Drives: 14' Raven M/T - 02' is300
Mobil 1 0w-30 lab results
Got my oil results back from blackstone labs. looks good. dunno why the viscosity is lower than its supposed to be. let me know what you guys think.
post up your results for this oil ect.. |
Drives: frs
Try 5w-30 next time, maybe?
Drives: MDX, Camry
0w-30 is 0 weight oil with additives (viscosity modifiers) to make it a 30 weight oil at 100C. I guess those additives' effectiveness diminished after 6k miles. It is like feeding steroids to a normal guy to be a sprinter. After running 6 months, the steroids wear off and he becomes a normal guy again. It would be interesting to see the results with other oils.
Drives: 2014 Subaru BRZ Limited 6MT SSM
I've read that Mobil 0W-40 is a little thin too. Maybe it's just a Mobil thing. I think I'll try PP 0W-40 next. It's apparently more true to its weight. I wouldn't be worried about your oil being a little thin for a 0W-30 though, it's a quality oil and as long as you aren't pushing it in extreme conditions, you should be just fine.
Drives: 15 Impreza
Senior gif poster
Drives: 2013 Asphalt FRS
I've been using Ow30 Mobil 1 oil for about 45k now and I'm happy with it so far (I'm at 75k total). No auto cross or track events just daily and spirited driving. Frequent short trips so I change my oil much sooner like around 3k-4k. Once it starts getting a lot darker I change it. That low viscosity is interesting. I'm really interested in what he results would be in a 0w40 test. Or the 0w30 test with like 4K miles and see if similar low viscosity still occurs the same with less beak down. I wonder if the oil starts breaking down after 4.2kish that's when I have noticed the color really start to change.
I may change to 0w40 if you get another oil test that shows improved results. Thanks for posting |
Mobil one 0w30 runs slightly thin with a 100c viscosity of only 10.9 cst when new. Compare that with something like Castrol Syntec 0w30 (aka German Castrol) which has a viscosity of 12.2 cst at 100c. Nothing to worry about though.
2022 BRZ Build 2013 FR-S Build |
Viscosity may be low, if you had 0W20 in there previously. An oil change doesnt exchange out 100% of the oil.
Thanks for posting your sample! |
Drives: 15 BRZ LTD, 05 FXT
Agree. If there's nothing to suspect a problem with the engine, the second oil change on a given oil sample is the one that matters most since it will give you a better idea of your engine with this oil.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
#10 |
Been using 0w-30 for the last 3 changes to answer some of you asking if I had switched.
#11 |
Drives: MDX, Camry
#12 |
Drives: Currently 2018 Taco
Fuel dilution.
Flash point near threshhold. Try 7500 mile OCI and retest, if concerned. Or stick with 6000 mile OCI. There is no notorious Mobil1 high iron results from this UOA. IMHO. You have found your sweet spot. Go with the flow. |
#13 |
Senior gif poster
I just got back my first used oil analysis. I've been running mobil 1 0w-30 for about 40,000 miles. My total mileage is 73,000. Comparing against unit/location averages things seem to look pretty good.
I'm no expert but if anyone with more knowledge can help me understand more about this readout it would be appreciated.
#14 | |
Proud of BOXER
Drives: Subaru Boxer
You added 5.7 quarts as top off? What does that mean in the notes?
| My Nameless header dyno results (results to follow) | Simply_the_best | Engine, Exhaust, Transmission | 39 | 06-28-2016 04:09 PM |
| Mobil 1 incl 0W40 $35 cash | wbradley | CANADA | 5 | 08-10-2015 11:15 AM |
| Mobil 1 full synthetic for e85? | Mr_YUzU_FRS | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 01-28-2015 09:02 PM |
| Mobil 1 0W-20 | Brahsbrah | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 109 | 07-01-2014 09:29 PM |
| Mobil 1 Oil on Sale | White64Goat | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 14 | 03-12-2014 11:21 AM |
