Drives: '17 PP BRZ
Best way to brace this super wobbly wing?
I recently got and installed the GTC-200 Drag wing from APR and as the video shows, it needs some bracing. Ideas?
FT86 Speed Factory Catted UEL Headers, Motiv Overpipe, Ark Test Pipe, Ark Grip Exhaust, GrimmSpeed Intake, V4 Stage 2 OFT Tune, Illusion Red Powdercoated Enkei Raijin 18x8 Squared, Eibach Pro Springs, MTEC Clutch Spring, Audio Upgrade, Random Accessories
[insert cool phrase here]
Drives: BRZ Premium
Yeah lose the wing.
Lol I'm joking. Get larger plates on the underside mounting holes.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
| The Following User Says Thank You to Mr.ac For This Useful Post: | texastwurkt3am (08-13-2018) |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
You need cinder blocks between the thin trunk alloy sheet and the chassis.
"I gotta rock." -- Charley Brown |
Looks like the trunk is too flimsy to support it.
A.K.A. Starlord
Drives: 2015 Series.Blue
It looks like you mounted it to the sheetmetal, and not to anything structural...
![]() Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. |
Drives: 2017 BRZ
Can you post a pic of the underside of the trunk that shows where the bolts come thru? You're going to need a custom plate on the underside that ties into the frame of the trunk lid.
#7 | ||
Drives: '17 PP BRZ
TRACKBREAD
I'd fill the cavity where the bolts are with dense structural foam. Nice and light, and it'll stiffen the panel right up.
http://www.carbonfiberglass.com/Foam...-coverage.html |
| The Following User Says Thank You to Yoshoobaroo For This Useful Post: | texastwurkt3am (08-14-2018) |
Country Boy 4 Life
OP, If you use foam, I would highly suggest using low expansion spray foam. If you use the 3X expansion, it can warp the trunk lid. I watched my friend destroy his trunk lid by using the stuff that expands too much.
Edit: Saw the underside photo. Forget expansion foam. Either: Remove the wing and sell it. Use money to fix holes in trunk. OR Take the wing off, build underside brace plates, do body work on the damaged area - then paint, now re-install the wing. OR Get a new trunk lid and start over. Good luck!
I LIKE TIRES! Last edited by Leonardo; 08-14-2018 at 01:09 PM. |
| The Following User Says Thank You to Leonardo For This Useful Post: | texastwurkt3am (08-14-2018) |
#10 |
TRACKBREAD
The key is to be patient and do a little at the time. If your foam expands 3X, only fill 20% of the cavity. Rinse and repeat. And don't pour foam in a large cavity through a small hole, than can cause a blockage and generate pressure.
| The Following 2 Users Say Thank You to Yoshoobaroo For This Useful Post: | Leonardo (08-13-2018), texastwurkt3am (08-14-2018) |
#11 | |
Drives: Subaru BRZ Limited
#12 |
Drives: C5, GT-86, '24 Colorado TrailBoss
could he use that stuff from home depot great stuff or whatever its called
#13 | |
Country Boy 4 Life
I think longer bolts and new under mount plates are what is needed though. Forget the foam.
I LIKE TIRES! |
#14 |
Drives: 2017 BRZ
| Brace FRS/BRZ/86 trunk for GT Wing/Trunk lateral movement | Ashikabi | DIY (Do-It-Yourself) Guides | 2 | 09-09-2016 04:04 PM |
| Truck brace to support a wing | 08stiguy | Cosmetic Modification (Interior/Exterior/Lighting) | 29 | 03-30-2016 01:52 PM |
| FS: Cusco Front Strut Tower Brace with Master Cylinder Brace / Adj Chassis Brace | VoiD | Brakes, Suspension, Chassis | 2 | 03-16-2016 04:19 PM |
| sold all Whiteline Rear sway brace also dc Sports lateral brace | stiboost08 | Brakes, Suspension, Chassis | 25 | 07-19-2015 07:49 PM |
| Wobbly gas pedal? | Rayme | Issues | Warranty | Recalls / TSB | 1 | 09-30-2014 09:19 AM |
