Old 07-31-2018, 06:15 PM   #15
Originally Posted by ermax View Post
There is actually sound deadening material around the pump from the factory. I doubt adding more is going to hurt.
Unless rodents crawl up there and say "Oh already furnished"
Old 07-31-2018, 09:07 PM   #16
I was thinking more of a putty like substance that you could pack around the pump...
Old 07-31-2018, 09:11 PM   #17
Ah I see.
Actually I think they have dug up some of your early works with clay.
humfrz (07-31-2018)
Old 08-01-2018, 12:09 AM   #18
Impureclient
Drives: 2015 FR-S
http://courseweb.stthomas.edu/apthom...atingDough.htm
The Following User Says Thank You to Impureclient For This Useful Post:
humfrz (08-01-2018)
Old 08-01-2018, 03:23 AM   #19
jflogerzi
jflogerzi's Avatar
Originally Posted by EddieZ2 View Post
They dropped the octane around my parts. I can get only 91 octane pure gas. First fill up and it was "Hello crickets." I grabbed some Lucas and added it to the next fill up. Did the trick. Lucas does wonders with the crickets !
Gonna try this myself. I have the crickets with my new to me 2013 FRS. 58K on the ODO. for 8$ its worth a shot. When you mix in on fill up do you do 1 ounce at the haft way point of fill yup and top of the rest after tank is 100% full. Or is better to put in amount before fill up and then tank?
Old 08-01-2018, 09:25 PM   #20
gravitylover
When I used to have to use a lead additive in my old Willys I put a bit in before I started pumping then the rest about halfway through. I wanted to make sure it was well mixed. With this car because it's a saddle tank I'd want to do the same or put it all in at the start.
Clicking / tapping sound + fuel pump noise + clutch grinding Mikeez Issues | Warranty | Recalls / TSB 11 04-26-2015 11:19 PM
Sound shield over fuel pump? Pacific Auto Engine, Exhaust, Transmission 1 08-20-2013 04:27 AM
2013 FRS fuel pump sound MosesFRS Issues | Warranty | Recalls / TSB 9 02-23-2013 09:01 AM
Hood sound dampener Brimford Cosmetic Modification (Interior/Exterior/Lighting) 4 01-17-2013 08:00 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
