Old 05-09-2018, 09:08 PM   #1
jayliu.jiayu@gamil.com
jayliu.jiayu@gamil.com's Avatar
Drives: 2017_86 2016_frs 2007_335i
RPF1 17x8+45 re71 245 40 17 overall review
Life is filled with all the things u don't know
Guys buy the set of OEM sensor
RPF1 came with the red valve stems
If u wanna keep u OEM set for winter & still wanna use those red valve stems
Buy it before u go to the tire shop
#rpf1 #gt86 #frs #brz #re71r #newwheels
After sooo many things happen
Here is my over review
1. Make sure r u going to update a big brake kit
2. Choose the wheel & tire size that fit ur car and
also fit the brake kit u will update
3. Check the wheel & tire size with the online calculator
To make sure those will fit u wheel base
Also u can’t check Own review , there is one on our forum
4. Check u OEM wheels is there a TPMS, if so either u can use the OEM
Sensor which usually a one peice deigns with the valv stem on it
Or buy a after market sensor for ur car model
Note: some of wheels come with very nice stem
Buy may not fit any sensor u either use it with tire
Pressure light on or just use the OEM sensor
5. Check out ur OEM lug nut style, there 3 popular styles
And see is the OEM lug nut has the same style with ur new wheels
If not buy the new lug nut that fit ur new wheels
6. Center cap for the wheel , the OEM one may not fit!
7. U need hub ring to install the rim buy it before u install
That my over review for change a after market wheels
jayliu.jiayu@gamil.com is offline   Reply With Quote
Old 05-09-2018, 09:46 PM   #2
cjd
cjd's Avatar
Drives: 2017 BRZ
5 sets of wheels for this car... Never got TPMS sensors for any of them. On 2 I'm averaging a pressure check every mile driven...
I didn't realize you could use aftermarket valve stems on any TPMS sensors though.
Old 05-10-2018, 01:53 AM   #3
so u drove with the tire pressure light on?
i just don't want those error light, and the sensors was need by law
people said the oem tpms will fit.
i will let people need once i have them
Old 05-10-2018, 04:31 PM   #4
Quick update the red stem does not fit any sensors, u either use them with tire light on or just go for the OEM sensors!
Old 05-14-2018, 02:43 AM   #5
lug nut on the way !!!! will upload after i got it
hope i will help some one
oem suspension with rpf1 17x8 +45 245 40 17 all four
Old 05-21-2018, 06:59 AM   #6
Nice photo from car meet
Old 09-12-2018, 03:20 AM   #7
lug nut on and center cap
Old 09-12-2018, 10:42 AM   #8
Soloside
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
You can play hide and go seek along the wheel gaps.
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside
Soloside is offline   Reply With Quote
Old 09-13-2018, 07:11 AM   #9
thx for the advances, for now i am okay with the stock suspension set up
my next move going to be the racing seat.
i am flying around on my seat at track day
one day will do the suspension when i feel i need
Old 09-13-2018, 08:17 AM   #10
churchx
churchx's Avatar
Drives: 2014 GT86
jayliiu.jiayu: problem with racing seats is that for safety they should be used with full set of accompanying extras, multi-point harness, safety cage .. and helmet to not crush skull on cage tubes . Also that multipoint harness has some specific requirements how to fix/mount it, to not submarine in crash. But eg. wearing helmet when driving on public roads is not legal here (reduces visibility), same about altering stock safety systems functioning (eg. stock airbags).
So i'd consult first what's legal, what's not in country you live in first, if you wish to dual use car.
If that works for you, you can go "minimum" route, using stock seats/belt, but getting some clip or CG-lock for more secure fixing in seat lower body. To tension shoulder part, one can use trick of moving back seat, then quickly pulling safety belt for it to "lock", then moving seat back to tension it.
Old 09-16-2018, 12:09 AM   #11
thx for the head up
i am in canada so i should be fine with racing seat
will keep the stock harness for daily
for the harness bar still in considering
http://www.ft86speedfactory.com/agen...l#.W53W4PlReCo
cause there is a hock behind the rear seat. but the angle is not too good tho
for the harness i am going to do a 6 points for sure
will keep all senors for sure
Thoughts on turning down rims to change offset? Triumphrider Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-22-2015 12:12 PM
How to change the start up screen on 2014 head unit? Choob Electronics | Audio | NAV | Infotainment 9 08-03-2014 06:24 PM
WTB head/rims/tails..more Yosty Want-To-Buy Requests 5 08-02-2014 04:33 AM
Android Head Unit - LED Colour Change - T7019A (and TUN21A) Tech DIY (Do-It-Yourself) Guides 57 10-10-2013 11:10 PM
Android Head Unit - LED Colour Change - T7019A (and TUN21A) Tech Electronics | Audio | NAV | Infotainment 2 07-18-2013 06:17 PM
