Old 03-14-2018, 10:19 PM   #1
WhiteChocolate
WhiteChocolate's Avatar
Drives: White like Chocolate
Bent Chassis
Last summer I was involved in accident that put my car out for a year, as I gathered parts to repair the car on my own. I was hit in the front passenger side of the car. So far I've replaced everything to do with the suspension components for that side including the steering rack (Inner and outer tie rods, control arms, new coilers, end link, etc.). After my alignment I was told I had an issue with my caster and it looked like I had body damage. I got under my car to take a look at the damage.
I've attached some images that I took while I was under the car to compare my passenger and driver side. These were the only spots I could tell there was a difference. I also provided a diagram of the chassis to show where I took a picture. Can anyone let me know if this is fixable and if it is what could be the rough cost of what it would be to pull it back to spec? I currently have issues with the wheel hitting the back of the wheel well at full lock to my passenger side.
WhiteChocolate is offline   Reply With Quote
Old 03-14-2018, 10:52 PM   #2
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Did you replace the front subframe? Sounds like the mounting points for the lower control arm are bent out of place.
ineedyourdiddly
Old 03-14-2018, 11:20 PM   #3
WhiteChocolate
Even with the frame slightly bent like that? Replacing the front subframe would fix this?
Old 03-15-2018, 09:41 AM   #4
strat61caster
It's a total shot in the dark.
Usually pieces like control arms and sub frames are meant to bend before the chassis because they are cheaper to replace. I have no idea how what you show would influence the cars alignment, but if you have not touched the subframe you absolutely should investigate that.
ineedyourdiddly
Old 03-15-2018, 10:20 AM   #5
Looking for obvious damage is only part of the process. You need to make sure that all your dimensions are correct even if there is nothing to see. The attached (Thanks to Ultramaroon) has all the measurements and locations for you to properly assess the structure.
https://demos.starbase7.net/t3Portal..._cr_index.html
strat61caster (03-15-2018)
Old 03-15-2018, 12:14 PM   #6
wparsons
wparsons's Avatar
If the body is bent, you'll need to get it on a frame machine to be pulled back to spec.
flickr
The Following 4 Users Say Thank You to wparsons For This Useful Post:
churchx (03-15-2018), strat61caster (03-15-2018), Tcoat (03-15-2018), Turbo (06-14-2018)
Old 03-15-2018, 01:21 PM   #7
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Frame Straightening Table
Takes precision and a whopping great lot of hydraulics.
BlackJack
wparsons (03-15-2018)
Old 03-15-2018, 01:47 PM   #8
WhiteChocolate
Thank you for this, I'll use this today and investigate more
The Following User Says Thank You to WhiteChocolate For This Useful Post:
Tcoat (03-15-2018)
Old 03-15-2018, 01:50 PM   #9
As W said it will take a straightening machine to fix if off even by a little.
Old 03-15-2018, 02:15 PM   #10
churchx
churchx's Avatar
Drives: 2014 GT86
Then again straightening pictured in pic is way more thorough then what maybe needed imho. Probably slight pulling of front will move things into place, i doubt main body and rear to also needing straightening. But shop should tell after measuring reference points/distances.
Old 06-12-2018, 03:35 PM   #11
WhiteChocolate
Finally an update on this:
Was able to get the frame straightened out. I'm still having issues with the passenger wheel hitting the rear side of the wheel well. Also when I drive there is a small hop coming from the passenger front as well. I'm thinking maybe the wheel hub somehow got tweaked very slightly
Old 06-12-2018, 03:43 PM   #12
evomike
Drives: frs
this honestly sounds like a situation where you should have dropped your car off at a shop and had it fixed, did you put a claim in to your insruance?
evomike is offline   Reply With Quote
The Following 2 Users Say Thank You to evomike For This Useful Post:
Stang70Fastback (06-12-2018), wparsons (06-12-2018)
Old 06-12-2018, 04:20 PM   #13
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
This is what insurance is for...!
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 06-13-2018, 12:10 AM   #14
WhiteChocolate
I was thinking about doing that, but I wanted to make this a learning process for myself as well. Just got the car all taken apart and it turns out the wheel hub is bent out of place
RPF1 Bent S84kam Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 08-07-2015 05:13 PM
NY: (1) Stock OEM Rim (bent) klittl06 Wheels and Tires 6 01-15-2015 06:56 PM
So I Bent a fender... Avid Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 13 09-07-2014 07:56 PM
Bent Rod Pics.. FullBlown Forced Induction 47 10-27-2013 08:02 PM
Bent Rim Sir Alex Mid-Atlantic 5 08-09-2013 03:34 PM
