Old 07-31-2018, 11:53 AM   #1
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Metallic Scratching Noise On Start Up
Hi Folks!
Recently I've been hearing a metallic scratching noise upon cold start up. It doesn't always occur so it's very difficult to record the noise. Sometimes it will happen once every 3 days, and sometimes it will happen once every 3 months.
It doesn't seem to relate to temperature either. To describe the noise, I would have to say it's a sound of crumpling paper really quickly or someone shaking a bag of rocks with metal shavings. The noise only lasts for a split second and goes away quickly.
The only exhaust mod I have is a Perrin 3 Inch exhaust. Everything else is stock.
I'm going to check the following this weekend:
1) Exhaust Shields
2) Mounting Points/Connection Points of exhaust
3) Check Starter (to see if it's grinding on the fly wheel but I highly doubt it).
Anything else to check? Could it actually be the baffles inside my Perrin muffler has gone/loose? Ideas on how to check that?
Car is a 2013 Scion FR-S 10 Series. It has push button start. Automatic Transmission. 56k Miles.
N1rve
Old 07-31-2018, 12:33 PM   #2
Heat shield.
I went through a big puddle that moved one of my heat shields and it made exactly that sort of noise under the same conditions as you stated.
Before I could hunt it down I went through another big puddle that apparently fixed it.
Find a big puddle!
Old 07-31-2018, 03:51 PM   #3
Heat shield.
Find a big puddle!
Kind of hard in LA this time of year ..
spike021 (07-31-2018)
Old 07-31-2018, 03:54 PM   #4
Originally Posted by N1rve View Post
Hi Folks!
1) Exhaust Shields
N1rve, you must be low on things to worry about -
Old 07-31-2018, 04:04 PM   #5
N1rve
N1rve's Avatar
I just don't want my engine to blow up right after my powertrain warranty ends
N1rve
Old 07-31-2018, 04:05 PM   #6
OK
Find a shallow beach.
humfrz (07-31-2018), spike021 (07-31-2018)
Old 07-31-2018, 04:11 PM   #7
OK, go with @Tcoats plan - find a percolation pond and hit it fast and hard...
N1rve (07-31-2018), spike021 (07-31-2018)
"Scraping/Scratching" noise on acceleration? Berzerk Issues | Warranty | Recalls / TSB 18 09-30-2018 11:28 AM
Strange metallic vibration noise started dumbforcrumbs Issues | Warranty | Recalls / TSB 1 02-02-2017 08:28 PM
Metal on metal scratching noise front left wheel Ezk1el Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 08-11-2014 12:00 AM
Scratching noise from clutch when stopped jshadeck Issues | Warranty | Recalls / TSB 2 09-10-2013 12:37 PM
Strange noise at start up? Hanakuso Issues | Warranty | Recalls / TSB 0 06-12-2013 01:59 AM
