Old 06-25-2018, 01:23 PM   #99
jamal
jamal's Avatar
Drives: Legacy GT
Originally Posted by Turbo86 View Post
So are the performance package calipers the exact same as the STI calipers? If it takes the same size pads and rotors, and looks the same from the outside, is it pretty much the same thing?
The STI brembos have a pair of 40mm pistons and 46mm pistons. The smaller pistons are what the rotor "sees" first as there is a slight force wedging the pads together. Except that the sti mounts the calipers on the back of the upright and the brz has them on the front. So to keep the bleed screws and internal passages in the right place you would have to swap them from left to right, which puts the pistons in the wrong order.
My understanding is that the BRZ PP calipers have 40mm pistons and no differential bores. The subaru 4-pots and stock brakes have all the same sized pistons and it's not the end of the world but it would have been nice if they'd done 40/42 or something.
So the total piston area is smaller to maintain correct bias with the bigger rotors (sti brakes move it forward), and the smaller area also results in a firmer brake pedal. The sti calipers meanwhile have more piston area and a bigger rotor and they don't work on the brz.
jamal is offline
Old 07-12-2018, 02:40 PM   #100
C1Y3R
Drives: 2018 Subaru BRZ ts
I'm bumping this for more contribuions. If anyone has any experience with Enkei nt03 or rs05rr fitments I'd greatly appreciate it!
C1Y3R is offline
Old 07-12-2018, 11:05 PM   #101
babykwiss
Drives: Scion FRS
i have 18x9.5 +40 Rays 57c6. You will need at least a 5mm spacer to clear stock Brembos on PP package.
babykwiss is offline
Old 07-12-2018, 11:46 PM   #102
mixxxx
mixxxx's Avatar
OZ Ultraleggera 17x8+48
Plenty of clearance
Edited for correct offset
mixxxx is offline
Old 07-13-2018, 06:33 PM   #103
Ryan GT86
Ryan GT86's Avatar
Drives: 2019 Toyota 86
Does anyone know if the Enkei TD5 will fit? Its a 17x8 wheel with a 45 mm offset.
Is there a list of Enkei wheels confirmed to fit?
Ryan GT86 is offline
Old 10-10-2018, 12:28 PM   #104
FremontSubaru
FremontSubaru's Avatar
Drives: 2018 BRZ P/P
According to Konig, the 17x9 +40 will not fit the pp brembos. this is very unfortunate for STX autocrossers
I loved this option since it was cheap, lightweight, and came in black!
Probably have to go with Wedssports.. anyone know the clearance on the Rota Titans 17x9 +35?
FremontSubaru is offline
Old 11-04-2018, 11:50 AM   #105
Chuckls
Moutain Runner
17x8+35 Avid Av20s fit!
Chuckls is offline
The Following 3 Users Say Thank You to Chuckls For This Useful Post:
J1Avs (12-12-2018), JonAvalon (04-03-2019), Teseo (10-22-2021)
Old 11-04-2018, 07:10 PM   #106
cjd
cjd's Avatar
Drives: 2017 BRZ
Only a little heavier than the TC105n and a lot nicer on the bank balance, the 949 6UL in 17x9 fit quite nicely. I didn't think Titans were +35 either (can't speak to whether they fit).
cjd is offline
Old 12-06-2018, 12:05 PM   #107
itsovr9k
Drives: AP1 S2000, 2021 CTR
I haven't seen this asked yet. Any idea if the 17x7 +42 RPF1s would clear PP Brembo's?
itsovr9k is offline
Old 12-12-2018, 05:35 PM   #108
azndave1
azndave1's Avatar
Drives: none
Confirmed that Gram Lights 57 xtreme 18x9.5 +40 5x100 fits on PP with 1 finger gap, but will need coilovers.
https://ibb.co/P9TGR3n
https://ibb.co/7gg2Jbj
azndave1 is offline
Old 01-09-2019, 12:55 PM   #109
brandon525
Drives: 2014 frs (someday)
Originally Posted by 007BRZ View Post
These are the HAWK CERAMICS that fit the Performance Brembos on my 2017 Yellow BRZ
Enkei RaiJins 18X8.5/9.5 +45
245/35 18 Michelein PSS
I LOVE these pads, very little dust, Great stopping power for the street. Rotors smooth as glass.
Had Hawk Ceramics on my 2013 BRZ Limited for 52,000 miles and they were half way worn.
Those are 2011 STI center caps, had polycarbonate spacer rings made in Hungry for $5. shop here wanted
$180. The lugs are from FT-86 SpeedFactory.....the frosting on the cake!
Do you have at least a finger width in between the caliper and spoke? If so I think I'll run it.
Sent from my Moto G (5) Plus using Tapatalk
brandon525 is offline
Old 04-03-2019, 01:19 PM   #110
RWDWeekend
RWDWeekend's Avatar
Drives: 2017 Subaru BRZ PP
So FT86 confirmed Ambit RE-02 fitment on the PP, but I found the Ambit RE-02s for sale online with a disclaimer that they would *not* clear a BBK. Anyone have any idea why? They were the same size listed here, 17x9+35. Maybe a vendor just trying to play it safe?
RWDWeekend is offline
Old 04-23-2019, 08:49 PM   #111
le_p
Drives: 86 GTS
Can someone confirm whether the SSR GTX01 18x8.5 +44 clears the Brembos, please?
le_p is offline
Old 05-14-2019, 09:38 PM   #112
livingasleep
Drives: 2018 Subaru BRZ Sport-Tech RS
Searched the whole thread for this, no results.
Anyone know if the Rays Gram Lights 57CR in 18x9.5 fit at some offset (hoping for +38)?
Trying to buy some wheels and one shop said these "should" fit but rather see pics before purchasing!
livingasleep is offline
2017 BRZ Performance Package Brembo Brakes Part Numbers Veloist Suspension | Chassis | Brakes -- Sponsored by 949 Racing 146 04-27-2023 09:36 AM
Real STI BREMBO package upgrade - DIY Trap63 DIY (Do-It-Yourself) Guides 40 06-15-2022 09:25 PM
Will The Brembo BBK of the Performance Package BRZ fit into the wheels of Series Blue DaJo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 09-25-2018 05:12 PM
To get the Performance Package or Not? Thread Zaku BRZ First-Gen (2012+) — General Topics 141 12-06-2016 10:04 PM
Someone tested the Performance Package... small but SOME info at least ~el~jefe~ BRZ First-Gen (2012+) — General Topics 13 11-29-2016 04:21 PM
