Old 07-06-2018, 09:54 PM   #29
monkeybike
Drives: 86
Originally Posted by brandonblt2 View Post
And I remember there is a thread somewhere basically claiming that Mobil 1 is the same oil subaru sells from the dealership has Subaru Oil.
Subaru in Australia use Castrol Edge.
They don’t bother repackaging it now.
They sell it in the Castrol packaging with an OEM label.
monkeybike is offline   Reply With Quote
The Following User Says Thank You to monkeybike For This Useful Post:
Bonburner (07-10-2018)
Old 07-09-2018, 03:12 AM   #30
pinoy_dorifto
Tuloy po kayo!
Drives: 2019 Toyota 86 TRD SE
Have been using Mobil 1 with OEM oil filter since first oil change. Mostly DD, and a couple of track days. Stock except for catback, k&n drop in and Perrin tube. Great deal on a box of 6 quarts at Costco when its on sale.
I.G. @mytoy86
pinoy_dorifto is offline   Reply With Quote
Old 07-09-2018, 08:42 AM   #31
Tokay444
I've only put Mobil 1 synthetic advanced fuel economy or extend mileage in my car and I have 116k miles. Never had it really burning any oil and I usually do oil changes at 7,500 miles. I've also had no engine problems *knock on wood* And I remember there is a thread somewhere basically claiming that Mobil 1 is the same oil subaru sells from the dealership has Subaru Oil.
Toyota's factory fill is Mobil1. They just put their own sticker on the same plastic bottles. I can't comment on the Subaru oils.
Old 07-10-2018, 03:48 AM   #32
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Where did you read this?
Looking simply at the physical properties of all 0w20 Mobil 1 oils vs toyota's genuine motor oil, they are worlds different.
Yes, TGMO is manufactured by ExxonMobil .. but the oil looks quite different form mobil1 products.
TMGO:
Relative Density (at 15 C): 0.851
Flash Point [Method]: 219C (426F) [ASTM D-92]
Flammable Limits (Approximate volume % in air): LEL: 0.9 UEL: 7.0
Autoignition Temperature: N/D
Boiling Point / Range: > 316C (600F)
Vapor Density (Air = 1): > 2 at 101 kPa
Vapor Pressure: < 0.013 kPa (0.1 mm Hg) at 20 C
Evaporation Rate (n-butyl acetate = 1): N/D
pH: N/A
Log Pow (n-Octanol/Water Partition Coefficient): > 3.5
Solubility in Water: Negligible
Viscosity: 36.1 cSt (36.1 mm2/sec) at 40 C | 8.5 cSt (8.5 mm2/sec) at 100C
Pour Point: -27°C (-17°F)
Old 07-10-2018, 03:51 AM   #33
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Originally Posted by DandoX View Post
Toyota brand motor oil pretty much is mobil 1, look it up.
TMGO:
pH: N/A
The Following User Says Thank You to Bonburner For This Useful Post:
Spuds (07-11-2018)
Old 07-10-2018, 11:53 AM   #34
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
TMGO:
pH: N/A
I was told a couple years ago that Toyota Synthetic 0w20 oil was made by Mobil One. That was at the Toyota parts dept by a well seasoned sales rep. Granted maybe not the most reliable source but I knew the same mafacturer was involved. I imagine Toyota adds a a few of their own additives to make it smeowhat unique.
I'm not sure what your showing with all those values at the bottom. I need an analays from the same car with m1 and then wth Toyota brand so we can see what your talking about. The stats alone don't illustrate anything.
So yeah I expect some differences but how great is the question.
DandoX is offline   Reply With Quote
Old 07-10-2018, 02:39 PM   #35
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Yeah the sales rep knew that the manufacturer was MobilExxon, but just because the manufacturer makes something for a different company does not mean they are the same products.
Those are not stats, those are the physical properties provided on the TGMO's MSDS forms. You can compare them to all of the Mobil1 oils and they are Vastly different. Significant difference. Mobil1 oil is more similar to penzoil and castrol in terms of the physical properties.
If you knew some chemistry, organic chemistry, and physical chemistry, you would understand that having such a difference in the physical properties is evidence that the products are significantly different. This is coming from a MS in chemotherapeutic drug design and synthesis with a BS in chemistry and currently working on his PharmD. Yes different fields, but similar enough basic utilization of chemistry knowledge to understand the stark differences between the products.
Old 07-10-2018, 03:06 PM   #36
DandoX
Senior gif poster
DandoX's Avatar
Well thanks for sheding light on this Dr.
Could you please link to where I can compare the oils, I can't seem to find what site has the data to compare?
Are these properties from someone's used oil analasys or an analysis based on fresh oil?
I'm curious and want to see the differences.
Old 07-10-2018, 03:09 PM   #37
Leonardo
Country Boy 4 Life
Leonardo's Avatar
My dealership uses Mobile 1...
Is my car going to self destruct?
I LIKE TIRES!
Old 07-10-2018, 03:44 PM   #38
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Candidate Dr. to be correct. I don't want to falsely take a title.
Fresh oils. MSDS are required standardized documentation regarding chemical and physical properties, hazard control, waste directions, safety direction, etc.
For the Mobil1 Oils just look on their website, they list the physical properties → https://mobiloil.com/en/viscosity/0w-20
The TGMO 0W20 MSDS can be found online, see section 9 for physical and chemical properties.
https://physics.usc.edu/Undergraduat...0005160165.pdf
http://sgnauto.com/products/oil_and_...and_oem/toyota
And no, I don't think Mobil1 will do damage to your engines. I just don't use them as a preference.
DandoX (07-10-2018)
Old 07-11-2018, 08:21 AM   #39
bluesubie
Drives: 2004 Subaru Forester 2.5XT
https://www.bobistheoilguy.com/forum..._results_are_s
This is a bit old, but M1 was one of the first to reformulate with lower Ca and boosted Mg:
http://www.pqiamerica.com/June%202014/exmoM1.htm
bluesubie is offline   Reply With Quote
The Following User Says Thank You to bluesubie For This Useful Post:
DandoX (07-11-2018)
Old 07-11-2018, 08:51 AM   #40
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Only comparable numbers I was able to find from Mobil indicate Mobil 1 is actually better. Lower density, higher viscosity, higher flashpoint, nothing else I saw that was directly comparable unless I'm missing something. I don't have time to look closer, but figured I'd leave my interpretation of the data.
Old 07-11-2018, 09:48 AM   #41
bluesubie
But take a look at the differences in the metallic additive packs. I’ll take the higher boron and moly in the TGMO.
But are these differences enough to say that one oil is better than the other in an 86 over 100k or 200k miles? Probably not.
Old 07-11-2018, 09:57 AM   #42
Tokay444
I can't get TGMO in 0w40, so no thanks.
Mobil 1 0w-30 lab results max20s14 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 17 04-03-2018 06:08 PM
Mobil 1 0W-20 Brahsbrah Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 109 07-01-2014 09:29 PM
Mobil 1 Oil on Sale White64Goat Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 03-12-2014 11:21 AM
Why do the FRS/BRZ engines sound different from other Subaru's russv Scion FR-S / Toyota 86 GT86 General Forum 6 03-28-2013 05:30 PM
Subaru engines' weights Allch Chcar Other Vehicles & General Automotive Discussions 19 04-30-2011 12:10 AM
