Old 08-15-2018, 11:47 PM   #29
Still no explanation ultra. Op still doesn't get it. The structure was there, you cut it out.
Didn't it come with instructions?
Maybe I'm wrong but I read differently. He may not have said it exactly but I think he gets it.
I also don't think the wang was made specifically for the car. In order to get the fasteners tight without deforming the skin, spacers would have to be accurately designed and installed between skin and structure. That would be quite a project to get right.
texastwurkt3am (08-16-2018)
Old 08-15-2018, 11:51 PM   #30
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Jesus can we stop being hypercritical here? I'm sure we've all done stupid shit like this at one point or another. I know I have.
OP came here for advice on how to fix it, not to hear how badly he fucked up from 27 different people, he knows he fucked up.
OP, good luck and let us know what route you're taking and how your attempts at fixing it go.
My suggestion is to take the trunk lid off and place it upside down, pour 16lb structural foam in the structural channels that you cut the big holes in. With any luck that fixes it.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
Old 08-16-2018, 02:15 PM   #31
texastwurkt3am
texastwurkt3am's Avatar
Drives: '17 PP BRZ
I do grasp that, even if I didn't word it correctly. And no, it did not come with instructions; only a part list.
FT86 Speed Factory Catted UEL Headers, Motiv Overpipe, Ark Test Pipe, Ark Grip Exhaust, GrimmSpeed Intake, V4 Stage 2 OFT Tune, Illusion Red Powdercoated Enkei Raijin 18x8 Squared, Eibach Pro Springs, MTEC Clutch Spring, Audio Upgrade, Random Accessories
texastwurkt3am is offline   Reply With Quote
Old 08-16-2018, 02:26 PM   #32
texastwurkt3am
Drives: '17 PP BRZ
Sounds like a good place to start. I wasn't previously aware of structural foam before this thread. I was gonna fabricate some metal plates but this seems easier
Old 08-19-2018, 10:12 AM   #33
gtengr
Drives: 2017 BRZ
Is that cavity open to the license plate area? May want to seal some of that off.
gtengr is offline   Reply With Quote
Old 08-19-2018, 01:29 PM   #34
I hadn't heard about that stuff either. Please let us know how it works.
Old 08-19-2018, 03:17 PM   #35
Grady
Grady's Avatar
I would not use foam! Foam is great for holding moisture and starting corrosion.
Just clean the cut out area up and sandblast everything get some epoxy and micro balloons and fill it up. Once that has set drill new holes.
I beleive you are in the DFW area so if you need any help just PM me.
Old 09-22-2018, 04:01 PM   #36
Yoshoobaroo
TRACKBREAD
An epoxy mixed with fiberglass microballoons will work well for sure!
Old 09-22-2018, 04:01 PM   #37
Yoshoobaroo
TRACKBREAD
original post
Any luck?
Old 09-25-2018, 09:02 PM   #38
Grady
Grady's Avatar
Any luck?
He did not take anyone’s advice. Saw him on the road the other day.
The Following 2 Users Say Thank You to Grady For This Useful Post:
texastwurkt3am (10-09-2018), Yoshoobaroo (09-25-2018)
Old 10-09-2018, 04:30 PM   #39
texastwurkt3am
Drives: '17 PP BRZ
Any luck?
I am! I'm in Farmer's Branch. Sorry, been in a weird funk the past few weeks and haven't checked back. I'm down to try
Old 10-09-2018, 04:31 PM   #40
texastwurkt3am
Drives: '17 PP BRZ
Any luck?
Still yet to try anything. I hit up the microballoon guy to give it a shot
Brace FRS/BRZ/86 trunk for GT Wing/Trunk lateral movement Ashikabi DIY (Do-It-Yourself) Guides 2 09-09-2016 04:04 PM
Truck brace to support a wing 08stiguy Cosmetic Modification (Interior/Exterior/Lighting) 29 03-30-2016 01:52 PM
FS: Cusco Front Strut Tower Brace with Master Cylinder Brace / Adj Chassis Brace VoiD Brakes, Suspension, Chassis 2 03-16-2016 04:19 PM
sold all Whiteline Rear sway brace also dc Sports lateral brace stiboost08 Brakes, Suspension, Chassis 25 07-19-2015 07:49 PM
Wobbly gas pedal? Rayme Issues | Warranty | Recalls / TSB 1 09-30-2014 09:19 AM
