Old 08-26-2018, 08:41 PM   #15
invaliduser
Drives: 2017 86
1. Make sure both collars are 1/8" away from bushing.
2. The popular whiteline end links are too long for a 1+ inch drop. Cutting them a good half inch is necessary.
4. Make sure bar is centered on vehicle (same poke on each side).
5. Blue loctite everything
6. Ratcheting wrenches unless u hate yourself
7. Connect up top end links, put washer on bar side, use blue loctite. Tighten them down.
8. Make sure preload/length nuts are not tight
9. Lower car on to ramps.
10. Raise up rear end (Jack on differential) so rear is same height as front on ramps.
11. Connect up bottom end links, washer on bar side, use blue loctite. Tighten down.
12. Adjust preload to a point where there is none.
13. Tighten down preload nuts
invaliduser is offline   Reply With Quote
The Following 2 Users Say Thank You to invaliduser For This Useful Post:
Pat (06-30-2020), sroby (02-24-2019)
Old 08-26-2018, 10:55 PM   #16
FastWhite
Drives: Subaru BRZ Limited M/T
I do need to mention that the end link pictures above are not on the website. Neither are they on the SPL website. You have to contact FT 86 speed factory directly and they can order them from SPL. I just installed mine today as per above notes. They fit good.
I am running the TIEN SRC’s and I am at the recommended ride height for these coil overs. Center of wheel to fender, 335 mm.
FastWhite is offline   Reply With Quote
Old 08-26-2018, 10:56 PM   #17
FastWhite
Oops, the OEM length is what is pictured on the website.
DIY: Sway-bar installation justinco DIY (Do-It-Yourself) Guides 3 01-26-2018 06:45 PM
Strongest rear sway bar end link? I broke 3 sets... FLASCH Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 10-15-2015 09:32 AM
front sway end link clearance issue HELPPP MEEE?!?! BrightSlide Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 07-09-2015 08:31 AM
Help, installed Swifts, damaged F Sway Bar Link F1fletch DIY (Do-It-Yourself) Guides 0 02-09-2014 11:49 AM
Ajdustable front sway bar link on a coilover questions Vten Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 05-06-2013 09:39 PM
