Old 03-29-2016, 09:27 PM   #1
08stiguy
08stiguy's Avatar
Drives:
Truck brace to support a wing
Hello everyone,
Trying to see if there are any aftermarket or DIY's trunk braces to support a wing? I have a wing installed but the truck is still a tad flimsy. Looking to brace it up for support. Has anyone done or seen this?
08stiguy is offline   Reply With Quote
Old 03-29-2016, 09:48 PM   #2
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
keeping your brz?
Flex Fuel Turbo BRZ
BRZtoni is offline   Reply With Quote
Old 03-29-2016, 09:51 PM   #3
08stiguy
08stiguy's Avatar
Drives:
Originally Posted by BRZtoni View Post
keeping your brz?
Yep! I couldn't sell it lol. I have big plans for it.
The Following User Says Thank You to 08stiguy For This Useful Post:
BRZtoni (03-29-2016)
Old 03-30-2016, 08:24 AM   #4
Ashikabi
Ashikabi's Avatar
Originally Posted by 08stiguy View Post
Hello everyone,
I've never seen one so you're likely on your own. I'd find a welder you can work with to design something custom. Good luck and be sure to post pics in the new "Look what I made!" thread
The Following User Says Thank You to Ashikabi For This Useful Post:
go_a_way1 (03-30-2016)
Old 03-30-2016, 08:27 AM   #5
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
@CSG Mike
Old 03-30-2016, 08:50 AM   #6
Or find a BFW designed for the car so it actually does something and has secure and ridged mounting points.
Old 03-30-2016, 09:14 AM   #7
08stiguy
08stiguy's Avatar
Drives:
I had it from a previous build so I'm not buying another one. Thanks for the useless tip though, I'll take it under advisement. Today I'm actually going to a M&R metal fabrication to get some brackets cut out and to see if they fit to stiffen up the upper lid of the trunk.
Old 03-30-2016, 09:27 AM   #8
Ashikabi
Ashikabi's Avatar
Lol easy killer...
I'm curious about this myself. What will these brackets look like? Will your trunk still be functional?
Old 03-30-2016, 09:44 AM   #9
Wasn't joking nor being snarky. If you have a left over part that is fine but just slapping any old thing on there isn't always the way to go. Parts are designed for specific cars for a reason.
Old 03-30-2016, 10:01 AM   #10
08stiguy
08stiguy's Avatar
Drives:
Sure, if you have the money to buy a brand new one, then yes agreed. I don't don't, so back to the point of stiffening the deck lid of the trunk. I remember seeing an episode of speed academy and their voltex wing came with a brace, so I may just see if they would be willing to sell just the brace itself.
Most aftermarket wings that are "made for your car" are attached via trunk lid, unless you go with the RB wing or some other BFW that attaches via the frame. So my thread was for bracing the under side, not buying a brand new wing that would leave me in the same predicament I'm in now.
Old 03-30-2016, 10:05 AM   #11
Ashikabi
Ashikabi's Avatar
The rocket bunny wing attaches to the lid just on the back side. You are talking about a frame or post that would mount inside the trunk and support the lid right? What if you add blocks around the outside of the lid next to the weather stripping?
Old 03-30-2016, 10:12 AM   #12
08stiguy
08stiguy's Avatar
Drives:
Correct. I may just use some longer bolts and fab a bracket to the under side of the base plate. Mmmmmm…I have to draw out some sketches.
Old 03-30-2016, 10:13 AM   #13
08stiguy
08stiguy's Avatar
Drives:
[ame]http://youtu.be/vYB3L465ndI[/ame]
Old 03-30-2016, 10:25 AM   #14
Ashikabi
Ashikabi's Avatar
Good looking wing but not sure that's what OP is looking for
FS: Cusco Front Strut Tower Brace with Master Cylinder Brace / Adj Chassis Brace VoiD Brakes, Suspension, Chassis 2 03-16-2016 04:19 PM
FS: Used OEM Limited Wing - Dark Grey Metallic - with STi wing gurney Enalband24 Exterior Parts (Aero, Lighting, Etc.) 10 01-03-2016 12:24 PM
sold all Whiteline Rear sway brace also dc Sports lateral brace stiboost08 Brakes, Suspension, Chassis 25 07-19-2015 07:49 PM
Brembo Front Brakes, APR Brake Ducts, GT Spec Rear Lower T Brace/Sway Brace, etc smellslikecurry Brakes, Suspension, Chassis 27 08-15-2014 11:52 AM
Supertek Brake Master Cylinder Support Brace - Now Available Supertek Industries Brakes, Suspension, Chassis 15 05-24-2014 11:45 AM
