Old 08-08-2018, 05:18 PM   #1
Totalrecall
Drives: frs
FRS/BRZ intake leak part?
What is this part called at the bottom? I've pinpointed intake lean causing a lean code.
The little thing that hangs from the intake pipe. Mine has a huge hole from rubbing on belt. And what is even the point of this cup thing, Its hollow
Totalrecall is offline   Reply With Quote
Old 08-08-2018, 05:55 PM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
Probably resonator. To cancel out certain noise frequencies. If it's simpler to you, you can close it off, just like soundtube port.
Old 08-08-2018, 06:00 PM   #3
jflogerzi
jflogerzi's Avatar
You could probably just cap it. Local hardware store should have it. Otherwise just get the Perrin inlet tube and do the sound delete.
Old 08-08-2018, 06:54 PM   #4
I think that one is important for the MAF
Old 08-08-2018, 09:53 PM   #5
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
That is indeed a resonator, but I believe it was used in some way to help the sound resonator tube that pumps the intake noise into the cabin. You can replace the whole intake tube rather than buying that OEM part as I was unable to find that specific part number looking at diagrams
Also doing so deletes the sound tube:
https://www.rallysportdirect.com/par...ake-hose-black
Or you can have this used OEM tube:
https://www.ebay.com/itm/O-13-16-SCI...item1a3c100bb1
I don't believe it's important to MAF, many CAI and other inlet tube manufacturers removed it and found it was simply for sound suppression. Also the TRD intake removes it entirely as well.
Old 08-08-2018, 11:04 PM   #6
After I posted, I second guessed all the people that were worried about the sound tube delete. :/
*gasp* "What if they were all...?" ... "Nah. No way!"
Old 08-08-2018, 11:49 PM   #7
FRSBRZGT86FAN
Well all I can say is I have the TRD intake installed which didn't do much but look cool, but I did cap off the sound tube as it came with the cap to remove it.
Old 08-09-2018, 04:41 AM   #8
Boomerang
86
Boomerang's Avatar
It's called the resonator.
FWIW just remove it and plug it.
Link below will show you before vs after HP if you remove;
https://cdn.mishimoto.com/media/prod...ringReport.pdf
Old 08-09-2018, 06:56 AM   #9
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
The resonator is used to tune the intake pulses. Mishimoto did some dyno testing with it, it generates about 3-5 HP depending on which air filter and intake hose used (also linked by @Boomerang above):
https://www.mishimoto.com/engineerin...nt-completion/
Either way the engine lost power without the resonator in every scenario.
Old 08-09-2018, 07:51 AM   #10
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
just get the Perrin silicone intake tube or a whole intake kit and replace that whole assembly.
guybo is offline   Reply With Quote
Old 08-09-2018, 12:19 PM   #11
I'm back to thinking it affects MAF operation. It also supports my years old argument that the sound tube was an afterthought.
Old 08-09-2018, 02:04 PM   #12
Totalrecall
Drives: frs
Thanks all for the info, I will end up just deleting it for now. Currently have the hole taped off with electrical tape. (Very temporary to troubleshoot lean code and confirm cause) .
Ill purchase whole intake part as suggested from ebay later on.
Oil leak under intake! snk828 Issues | Warranty | Recalls / TSB 26 03-22-2018 10:35 PM
Part Out! (Phantom ESC, OFT, OFH, TRD Intake, Catback, etc.) illmatic_frs Canada Classifieds 7 09-29-2017 12:31 PM
Intake manifold leak Diz86x Engine, Exhaust, Transmission 5 07-13-2017 12:42 PM
SNJ Part Out: Aem Intake ; Boral, j2 , perrin jwjknorr Engine, Exhaust, Bolt-Ons 39 06-06-2014 05:45 PM
Intake canister part number? utekineir Engine, Exhaust, Transmission 5 09-10-2013 01:42 PM
