| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: MDX, Camry
Why is my BRZ idling so rough?
Long-time 2013 BRZ owner here. Car is about 5 year old with 37k miles. One thing I am concerned about it that the car idles petty rough, especially when it is still cold. I feel like the connection rods has a bad bearing (of course I don't really know). It has been this way since new and I have a pretty peaceful 5 years now. Should I be concerned that it is an exploding bomb? I still have a couple of month drive drain warranty. Not sure whether I should take it to a dealer to have a look.
Any ideas? Thanks. |
#2 | |
#3 |
Drives: 2013 frs red
Hasn't it been to a dealer already? It has 37k on it.
#4 | |
What lantana and tcoat said^ So many things can cause a rough idle condition. Do you have any mods? Either way you said it yourself go to the dealer while it still has time left under warranty and get it checked out, if they don't find anything take it to another Subaru dealer if possible to confirm. Also 37k miles is pretty low for a 5 year old BRZ which is pretty cool.
#5 |
Drives: Crapcan
Have you tried turning the "idle roughness adjustment screw?"
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | FRSBRZGT86FAN (08-17-2018) |
#6 |
factory ghost cam
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | chaoskaze (08-18-2018), FRSBRZGT86FAN (08-17-2018) |
#7 |
Drives: MDX, Camry
It is quite hard to describe the feeling. I kind of suspect that it is a Subaru design issue. Piston and connecting rod of a Boxer should move in a roughly horizontal plane. But I feel that while it is idling, there are some additional vibration on the vertical plane. I was hoping that someone else who experienced it can explain to me what is going on. But scratch that.
#8 |
Drives: '15 BRZ RA
@qqzj There is a reason that 4-cyl Boxer engines have rough idle. It is on their inherent design, because of the firing order LLRR or RRLL.
#9 | |
Drives: '16 FR-S RS2 MT, '06 xA Polar MT
LRL+RLR or RLR+LRL
Math is like Love, simple idea at first that quickly gets complicated
#10 |
Drives: brz 2017 hksv2
what you mean with rough? that the rpm oscillate or that the car vibrates? it rpm oscillate i m pretty convinced it a becayse the stock tune that add PI already starting from 0.2 of engine load and PI and DI are never match-scaled properly
i fixer the rpm oscillating in every tune I did removing PI untill 0.4 engine load and reducing a bit port scalar from 228 to 222 or 224 |
#12 | |
TRACKBREAD
Yea the stock tune has a garbage idle, especially on the early cars. |
| The Following User Says Thank You to Yoshoobaroo For This Useful Post: | norcalpb (08-18-2018) |
#13 | |
Drives: Crapcan
#14 |
| Odd noise when idling? | Terruko | Issues | Warranty | Recalls / TSB | 29 | 10-16-2016 07:09 PM |
| 6 speed m/t idling low | Gt86_nick | Engine, Exhaust, Transmission | 1 | 01-28-2014 07:54 PM |
| Idling Issue | ericmpena | Issues | Warranty | Recalls / TSB | 1 | 11-01-2013 12:21 AM |
| High idling on new FR-S | ndsleep612 | Issues | Warranty | Recalls / TSB | 19 | 07-27-2013 10:06 AM |
| Idling/RPM question | Crackseed | Hawaii | 3 | 02-24-2013 11:54 PM |
