Drives: frs
FRS/BRZ intake leak part?
What is this part called at the bottom? I've pinpointed intake lean causing a lean code.
![]() The little thing that hangs from the intake pipe. Mine has a huge hole from rubbing on belt. And what is even the point of this cup thing, Its hollow Last edited by Totalrecall; 08-08-2018 at 05:40 PM. |
#2 |
Drives: 2014 GT86
Probably resonator. To cancel out certain noise frequencies. If it's simpler to you, you can close it off, just like soundtube port.
#3 |
You could probably just cap it. Local hardware store should have it. Otherwise just get the Perrin inlet tube and do the sound delete.
#4 |
I think that one is important for the MAF
#5 | ||
That is indeed a resonator, but I believe it was used in some way to help the sound resonator tube that pumps the intake noise into the cabin. You can replace the whole intake tube rather than buying that OEM part as I was unable to find that specific part number looking at diagrams Also doing so deletes the sound tube: https://www.rallysportdirect.com/par...ake-hose-black Or you can have this used OEM tube: https://www.ebay.com/itm/O-13-16-SCI...item1a3c100bb1 I don't believe it's important to MAF, many CAI and other inlet tube manufacturers removed it and found it was simply for sound suppression. Also the TRD intake removes it entirely as well.
| The Following 2 Users Say Thank You to FRSBRZGT86FAN For This Useful Post: | Teseo (06-28-2024), Ultramaroon (08-08-2018) |
#6 | |
*gasp* "What if they were all...?" ... "Nah. No way!"
| The Following User Says Thank You to Ultramaroon For This Useful Post: | FRSBRZGT86FAN (08-08-2018) |
#7 | |
Well all I can say is I have the TRD intake installed which didn't do much but look cool, but I did cap off the sound tube as it came with the cap to remove it.
| The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | Ultramaroon (08-08-2018) |
#8 | |
86
It's called the resonator. FWIW just remove it and plug it. Link below will show you before vs after HP if you remove; https://cdn.mishimoto.com/media/prod...ringReport.pdf |
| The Following 2 Users Say Thank You to Boomerang For This Useful Post: | bcj (08-09-2018), Ultramaroon (08-09-2018) |
#9 |
TRACKBREAD
The resonator is used to tune the intake pulses. Mishimoto did some dyno testing with it, it generates about 3-5 HP depending on which air filter and intake hose used (also linked by @Boomerang above):
https://www.mishimoto.com/engineerin...nt-completion/ Either way the engine lost power without the resonator in every scenario. |
#10 |
Huge E85 fan!
Drives: 2016 Scion FRS
just get the Perrin silicone intake tube or a whole intake kit and replace that whole assembly.
| The Following User Says Thank You to guybo For This Useful Post: | Boomerang (08-10-2018) |
#11 | |
#12 |
Drives: frs
Thanks all for the info, I will end up just deleting it for now. Currently have the hole taped off with electrical tape. (Very temporary to troubleshoot lean code and confirm cause)
. Ill purchase whole intake part as suggested from ebay later on. |
| Oil leak under intake! | snk828 | Issues | Warranty | Recalls / TSB | 26 | 03-22-2018 10:35 PM |
| Part Out! (Phantom ESC, OFT, OFH, TRD Intake, Catback, etc.) | illmatic_frs | Canada Classifieds | 7 | 09-29-2017 12:31 PM |
| Intake manifold leak | Diz86x | Engine, Exhaust, Transmission | 5 | 07-13-2017 12:42 PM |
| SNJ Part Out: Aem Intake ; Boral, j2 , perrin | jwjknorr | Engine, Exhaust, Bolt-Ons | 39 | 06-06-2014 05:45 PM |
| Intake canister part number? | utekineir | Engine, Exhaust, Transmission | 5 | 09-10-2013 01:42 PM |
