Old 06-09-2018, 02:45 AM   #1
Kevyn
Drives: Scion FRS 2013
Radio, dome light, clock won’t work
So I recently put in a new motor into my car and check to make sure everything is plugged in now my radio is not working the time is not showing and some light now working now I search alll the fuses to new one stil didn’t work and I checked the fuse slot to see if they were getting power and they were now what could it be tbh.
Kevyn is offline   Reply With Quote
Old 06-09-2018, 11:41 AM   #2
Did you check both sets of fuses? The ones under the dash and the ones in the engine bay?
FRSBRZGT86FAN (06-10-2018), humfrz (06-09-2018), soundman98 (06-04-2021)
Old 06-10-2018, 02:17 AM   #3
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Judging by your recent engine swap, make sure your wiring harness is properly installed and grounded for both the interior and exterior fuse blocks.
The Radio and clock are both fuse protected by the same fuses on the engine bay box and interior box:
On the engine bay fuse box it's fuse 49 which is also dome light and needs to be replaced with a 20 amp fuse:
It can also be the interior illumination fuse on the inside fuse box:
That'll be fuse 3, which is 10 amps, and fuse 17 and 21 which are 7.5 amps
The Following 2 Users Say Thank You to FRSBRZGT86FAN For This Useful Post:
humfrz (06-10-2018), Ultramaroon (06-10-2018)
Old 06-10-2018, 03:18 AM   #4
Kevyn
Sorry for taking a while to respond but I’m check tomorrow and see what happens thank you I’ll keep you guys updated
Old 06-10-2018, 03:19 AM   #5
Kevyn
Yes I swapped all the fuses for new one so maybe just a faulty fuse maybe idk
Old 06-10-2018, 02:53 PM   #6
OP, for you and others that find this thread, and for as long as the website remains active, First Gen. Electrical Wiring Diagram.
FRSBRZGT86FAN (06-10-2018), humfrz (06-10-2018)
Old 06-10-2018, 04:30 PM   #7
So, does stuff work now ??
you didn't need to swap ALL the fuses, just the one(s) that were blown.
(Bubba learnt me that)
Old 06-04-2021, 12:53 PM   #8
Drafter
Drives: 2017 Brz
Love this forum. Thanks for all the info! Fixed my issue easy.
Drafter is offline   Reply With Quote
The Following User Says Thank You to Drafter For This Useful Post:
Underglow/footwell light controlled by door without using dome light or door switch pcguru2000 DIY (Do-It-Yourself) Guides 5 06-17-2018 11:09 AM
Map/Dome Light Dis-assembly/Phastek Performance LED Dome Light F1point4 DIY (Do-It-Yourself) Guides 9 03-25-2014 09:39 PM
OEM Dome Light Bulb? ScionFR-S Interior Parts (Incl. Lighting) 4 12-09-2013 11:33 AM
Replace Dome Light Zoomryder Cosmetic Modification (Interior/Exterior/Lighting) 6 04-09-2013 05:54 PM
