RPF1 17x8+45 re71 245 40 17 overall review
2 Attachment(s)
Life is filled with all the things u don't know
Guys buy the set of OEM sensor RPF1 came with the red valve stems If u wanna keep u OEM set for winter & still wanna use those red valve stems Buy it before u go to the tire shop #rpf1 #gt86 #frs #brz #re71r #newwheels:bow: After sooo many things happen Here is my over review 1. Make sure r u going to update a big brake kit 2. Choose the wheel & tire size that fit ur car and also fit the brake kit u will update 3. Check the wheel & tire size with the online calculator To make sure those will fit u wheel base Also u can’t check Own review , there is one on our forum 4. Check u OEM wheels is there a TPMS, if so either u can use the OEM Sensor which usually a one peice deigns with the valv stem on it Or buy a after market sensor for ur car model Note: some of wheels come with very nice stem Buy may not fit any sensor u either use it with tire Pressure light on or just use the OEM sensor 5. Check out ur OEM lug nut style, there 3 popular styles And see is the OEM lug nut has the same style with ur new wheels If not buy the new lug nut that fit ur new wheels 6. Center cap for the wheel , the OEM one may not fit! 7. U need hub ring to install the rim buy it before u install That my over review for change a after market wheels |
5 sets of wheels for this car... Never got TPMS sensors for any of them. On 2 I'm averaging a pressure check every mile driven...
I didn't realize you could use aftermarket valve stems on any TPMS sensors though. |
i just don't want those error light, and the sensors was need by law people said the oem tpms will fit. i will let people need once i have them |
Quick update the red stem does not fit any sensors, u either use them with tire light on or just go for the OEM sensors! :(
2 Attachment(s)
lug nut on the way !!!! will upload after i got it
hope i will help some one oem suspension with rpf1 17x8 +45 245 40 17 all four |
Nice photo from car meet
2 Attachment(s)
lug nut on and center cap
You can play hide and go seek along the wheel gaps.
thx for the advances, for now i am okay with the stock suspension set up my next move going to be the racing seat. i am flying around on my seat at track day one day will do the suspension when i feel i need :thumbup: |
jayliiu.jiayu: problem with racing seats is that for safety they should be used with full set of accompanying extras, multi-point harness, safety cage .. and helmet to not crush skull on cage tubes :). Also that multipoint harness has some specific requirements how to fix/mount it, to not submarine in crash. But eg. wearing helmet when driving on public roads is not legal here (reduces visibility), same about altering stock safety systems functioning (eg. stock airbags).
So i'd consult first what's legal, what's not in country you live in first, if you wish to dual use car. If that works for you, you can go "minimum" route, using stock seats/belt, but getting some clip or CG-lock for more secure fixing in seat lower body. To tension shoulder part, one can use trick of moving back seat, then quickly pulling safety belt for it to "lock", then moving seat back to tension it. |
thx for the head up i am in canada so i should be fine with racing seat will keep the stock harness for daily for the harness bar still in considering http://www.ft86speedfactory.com/agen...l#.W53W4PlReCo cause there is a hock behind the rear seat. but the angle is not too good tho for the harness i am going to do a 6 points for sure will keep all senors for sure |
| All times are GMT -4. The time now is 01:14 PM. |
User Alert System provided by
