Old 12-19-2017, 03:24 AM   #1
Bach415
Bach415's Avatar
Drives: Whiteout FRS
Front sway bar end link installation?
Hey guys,
Just wondering if there is a specific way to install the front end links. I currently have RacerX adjustable front end links. It seems to be the culprit in making noises as every adjustment I do to them either makes the noise happen less or more frequently or go from passenger to driver and vice versa.
How I installed it:
Car jacked up with suspension unloaded, remove old end links (unusable anymore). Installed driver side end link and adjust it to the minimum setting and tighten. Then put the car onto ramp (with wheels on now) and install the passenger side end link. Adjust the passenger side end link until it feels easy to turn then hand tightened. Jack up the car, wheels off, and tighten the passenger end link. The bolts from the end link to the coilover and sway bar were also torqued down.
Is there a certain way to install the end link or does it need to be in a certain position? Just trying to eliminate the sound problem.
Bach415 is offline   Reply With Quote
Old 12-19-2017, 06:09 PM   #2
norcalpb
norcalpb's Avatar
I installed mine by turning the wheel and just taking it off with the car on the ground. I believe you want pre load on the end links before tightening
The Following User Says Thank You to norcalpb For This Useful Post:
Bach415 (12-20-2017)
Old 12-20-2017, 03:04 AM   #3
Bach415
Bach415's Avatar
I'll give that a try and see what happens.
Old 12-27-2017, 02:56 AM   #4
Bach415
Bach415's Avatar
BUMP still making noise after adjustment and alignment
Old 12-27-2017, 10:37 AM   #5
cjd
cjd's Avatar
Drives: 2017 BRZ
What kind of noise?
Old 12-29-2017, 03:33 AM   #6
Bach415
Bach415's Avatar
Old 01-06-2018, 09:36 PM   #7
norcalpb
norcalpb's Avatar
Why did you adjust the Endlinks to minimum height to begin with?
Old 01-08-2018, 03:31 PM   #8
Bach415
Bach415's Avatar
Just wanted to be safe on avoiding the LCA. On my old HKS end links, even though they were shortened from factory, they got pretty close to hitting the LCA (always had this weird clunking sound but didn't see any marks on LCA but the rubber ended up ripping bottom side only and seizing up the joint). Same with Whiteline (had to return them as they were hitting my fender wall). I had slowly increase the end link length on both sides for the RacerX until the noise was to a minimum. Still bothered me that I can hear it.
Anyways, problem is solved now. Lowered the car more in the front and set the end links close to minimum settings and the noise is gone (possible that I finally just got the right settings by luck).
Old 01-08-2018, 03:35 PM   #9
norcalpb
norcalpb's Avatar
Yeah it’s a shame that when you search “Endlink noise”, all the posts tell you to get shorter end links. I once had whiteline endlinks that were set at minimum height and I got a really nasty binding noise. I then switched to Perrin endlinks and they would rub so hard on the inner fender that the bushings got squeezed out like a press would do.
Bottom line I’m back to stock endlinks and there is no noise lol. But I’m glad your problem was resolved as well.
Bach415 (01-08-2018)
Old 01-08-2018, 10:08 PM   #10
Bach415
Bach415's Avatar
@norcalpb *couldnt let me quote you lol. But yeah, that is true. That's why I kept on switching different end links. Too many variables when it comes to end link sounds.
Old 04-26-2018, 07:23 PM   #11
Tgutz21
Today I realized that my traction control light kept coming on when taking turns. I come to find out my passenger side swar bar link is flat out missing and I don’t know how it happened. Do you have any recommendation on which ones to get? And if I should jack up the car or leave it grounded?
Tgutz21 is offline   Reply With Quote
Old 07-10-2018, 10:38 AM   #12
B T
Any idea what the shortest available adjustable endlink is? I have marks where my whiteline endlinks have been kitting my SPL LCAs even set at the minimum length.
B T is offline   Reply With Quote
Old 07-22-2018, 01:01 AM   #13
FastWhite
Drives: Subaru BRZ Limited M/T
Godspeed has a front end link, shortest it goes to, per website is 200 mm
FastWhite is offline   Reply With Quote
Old 08-17-2018, 04:18 AM   #14
FastWhite
SPL has released there new front end links. Two sizes, OEM length and shortened length, 7.5-9.5 inches
DIY: Sway-bar installation justinco DIY (Do-It-Yourself) Guides 3 01-26-2018 06:45 PM
Strongest rear sway bar end link? I broke 3 sets... FLASCH Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 10-15-2015 09:32 AM
front sway end link clearance issue HELPPP MEEE?!?! BrightSlide Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 07-09-2015 08:31 AM
Help, installed Swifts, damaged F Sway Bar Link F1fletch DIY (Do-It-Yourself) Guides 0 02-09-2014 11:49 AM
Ajdustable front sway bar link on a coilover questions Vten Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 05-06-2013 09:39 PM
