Old 11-20-2017, 12:59 AM   #1
snk828
snk828's Avatar
Drives: raven FRS
Oil leak under intake!
Oil build up/ or leak under intake ? Is this normal for N/A set up? Need a catch can?
Leak by Louis li, on Flickr
snk828 is offline   Reply With Quote
Old 11-20-2017, 02:49 AM   #2
humfrz
Hello snk828, here is a thread you may wish to review that has an oil leak sorta like yours.
http://www.ft86club.com/forums/showthread.php?t=123110
No, that's not normal.
I don't believe a catch can is going to fix it.
You might start by checking the PVC valve and its hoses and connections.
I suggest you clean up the area and see if reappears.
humfrz
Old 11-20-2017, 04:18 AM   #3
snk828
snk828's Avatar
Drives: raven FRS
humfrz
I did clean it few days ago, it builds up little by little everyday. Not only that spot is leaking also around the timing chain cover seal, I can see the oil mark around the seal.
Old 11-20-2017, 12:02 PM   #4
humfrz
Well, another pesky oil leak ......
Back-in-the-day, when something on my car leaked, I started by torqueing (just tightening in those days) the bolts/nuts that held the suspect pieces together.
If that didn't fix it ...... I would go get a gasket kit and some permatex, take the part off, goop up the gasket real well and slap it back on ......... OR ...... just live with it ....... the barn floor was dirt and absorbed oil real well.
I'll defer to others to recommend what to do these days ......
humfrz
Old 11-20-2017, 12:47 PM   #5
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
humfrz
I just live with my timing cover leak until I feel like taking it off to reseal. And it's been leaking for a while lol
Old 11-20-2017, 01:20 PM   #6
humfrz
Good plan!
Really! Leaks don't hurt nutten if they aren't leaking on something that is not supposed to have oil on it, or, dripping on something that burns it, creating a bad smell ..... or ...... the leaking unit runs low on oil. In the latter case just add some more oil. In the former cases just get a drip pan.
humfrz
Old 11-20-2017, 01:23 PM   #7
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
....the barn floor was dirt and absorbed oil real well.
daiheadjai is offline   Reply With Quote
Old 11-20-2017, 01:29 PM   #8
humfrz
Heck, after all, I suspect that back-in-the-day that some of ol @Tcoat 's cars created, what today would be considered, an EPA superfund clean up site ..........
humfrz
Old 11-20-2017, 01:32 PM   #9
humfrz
Originally Posted by daiheadjai View Post
My computer no can see your picture .......
humfrz
Old 11-20-2017, 01:58 PM   #10
humfrz
Nah. My "good" cars had leaks fixed right away. My beaters either got filled with stop leak instead of oil or had enough dirt on the engine the oil couldn't reach the ground anyway.
Now I must confess that I probably sprayed much more coolant on the ground than any one person should have ever have been entitled to.
Old 11-20-2017, 02:15 PM   #11
humfrz
Yep, when I was a kid, I thought tractor engines came from the factory looking like this .....
humfrz
Old 11-20-2017, 02:32 PM   #12
daiheadjai
daiheadjai's Avatar
humfrz
Try this one:
[ame="https://www.youtube.com/watch?v=3VgufM9iLbI"]Crying Indian - The Single Tear - YouTube[/ame]
But you got the gist of it:
It is a short clip of a Native American shedding a single tear.
Although there's a poetic nature to it all: the oil came from the depths of the earth, and to the depths of the earth it shall return.
Ashes to ashes and all that...
Old 11-20-2017, 02:37 PM   #13
Ultramaroon
not playing cards
Ultramaroon's Avatar
humfrz
VW engines with cork valve cover gaskets and those shitty pushrod tubes.
Old 11-20-2017, 02:55 PM   #14
humfrz
Try this one:...........
REALLY! So, squeezing the oil out of that sand up in Canada, is just cleaning up the environment ......
After all, mother nature NEVER got sloppy ....... cepten at places like the la brea tar pits ........
humfrz
Oil Leak Brz_racer Engine, Exhaust, Transmission 22 07-17-2017 04:28 PM
Intake manifold leak Diz86x Engine, Exhaust, Transmission 5 07-13-2017 12:42 PM
oil leak ! frsqc Issues | Warranty | Recalls / TSB 5 07-01-2015 07:08 PM
Oil leak. ohnoitsthefuzz Issues | Warranty | Recalls / TSB 2 03-23-2015 01:31 AM
A/T Pan leak goke186 Issues | Warranty | Recalls / TSB 0 04-15-2013 10:31 PM
