Old 05-10-2018, 12:03 PM   #29
Hot-Lava_Dave
Hot-Lava_Dave's Avatar
Drives: 2016 Hot Lava MT
It sounds like something is broken/loose. I can't stand when things squeak or rattle and have the urge to fix it as soon as possible.
Fair enough about sounding like something is off! You must need a louder exhaust to cover it up. I only really notice it in drivethroughs now.
Hot-Lava_Dave is offline   Reply With Quote
The Following User Says Thank You to Hot-Lava_Dave For This Useful Post:
funwheeldrive (05-10-2018)
Old 05-10-2018, 12:04 PM   #30
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Originally Posted by PhyrraM View Post
So far my '17 is rattle free @ 20K miles.
Enjoy that while it lasts
smg1138 is offline   Reply With Quote
The Following User Says Thank You to smg1138 For This Useful Post:
Old 05-10-2018, 12:28 PM   #31
Jordanwolf
Rice King
Jordanwolf's Avatar
This.
My car has developed a rattle in 2nd, 4th and 6th gear.... -_-
Glorious Honda.
Jordanwolf is offline   Reply With Quote
Old 05-10-2018, 04:08 PM   #32
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
Originally Posted by Jordanwolf View Post
This.
No rattles here, just a hi-frequency buzz left front dash on the highway. ALmost sounds like its coming from the speaker.
PetrolioBenzina is offline   Reply With Quote
Old 05-10-2018, 04:15 PM   #33
Jordanwolf
Rice King
Jordanwolf's Avatar
Perhaps my specific car is of the defective sort then. It came with a rattle that sounded serious to me, and had the dealership stumped. I'm going to bring it in again, because if this is it progressing from the same issue, then that would be very depressing.
Glorious Honda.
Old 05-11-2018, 08:16 AM   #34
DefMunkie
Drives: 2017 86
Originally Posted by extrashaky View Post
It's not ticking. This engine sounds like a sewing machine, but that's not the crickets. The crickets are the high-pitched chirping you could hear in that video. With the hood closed, it often sounds exactly like crickets.
Once I stopped at a gas station in rural Louisiana for some coffee. While I was inside the store, I heard what sounded like my engine chirping and had a moment of panic thinking someone had started up my car outside. But no, it wasn't my car. There was a cage of bait crickets in the store for the fishermen.
No amount of valve adjustment will fix the chirping, because it's not valves. It's the high pressure fuel pump. This car is not the only car that has the issue. Some other cars with HPFPs also chirp.
Lol, I haven't experienced that sound yet then.
So the chirping sound is generated from the fuel pump itself?
DefMunkie is offline   Reply With Quote
Old 05-11-2018, 12:05 PM   #35
RayRay88
Drives: 2017 86 860 Special Edition
This.
Just to rule it out... is this your first manual car?
RayRay88 is offline   Reply With Quote
Old 05-11-2018, 12:41 PM   #36
Jordanwolf
Rice King
Jordanwolf's Avatar
It is.
If only you could sit in my car and see that how I drive, I think at least, isn't the issue. I'm also not a self taught manual.
It's a sound coming from the gear stick when accelerating after a certain rpm.
The other rattle I had mentioned as well came with the car, but isn't in the same location.
Glorious Honda.
Old 05-11-2018, 12:59 PM   #37
StraightOuttaCanadaEh
Wes
It is.
Mine rattles too, can't remember if it's in the same gears. But I lifted up the reverse lockout a bit while it was rattling and it stopped. So I figure maybe it just needs to be raised a bit, or maybe cushioned
Instagram: @gt86ws
Old 05-11-2018, 02:02 PM   #38
Embrace the crickets! I know I have....
The Following 4 Users Say Thank You to Dadhawk For This Useful Post:
extrashaky (05-11-2018), funwheeldrive (05-11-2018), HachiRokuX (05-16-2018), Jordanwolf (05-11-2018)
Old 05-11-2018, 02:22 PM   #39
Jordanwolf
Rice King
Jordanwolf's Avatar
Idunno. I tried taking the gear stick trim off already and moving it around to see if there was anything loose, but no luck. Really hoping this isn't a big issue.
Glorious Honda.
Old 05-11-2018, 02:30 PM   #40
extrashaky
Drives: 2014 BRZ Limited
Yep. They keep issuing new revisions of the pump. It keeps chirping. Maybe the latest iteration has fixed it. I don't know.
At one point Toyota was experimenting with putting insulation all around it so you couldn't hear it. A member here on this board was one of the test cases and had the foam installed at the dealer. It actually chirped louder. Apparently the insulation was holding heat in and making the sound worse.
Other manufacturers have solved the problem with sound deadening insulation, but they designed it that way from the beginning.
The Following User Says Thank You to extrashaky For This Useful Post:
Tcoat (05-11-2018)
Old 05-11-2018, 02:54 PM   #41
extrashaky
Originally Posted by Hot-Lava_Dave View Post
Honestly, I never understood why this bothers most owners. I just consider it a quirk of the car.
It bothers people because it sounds a lot like belt and pulley issues on older cars. I've heard older '80s and '90s vehicles make sounds almost identical to ours. When they do it, it usually means something bad.
Who wants a new car that sounds like an '80s beater? And to add insult to the injury, unlike our cars you can actually fix the '80s beater and make that sound go away.
The Following 2 Users Say Thank You to extrashaky For This Useful Post:
funwheeldrive (05-11-2018), Tcoat (05-11-2018)
Old 05-11-2018, 03:23 PM   #42
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
There's a belt that seems a little whiny, but no crickets on my 2017 AT 86. It's pretty much gotten 93 from Speedway its whole life.
Nevermore is offline   Reply With Quote
Here we go again! BRZ vs FR-S Crickets! PNW-BRZ Issues | Warranty | Recalls / TSB 47 07-20-2019 06:31 PM
FRS / BRZ Crickets Fix Urmyson Engine, Exhaust, Transmission 11 07-12-2016 06:08 PM
Crickets Wilfred86 Southern California 4 06-16-2016 04:05 PM
The crickets... RojerLockless Issues | Warranty | Recalls / TSB 67 02-10-2014 03:20 AM
Crickets After TSB... boredom.is.me Issues | Warranty | Recalls / TSB 9 01-06-2013 12:29 AM
