, 04:27 PM   #12
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Dang, well if the pads are in good shape, then it must be the rotors.
Unless by some weird chance the abs is kicking in for some unknown reason? That might mimic grinding/vibrations. Or a wheel bearing going out? But I hardly seen wheel bearings going out. Maybe your the lucky 5% that's have it.
Old 08-30-2018, 05:00 PM   #13
Skurj
Drives: SOLD...
new rotors less than $60 ea... and takes no time to replacem.
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018
and its gone... Sept '18 tho I am sure I will miss it
Replaced with 18 50th edition ND
Skurj is offline   Reply With Quote
Old 08-30-2018, 05:12 PM   #14
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Installing front rotors and pads is fairly easy. For a job this simple, I would spend the money on parts, not labor.
I have replaced all my rotors and pads with some after market parts from ebay that: stop my car, fit in my small budget, and make me happy.
I LIKE TIRES!
Ultramaroon (08-30-2018)
Circular Grinding Noise DaBoBo21 Engine, Exhaust, Transmission 0 04-20-2017 09:28 AM
Grinding noise when AC on Mikeez Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 07-11-2016 01:25 AM
Braking Noise hasfoot Issues | Warranty | Recalls / TSB 12 04-25-2015 12:02 AM
Grinding noise? frs10 Issues | Warranty | Recalls / TSB 7 09-20-2013 10:57 AM
Grinding / Shaking under emergency braking Kurenai Issues | Warranty | Recalls / TSB 16 11-05-2012 09:52 PM
