Old 06-01-2018, 01:07 PM   #1
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
Off-throttle vibration and steering noise
Hello,
I've had a couple of recurring noises on my car which I'd like to get rid of, or at least identify more specifically.
#1 is a vibration felt off throttle, as the engine goes from about 2.5 to 2k. It seems to be coming from the drivetrain and makes the engine feel rough. It's most present in 3rd gear, but can also be felt in 4th / 5th (car is a manual, btw).
#2 is a "clonk" type of noise heard when turning the wheel at low speeds / high steering angles. I'm not 100% sure it's coming from outside the cabin, but that would be my guess. I had attributed it to my 18" / 225 tires touching something in the wheel well, but after switching back to the stock tires / wheels, it remains present. It's heard a couple of times as I go from straight on to full lock.
Do you any ideas where these might be coming from?
Alex
alex87f is offline   Reply With Quote
Old 06-01-2018, 09:06 PM   #2
Originally Posted by alex87f View Post
Hello,
Alex
Hello alex87f ……..
Well, the description of those sounds could be caused a several hundred things.
Can you give us anything else to go on (like a video)?
Old 06-19-2018, 02:29 PM   #3
alex87f
Meow
alex87f's Avatar
Hello alex87f ……..
I don't think either noise is present enough to be heard on a video..
Regarding the engine noise, it is just some off-throttle vibration at low RPMs and what I was hoping for was to know whether or not it was a common thing with 86's.
The steering noise is definitely something I don't think is normal, but it's quite faint so as I said I don't think it'd be audible on video. For what it's worth, here's what I've been able to document on it:
-It only happens when the car is moving at slow speeds. When turning the wheels standing still, it's gone (which is weird )
-It happens both when turning left & right
I've tried tightening the strut-to-firewall bars a little bit as an older thread I found mentioned this as a potential cause, but it doesn't seem to make a difference.
Old 06-19-2018, 06:41 PM   #4
highway7
Drives: FRS 2013
#1 seems normal
#2 I had this problem, I took out the brake pads and cleaned the old brake grease and relubed the pads. For me it was the pads sticking and getting unstuck as the wheel turns instead of sliding properly.
highway7 is offline   Reply With Quote
Old 06-19-2018, 07:00 PM   #5
alex87f
Meow
alex87f's Avatar
Hmmm that's certainly an interesting possibility. My brake disks were OK last time Toyota checked but had a lip on the outer edge that caused quite a bit of squealing & rubbing. They took out all the pads and chamfered & greased them, but it was a while ago and the squealing is coming back. The brakes seems a possible culprit..
noise, throttle, vibration
FRS steering wheel vibration. snk828 Issues | Warranty | Recalls / TSB 36 07-07-2019 08:20 PM
Diff vibration/noise on decel Im_SPEED Engine, Exhaust, Transmission 9 01-28-2017 10:18 PM
trd quick shifter ? vibration noise Pcharliep04 Issues | Warranty | Recalls / TSB 5 08-01-2014 03:42 PM
Vibration/Noise near instrument cluster? nktech Scion FR-S / Toyota 86 GT86 General Forum 11 03-28-2014 09:42 AM
Vibration/Noise when clutch is depressed Ravenlokk Issues | Warranty | Recalls / TSB 17 12-02-2013 11:15 AM
