Old 06-15-2017, 01:11 PM   #1
Berzerk
Berzerk's Avatar
Drives: '17 CWP Limited BRZ w/PP
"Scraping/Scratching" noise on acceleration?
Hello all,
I recently purchased my '17 BRZ w/PP back in February. It has been a fantastic car so far and haven't had any issues. I'm at about the 3200 mile mark. Recently though, I am hearing a scraping/scratching noise whenever I accelerate. The sound only lasts for the brief moment that I put my foot on the gas. It does not happen on every single acceleration. It seems to be random as I couldn't replicate a pattern.
It's not super loud (not loud enough to get on video very well probably), but it is definitely audible if you're in the cabin. It does not sound like it's coming from the rear, but somewhere in the front. I can't tell whether it's something in the engine area, the suspension, or the brakes?
I have really been noticing it within the last month or so, but now I'm not sure if it has been happening for awhile and it is now just really getting my attention.
As I don't have much experience with this vehicle, is this a normal sound I don't need to worry about? I was planning on taking it into my dealership anyway since it's under warranty, but I'd love to hear thoughts first.
Thanks!
Berzerk is offline   Reply With Quote
Old 06-15-2017, 01:40 PM   #2
JD001
JD001's Avatar
Drives: Subaru BRZ
Why not?
Old 06-15-2017, 01:49 PM   #3
humfrz
Well, I don't think that sound is "normal" ..... at least either mine doesn't do it or I can't hear it ......
Maybe if the dealer gets it up on a lift, they can spot something that is lose ....
humfrz
Old 06-15-2017, 02:06 PM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
If it's at a specific RPM/RPM range it most likely is a rattling heat shield.
Old 06-15-2017, 02:19 PM   #5
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
Is it possibly the sound generator tube?
I plugged mine right away because it gave a raspy sound in the cabin on initial acceleration, which I suppose could sound similar to a scraping noise.
wolffbite is offline   Reply With Quote
Old 06-15-2017, 03:18 PM   #6
infinitewhiskey
Drives: 2016 Oceanic FR-S
Could also be the overpipe heat shield rubbing somewhere on the sway bar mount area.
infinitewhiskey is offline   Reply With Quote
Old 06-15-2017, 04:17 PM   #7
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
I had a bad heat-shield on my front-pipe. Noticed it right after the break-in period. Took me a long time to figure out what the hell it was, but it was fixed under warranty. It sounded more like a grinding/ metallic scrapping noise and only heard it under acceleration. I would start by check all your heat-shields and go from there.
DaBoBo21 is offline   Reply With Quote
Old 06-15-2017, 05:43 PM   #8
cat94
Drives: '17 86
Is heat shield rattling a concern that should be fixed? At 3.5-4.5k rpm I get a buzzing that sounds like it's coming from the dash area. I've tried to ignore it but I hear it every time =\
cat94 is offline   Reply With Quote
Old 06-16-2017, 10:47 AM   #9
Berzerk
Berzerk's Avatar
Your description sounds exactly like what I'm hearing, a grinding/metallic scraping noise under acceleration. Did it happen during the whole acceleration? Or just at the beginning as soon as the pedal is pressed down? For example, I start accelerating and the noise happens initially, but is not constant throughout the rest of the acceleration.
I will definitely check the heat shields and front pipe and then report back.
Thank you everyone for the info!
Old 06-16-2017, 11:13 AM   #10
Icecreamtruk
Drives: Track preped NA FRS
Noises that arent constant are usually an indication that something is vibrating and certain ranges of RPM makes it vibrate more and resonate. It totally seems like you have something loose or touching some of the shielding underneath the car. Get under it and take a loot at it, there might be visual damage to a shield (like hitting a rock or something) and it might be easier to spot. Otherwise, maybe put a gopro under the car while driving to see if you can film where the vibration is coming from. Or ignore, its just another noise the car makes, its not like its a silent car.
Edit: also, your username and your profile pic are so conflicting! lol
Old 06-17-2017, 01:58 AM   #11
UH60CE
Drives: 2017 Halo 86
I have this issue as well. Brand new 2017 Toyota 86 not even at 1500 miles yet and I recently noticed when I step on gas pedal a little harder than usual or sudden throttle acceleration I hear a a short brief metallic scrape screech click grind what ever you call it. So what could this be guys? I broke in my car the 1000 miles properly never even revved over 3500 rpm. Never scraped or bottomed out the car either. Put the car on a lift the other week just to inspect the underbody and everything is flawless no sign of any defect or anything. Car is a manual so maybe the sound generator rubs in the aluminum intake manifold when you step on gas cause you know how the engine moves when you give it some gas but it doesn't do that screech sound when in neutral and parked. I'm curious to see where this short little scrape sounds is coming from
UH60CE is offline   Reply With Quote
Old 06-17-2017, 03:03 AM   #12
JD001
JD001's Avatar
Drives: Subaru BRZ
About 2 months into the ownership of my BRZee I started to note a funny high pitch screeching/swirly sound. It kinda sounded like something metallic spinning (much like an angle grinder but really faint) but it would only happen intermittently.
As my ear become more attuned to the noise and after reading various posts about unusual noises, it boiled down to our friends the "crickets". Taking the car into dealer first week of July for a service and check on the "crickets".
Old 06-18-2017, 08:40 PM   #13
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
I'm sorry for the late response! Yes, exactly what you said is what I experienced. Once I got up to speed and the engine/ trans settled out all was good. I would take it to the dealership and have them check all of your heat shields. I hope it works out for you!
Old 09-27-2018, 10:05 AM   #14
8inchAzN
Drives: Car
Do you have an update on this? I am experiencing the exact same issue. 17 Manual BRZ 30k miles.
8inchAzN is offline   Reply With Quote
Brief "chirp" sound on acceleration nastynate88 Issues | Warranty | Recalls / TSB 17 04-05-2017 06:59 PM
BRZ 6AT - "click" on hard acceleration cpnslow Issues | Warranty | Recalls / TSB 6 10-07-2014 11:35 PM
Switching back to 17" Wheels from 18" for acceleration feel? bobsacamenoh Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 08-30-2014 07:35 PM
"Buzzing" From behind the steering wheel under hard acceleration husker741 Issues | Warranty | Recalls / TSB 13 06-30-2013 01:18 PM
Steering wheel/dash "rattle?" upon heavy acceleration? brett_g Issues | Warranty | Recalls / TSB 2 08-04-2012 04:52 AM
