Old 06-11-2018, 11:53 AM   #1
radroach
Drives: car
Fuel pump squeak sound dampener?
It's summer time and the crickets are out again. I'm curious if we'll ever have some kind of sound dampening device or material we can bolt on over the the squeaky fuel pump? Seems like that'd be a nice mod to have, if it worked right.
Old 06-11-2018, 01:42 PM   #2
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
yes, you can bolt on a louder exhaust
HKz is offline   Reply With Quote
The Following 2 Users Say Thank You to HKz For This Useful Post:
DandoX (06-11-2018), Sportsguy83 (07-31-2018)
Old 06-11-2018, 02:49 PM   #3
Old 06-11-2018, 02:56 PM   #4
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Embrace it and live in peace.
Old 06-11-2018, 03:31 PM   #5
Interesting idea.
I wonder if the HPFP gets hot (to the touch) or the fuel moving through it keeps it cool?
If it stays cool, maybe something liked this, molded over the pump, would deaden the sound?
http://www.greendepot.com/greendepot....1VOXc6SM.dpbs
Go radroach!
Old 06-11-2018, 03:39 PM   #6
radroach
Drives: car
Well maybe something like a sound dampening board would work:
I imagine you'd want to have it above and below the fuel pump as there would be some echoing from the ground below.
Old 06-11-2018, 06:21 PM   #7
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
check your local co-op to see if they have 100% gasoline.
thomasmryan is offline   Reply With Quote
Old 07-24-2018, 07:38 AM   #8
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
The problem with the 93~e10 available around where i live is that the proper lubricants aren't added to account for the e10. My crickets mostly go away by adding 1-2 ounces of lucas upper cylinder lubricant per full tank of gas.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
Old 07-24-2018, 09:10 AM   #9
JD001
JD001's Avatar
Drives: Subaru BRZ
The crickets will munch through the board..
Old 07-24-2018, 09:42 AM   #10
Grady
Grady's Avatar
There is a knob on the center dash. Turn it clockwise it fixes the issue everytime!
Old 07-27-2018, 12:01 PM   #11
EddieZ2
Drives: 2013 FRS
They dropped the octane around my parts. I can get only 91 octane pure gas. First fill up and it was "Hello crickets." I grabbed some Lucas and added it to the next fill up. Did the trick. Lucas does wonders with the crickets !
EddieZ2 is offline   Reply With Quote
The Following 2 Users Say Thank You to EddieZ2 For This Useful Post:
Ernest72 (07-27-2018), jflogerzi (08-01-2018)
Old 07-27-2018, 10:50 PM   #12
Impureclient
Drives: 2015 FR-S
Pretty sure I'm past or close to over a year now with the TSB fix and still no crickets. The last TSB that came out for that seemed like it was 50/50 on whether it went away.
Old 07-31-2018, 05:04 PM   #13
Interesting idea.
Go radroach!
I'm still curious about this possibility - any comments?
Old 07-31-2018, 06:03 PM   #14
ermax
ermax's Avatar
There is actually sound deadening material around the pump from the factory. I doubt adding more is going to hurt.
The Following User Says Thank You to ermax For This Useful Post:
humfrz (07-31-2018)
Clicking / tapping sound + fuel pump noise + clutch grinding Mikeez Issues | Warranty | Recalls / TSB 11 04-27-2015 12:19 AM
Sound shield over fuel pump? Pacific Auto Engine, Exhaust, Transmission 1 08-20-2013 05:27 AM
2013 FRS fuel pump sound MosesFRS Issues | Warranty | Recalls / TSB 9 02-23-2013 10:01 AM
Hood sound dampener Brimford Cosmetic Modification (Interior/Exterior/Lighting) 4 01-17-2013 09:00 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 05:53 PM
