Old 05-05-2018, 02:22 PM   #1
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
Got the crickets. Any other 17 MT's?
Seems to be intermittent so far. This is the first tank of E85 this year, so maybe I can attribute the crickets to that. It has always had just a hint of the noise every now and then, but it is obvious now.
Should I take it to the dealer and burn it in the lot as protest? Should I see how many pumps I can get the dealer to replace? Add a quart of engine oil to the gas?*
*The above paragraph is a joke.
Any other 17 MT's you know of with crickets? I don't remember reading about any here.
PetrolioBenzina is offline   Reply With Quote
Old 05-05-2018, 03:36 PM   #2
Impureclient
Drives: 2015 FR-S
It didn't seem to make a difference in the year of the car. The 13s were chirping as much as the 17s in the poll. I'm convinced it's all in the type of fuel used. I've run nothing but Chevron 93 in mine since the pump was replaced with the last TSB and still no crickets.
Impureclient is offline   Reply With Quote
Old 05-05-2018, 04:14 PM   #3
StraightOuttaCanadaEh
Wes
Mine started chirping within 3-5K km. Doesn't bother me though
Instagram: @gt86ws
Old 05-05-2018, 04:55 PM   #4
Brink
Drives: 2017 BRZ
'17 AT BRZ with crickets here. I've only ever run 91 Shell or Chevron in it, first noticed the crickets when I had been on Shell for a while but I'm now starting into my 3rd tank of Chevron in a row since noticing them and the crickets are still going strong.
Here's the fix for crickets:
https://www.cafepress.com/mf/7862987...tId=1184472861
Brink is offline   Reply With Quote
Old 05-05-2018, 05:12 PM   #5
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I noticed a little bit on shell 91. switched to petro 94/stinson 93 and no issues since.
Old 05-05-2018, 05:16 PM   #6
PetrolioBenzina
Drives: 17 86
I don't remember when my '13 got infested, but it's nice to know they still have not fixed the problem.
Old 05-05-2018, 05:18 PM   #7
PetrolioBenzina
Drives: 17 86
Chevron 92 for me as well, just switched to E85, loud crickets. Maybe they enjoy the corn 'licker and are having a party.
Old 05-05-2018, 05:19 PM   #8
Brink
Drives: 2017 BRZ
Nothing above 91 to be found out here.
Old 05-05-2018, 05:45 PM   #9
extrashaky
Drives: 2014 BRZ Limited
I haven't had crickets at all since I moved to Florida, so I'm even more convinced than ever that the crickets are caused by the fuel blend (winter/summer) and the additive packages. Since it's warm here throughout the year, our blends don't get as much butane as in colder climates.
When I lived in Texas and Louisiana, I'd get crickets on winter blends and on cheap gas from Sam's Club or Marathon stations. Sam's gas was the worst. I thought the fuel pump was going to jump out of the damned car and go hopping down the street on its own.
And before anybody says it, I'm almost certain that non-ethanol gas won't fix it. I tried it when it was the big bandwagon fix, and it made my crickets worse. I'm pretty sure it was because it was just shitty gas from mom and pop stations that was either cut down with a lot of octane substitutes or had really bad additive packages.
The Following User Says Thank You to extrashaky For This Useful Post:
Leonardo (05-07-2018)
Old 05-05-2018, 07:11 PM   #10
22R
22R
22R's Avatar
Drives: 2012 Camry SE 2017 Toyota 86
17 86 Auto only have used non ethanol 91 with 4400 miles and no crickets still.
22R
22R is offline   Reply With Quote
Old 05-06-2018, 07:20 AM   #11
WNDSRFR
Drives: FR-S,GTI
That's interesting. I'm in Florida and have never had crickets. I only use whatever 93 octane is cheapest. Usually Sunoco or Cumberland Farms. Neither of which are "top tier" fuels. So maybe it's the additives that cause it.
Old 05-07-2018, 02:24 PM   #12
mrderp
ಠ_ಠ
mrderp's Avatar
Drives: 860 SansOverspray
~4000 miles 17 MT 86.
Either 91 no ethanol or 94 ~10%. No crickets.
Also did ~3000 miles with the redesigned pump on the FR-S and the crickets never showed.
mrderp is offline   Reply With Quote
Old 05-07-2018, 06:45 PM   #13
RGlantz
Drives: 2016 Scion FRS
I add 2oz of 2 cycle engine oil if I start to hear the crickets. This seems to solve the problem for at least a couple of tanks of fuel. I read to do that somewhere else on this forum a while ago, though I'm not sure which post. But I've been doing that and have no problems. I pick up this stuff from walmart:
https://www.walmart.com/ip/Super-Tec...&wl13=&veh=sem
RGlantz is offline   Reply With Quote
Old 05-07-2018, 06:48 PM   #14
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I have heard them on and off on my 15 since new. Never bothered me, especially when the 100k Audi next to me at the light is doing the same thing.
Here we go again! BRZ vs FR-S Crickets! PNW-BRZ Issues | Warranty | Recalls / TSB 47 07-20-2019 05:31 PM
FRS / BRZ Crickets Fix Urmyson Engine, Exhaust, Transmission 11 07-12-2016 05:08 PM
Crickets Wilfred86 Southern California 4 06-16-2016 03:05 PM
The crickets... RojerLockless Issues | Warranty | Recalls / TSB 67 02-10-2014 02:20 AM
Crickets After TSB... boredom.is.me Issues | Warranty | Recalls / TSB 9 01-05-2013 11:29 PM
