Old 10-10-2015, 11:44 PM   #1
FLASCH
Drives: Asphalt FR-S
Strongest rear sway bar end link? I broke 3 sets...
I just broke my third set of rear sway bar end links. I broke the first set (Hotchkiss end links) when running Hotchkiss springs, sway bars with stock struts. After I blew out the stock rear struts, I got Mann-Engineering AST coil overs and got Whiteline end links (because I heard Whiteline end links were great) and kept the Hotchkiss sway bars.
With this set up, I broke two sets of Whiteline rear end links. The first set after about 6 months (while on track at Laguna Seca), and the second set after ~ 1 year (I have no idea when exactly). Whiteline replaced the first set under warranty, and I could get them to replace the second set, but I just want to find an end link that won't break!
I only do a ~6 track days/autoxs a year. I am running ~1.5 inch drop.
I saw Perrin put out the SS XD Spherical Bearing Rear Sway Bar Endlinks for ~$500 (seems expensive)
(http://perrinperformance.com/i-14660...-fr-s-brz.html)
Anyone try these?
Anyone know of anything really strong?
Pictures of the break:
FLASCH is offline   Reply With Quote
Old 10-10-2015, 11:53 PM   #2
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
I dont know why you have broken 3 set of end links because they are not supposed to be broken that easily after properly adjusted.
But since you ask for the best one, I would say SPL.
http://www.splparts.com/products/spl...s-brz-wrx.html
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 10-11-2015, 12:06 AM   #3
FLASCH
Thanks, those do look great.
I did adjust the swaybars the first time, so I thought I may had made a mistake which caused the end links to break. The next two times they were installed I had a professional race shop (both authorized Whiteline shops) do everything.
I am starting to think that it maybe the Hotchkiss sway bar design that doesn't align with the rear control arm properly, which may cause extra stress.
Old 10-11-2015, 12:08 AM   #4
Fastbrew
Drives: 2014 Pearl White BRZ
What size sway bar are you running? Maybe going smaller and letting the coilovers do their job a bit more might help.
Also - did you put in LCAs? Which ones?
Fastbrew is offline   Reply With Quote
Old 10-11-2015, 12:12 AM   #5
swarb
Where are they breaking at?
http://www.aurorabearing.com/index.html
You should be good with a military or aerospace series.
Many companies use their parts and sell under their own name.
Not sure who actually carries their parts, let us know if you find a place or what you decide to do.
Old 10-11-2015, 12:22 AM   #6
FLASCH
The rear is 19 mm. It is 4 way adjustable. After I broke the 2nd set, I went to spot softer on the sway (so 2nd softest setting) to try to reduce the stress on the part. Ya, I might be looking at new sway bars if this next set doesn't work. I just really like the way it handles now, it is corners really flat and very neutral.
I am running the SPC adjustable lower control arms, but I only installed those after the second set broke. They were installed the same time as the latest Whiteline end links.
Old 10-11-2015, 12:35 AM   #7
FLASCH
Interesting. I will look into those.
The Hotchkiss end links bent the the bolt that linked the end link to the LCA so much that I had to cut is off with a dremel.
The Whiteline's broke in the same place, shown below. All times the right side broke.
Old 10-11-2015, 12:47 AM   #8
ryoma
ryoma's Avatar
damn, that's crazy lol. whiteline is supposed to be good stuff.
Old 10-11-2015, 12:52 AM   #9
Fastbrew
Some LCAs have a bit of different geometry. GTSpec, Stance, etc. I run GTSpec. They have a bit of an angle to them. Helps with lowered cars in some cases.
Yours?
vs
Anyway - just seems weird that there is that much force on that one side. Certainly beefier links may help but maybe something else is going on?
I also have a GTSpec rear sway bar braces
Well, that's all I know and it probably didn't help much! Good luck with the issue
Old 10-11-2015, 02:34 AM   #10
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I've noticed that even an entirely stock rear suspension will cause the portion of the endlink connected to the LCA to twist a bit once mounted. luckily the stock uses rubber bushings so it does not break.
Intent > Content
Old 10-11-2015, 03:24 AM   #11
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
@Racecomp Engineering
Old 10-11-2015, 03:44 AM   #12
Fastbrew
Avo has a set I have never tried -
The Following User Says Thank You to Fastbrew For This Useful Post:
solidONE (10-11-2015)
Old 10-11-2015, 05:21 AM   #13
solidONE
solidONE's Avatar
I'd go with these if you intend on keeping the rear sway.
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
FLASCH (10-11-2015)
Old 10-11-2015, 12:48 PM   #14
kbye
kbye's Avatar
Drives: 2014 FR-S
If it's always one side consistently breaking, the issue might not be the end link but the positioning of the centering rings on the sway bar. Have you checked that the centering distance is the same on both sides?
kbye is offline   Reply With Quote
WTB: Rear sway end links or sway bar with endlinks JoeBoxer Want-To-Buy Requests 1 08-03-2015 01:20 PM
front sway end link clearance issue HELPPP MEEE?!?! BrightSlide Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 07-09-2015 08:31 AM
Help, installed Swifts, damaged F Sway Bar Link F1fletch DIY (Do-It-Yourself) Guides 0 02-09-2014 11:49 AM
Allen key broke off inside rear strut... infinite012 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 01-07-2014 01:38 PM
Ajdustable front sway bar link on a coilover questions Vten Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 05-06-2013 09:39 PM
