Old 08-28-2018, 07:14 AM   #1
mhiscott
Drives: 2013 FRS
Temp removal of pass seat (airbag light)
I am about to foster a large breed dog, and will need to be able to transport him around from time to time. Unfortunately, the FRS is my only car, and the dog doesn't fit inside on the front seat.
If I were to unbolt my passenger seat, and run the car periodically with no passenger seat, I realize I will get an airbag light while it's out. What I'm wondering is, when I reinstall the seat, does the light go out on its own? Or would I need to follow up each "seat removal" with a trip to the dealer to have the SRS module reset?
Thanks!
Mike
mhiscott is offline   Reply With Quote
Old 08-28-2018, 07:24 AM   #2
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Sorry, I don't have an answer for your question because this is all I can think about right now!
[ame]https://www.youtube.com/watch?v=ZB1fQyeorS0[/ame]
BirdTRD is offline   Reply With Quote
Old 08-28-2018, 07:45 AM   #3
The airbag module should recognize when the seat is back in place.
Old 08-28-2018, 12:16 PM   #4
Thanks!
Mike
Betcha if you put the back seats down, opened up the trunk and tossed a treat in there, he would jump in and lay down -
Old 08-28-2018, 12:51 PM   #5
evomike
Drives: frs
its probably still going to have a light that will need to be cleared, best bet is to buy a cheap scanner that has srs capabilities.
evomike is offline   Reply With Quote
Old 08-30-2018, 09:27 AM   #6
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Thanks!
Mike
If you buy an OBD-II ELM 327 and also buy the carista app on any smartphone, you can disable the airbag light before the seat removal. When you reinstall the seat you re-enable it and you should be fine.
It's also able to be done through techstream easily if you have a usb-ob2 cable compatible with techstream.
Also it's honestly worth it getting a bluetooth OBD-II dongle and some obd2 app on your phone with it at this point, it's kind of indispensable at this point in the automotive world if you ever want to fix things yourself.
Old 08-30-2018, 10:26 AM   #7
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
I have removed the passenger seat in my FR-S to haul a toolbox, and also lumber.
So i've done it twice at least.
While driving without the seat, the light is on and the car beeps at me.
After reinstalling it, the light turns off and everything seems fine.
I have not "tested" it by crashing my car and seeing if the seat airbags work.
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
Old 08-30-2018, 10:39 AM   #8
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Well, what are you waiting for??
Lol.
Current DD: M235i
8RZ is offline   Reply With Quote
BRZ / FRS Seat Swap - No Airbag Light! JohnPayneFun Cosmetic Modification (Interior/Exterior/Lighting) 3 07-23-2018 02:27 PM
WTB: Resistor for Aftermarket Seat Airbag Light KPDoubleX Canada Classifieds 9 05-01-2016 03:57 PM
WTB: FRS oem driver airbag, clock spring, both front seat belts, airbag module 14_GT86 Want-To-Buy Requests 3 04-01-2015 12:26 AM
Side Airbag light with aftermarket seat? Hanakuso Cosmetic Modification (Interior/Exterior/Lighting) 7 04-09-2014 03:20 PM
Airbag light stays on after removal/reinstallation Pablitomarrero Issues | Warranty | Recalls / TSB 13 04-04-2014 08:34 AM
