Old 03-20-2015, 11:59 PM   #1
Triumphrider
Triumphrider's Avatar
Drives: 2013 Scion FRS in white out
Thoughts on turning down rims to change offset?
Yes or No? I have not done this however I have thought about it, just talking maybe 3mm to pull the front wheels in a touch? Whats everyone's thoughts on this?
Triumphrider is offline   Reply With Quote
Old 03-22-2015, 12:12 PM   #2
Redstar
Destroyer of Tires
Redstar's Avatar
Drives: 2001 Honda Accord, 1997 Lexus ES300
It will depend on the wheel. If you machine too much metal off, the lug seat will be too shallow so it will require a fill and drill. Your best bet is to contact someone like Wheelflip to see if it's safe on your set of wheels, and how much they think you can change the offset.
Redstar is offline   Reply With Quote
The Following User Says Thank You to Redstar For This Useful Post:
Triumphrider (03-22-2015)
What offset will not interfere with turning? FRSGeek Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-08-2013 12:20 PM
FS: 17x8 35 offset Drag rims with tires Ryeong86 Wheels and Tires 4 05-31-2013 08:55 PM
oil change at 1000 miles! thoughts? ric342 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 23 05-23-2013 10:37 AM
Wheel offset change handling? keen as Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 04-23-2013 10:50 PM
Which Five Axis S5:F Rims? Which Offset? sharkasport AUSTRALIA 8 12-11-2012 12:21 AM
