Old 01-07-2013, 07:26 PM   #1
Hanakuso
Side Airbag light with aftermarket seat?
Other then the TRD airbag canceller, what other options are there for us? I know we can run without a resistor but I don't want the annoying light or the DIY of blocking it in the gauge cluster.
Hanakuso is offline   Reply With Quote
Old 05-09-2013, 08:44 PM   #2
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Anyone?
TouchMyHonda is offline   Reply With Quote
Old 05-14-2013, 11:05 AM   #3
jadewbj
jadewbj's Avatar
Drives: 2013 Whiteout Scion FRS
The resistor works perfectly fine on the drivers side. That is all you need if all you replace is the drivers side. If you do the passenger side the only way to not have it is to remove the passenger seat weight sensor from the stock seat and plug it in.
We folded it up and tucked it under the carpet. The only issue is that it thinks there is someone in the passenger seat all the time and it wants the seatbelt plugged in. I am going to try and turn it off with techstream.
Trust me when I say that is the only way to replace the pass seat and not have a light.
More on my blog:
http://www.jadecrew.com/custom-recar...seats-in-fr-s/
jadewbj is offline   Reply With Quote
Old 04-04-2014, 01:51 AM   #4
BRZpower
More on my blog:
so even the trd option you must use the stock weight sensor and put it under the seat? sounds kinda ghetto. i hope someone makes a kit soon.
what signal does the weight sensor send to that plug? there has got to be a way to trick the car into thinking its plugged in.
BRZpower is offline   Reply With Quote
Old 04-04-2014, 09:26 AM   #5
jadewbj
jadewbj's Avatar
I'm no electrical engineer but I would guess if someone can figure out the right resistor to mimic the signal. I know the airbag one is not the same.
Old 04-05-2014, 09:33 AM   #6
BRZpower
Maybe it just needs a completed circuit?
Old 04-09-2014, 02:59 PM   #7
jadewbj
jadewbj's Avatar
We tried the resistor from the airbag and it fried it. Not sure.
Old 04-09-2014, 03:20 PM   #8
ceruleansoldier
Drives: 2013 Scion FR-S - Raven
This works. I have one installed and have had no issues.
[ame="http://www.amazon.com/3-3-Ohm-Flameproof-Resistor-Pcs/dp/B0002ZP0US/"]Amazon.com: 3.3 Ohm 1W Flameproof Resistor 10 Pcs.: Electronics[/ame]
ceruleansoldier is offline   Reply With Quote
Airbag light trick for racing seats. Ricepuddin DIY (Do-It-Yourself) Guides 111 03-18-2024 08:05 AM
What's the weight on the passenger seat sensor? Iphone sets off airbag/seatbelt chime NeedsmoreCowbell Scion FR-S / Toyota 86 GT86 General Forum 67 03-28-2013 12:21 PM
Passenger side seat belt frs-guy Issues | Warranty | Recalls / TSB 1 10-11-2012 12:39 AM
Please post FR-S w/ aftermarket leather seat pics ngabdala Scion FR-S / Toyota 86 GT86 General Forum 6 05-31-2012 09:51 AM
Question about side airbag Nardi330 Scion FR-S / Toyota 86 GT86 General Forum 11 01-30-2012 07:02 PM
