Old 03-18-2017, 03:07 AM   #1
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Will The Brembo BBK of the Performance Package BRZ fit into the wheels of Series Blue
As the title states... I'm wondering if the BBK from the '17 Performance Package BRZ will fit into the BRZ STI wheels from the Series Blue. 17x7 5x100 +48... I have a feeling the offsets may be different but I need someone who can actually confirm it.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 03-19-2017, 11:18 AM   #2
mjanmohammad
Drives: Boosted 2017 BRZ PP. GT2860RS, JDL.
Nope they won't, you'll need a spacer to run them
mjanmohammad is offline   Reply With Quote
Old 03-20-2017, 03:44 AM   #3
DaJo
FT86Club Vancouver
DaJo's Avatar
I kinda had a feeling... Do you know how many mm spacers?
Thanks!
2000 MR-S 5MT
2010-2012
Old 03-20-2017, 11:15 PM   #4
mjanmohammad
Thanks!
That I don't know, I just tried to fit a friends STI wheels and they didn't fit I didn't want to run spacers so I didn't bother to check.
Old 03-20-2017, 11:31 PM   #5
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
They won't clear, that's why the STI JDM site mandates 18" x 7.5J for the optional Brembos.
krayzie is offline   Reply With Quote
Old 03-22-2017, 12:51 AM   #6
DaJo
FT86Club Vancouver
DaJo's Avatar
True for the tS... But not for the 2017 BRZ Performance Package in North America... The wheels for the new 2017 BRZ PP are 17x7.5 with the same offset (+48) as the 2013+ stockies.
All the numbers look the same but the width of the wheels which are 0.5 wider than the ones I've got, so I was just curious if that is the deal breaker for the BBKs.
2000 MR-S 5MT
2010-2012
Old 03-22-2017, 07:17 AM   #7
krayzie
Drive From Home
krayzie's Avatar
I stand corrected.
Interesting cuz back when they only made 7.5J for both 17" and 18", STI recommended 18" for the Brembos.
Now they revised the website and states the following:
※ You can not set standard wheeled wheels. Replacement with Brembo Brakes Aluminum Wheel is required. Corresponding
STI aluminum wheel part no.
18 inch: ST28100MF250, ST28100MF260, ST28100MF270, ST28100MF280
17 inch: ST28100MF050, ST28100MF060, ST28100MF080
* BRZ tS standard component
Item No.: ST28100MF050 PT Silver 17 × 7.5J + 48 PCD100 5 hole
Product No .: ST28100MF060 Gunmetalic 17 × 7.5J + 48 PCD100 5 hole
Product No .: ST28100MF080 Black 17 × 7.5J + 48 PCD100 5 hole
http://www.sti.jp/parts/subarubrz_zc/brake/26100AS000/
http://www.sti.jp/parts/subarubrz_zc.../ST28100MF050/
Dam that means I can get the Brembo option and my ST28100MF060 rims will fit!
Old 03-22-2017, 02:03 PM   #8
imnotsureaboutbrz
Drives: between cars...
I stand corrected.
Man those black wheels would look soooo nice, but I'm sure they are Expensive!!
imnotsureaboutbrz is offline   Reply With Quote
Old 03-22-2017, 02:13 PM   #9
krayzie
Drive From Home
krayzie's Avatar
The worst part is the shipping. FedEx + customs added up to be the same as another rim lol!
They are Enkei flow formed cast wheels Made in Japan.
Old 03-23-2017, 02:34 AM   #10
DaJo
FT86Club Vancouver
DaJo's Avatar
Gawd damn... Lol Stupid USDM 17x7... Why U no add 0.5 to the width!? xD
I have a feeling the tS Brembos are bigger than the Performance Package BRZ Brembos. Hmmm...
2000 MR-S 5MT
2010-2012
Old 03-23-2017, 02:47 AM   #11
krayzie
Drive From Home
krayzie's Avatar
The link I've provided is for the tS standard Brembo brakes and it's clearly saying on the fine print that you need 17" x 7.5J.
Old 03-23-2017, 06:10 AM   #12
DaJo
FT86Club Vancouver
DaJo's Avatar
Interesting! Sorry, I guess I missed that...
I wonder why they went ahead with the 18 inch wheels for tS then. Hmmm.
2000 MR-S 5MT
2010-2012
Old 03-23-2017, 07:59 AM   #13
spd
Drives: wrx, brz
If this is anything like the brembos on the WRX STI then it's not wheel diameter you're worried about, it's spoke clearance. The calipers are wider and won't clear depending upon spoke design. Wheel width and offset are irrelevant.
On those setups you'd need a 5mm spacer to clear with factory rims, not sure about the BRZ PP setup but I'd guess it's the same.
spd is offline   Reply With Quote
Old 03-24-2017, 07:10 AM   #14
WWFT86
Drives: 2017 BRZ Limited
Anyone know if the Brembo BBK will fit into a regular 2017 with non-PP wheel?
WWFT86 is offline   Reply With Quote
2017 BRZ Performance Package Brembo Brakes Part Numbers Veloist Suspension | Chassis | Brakes -- Sponsored by 949 Racing 146 04-27-2023 09:36 AM
Specs for BRZ Performance Package wheels? ~el~jefe~ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 34 04-17-2020 06:31 PM
WTB: OEM 2017 Performance package wheels mjanmohammad Want-To-Buy Requests 1 03-03-2017 02:35 PM
BRZ Blue.Series STI Wheels Wyattkb Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 01-03-2015 11:16 PM
FS: BRZ Blue Series wheels RogueBRZ Wheels and Tires 26 09-11-2014 05:29 PM
