Old 03-23-2018, 07:57 AM   #85
TheArtOfFoo
Drives: 2017 BRZ Premium (BREMBOOOOOS)
With the Brembos they will clear but way too close for my comfort.less that a mm
TheArtOfFoo is offline
Old 03-25-2018, 11:34 PM   #86
azndave1
azndave1's Avatar
Drives: none
So it says WedsSports TC105N 17x8+42 will fit, but will 18x8.5 +43 fit as well?
azndave1 is offline
Old 03-26-2018, 01:31 AM   #87
gpvecchi
gpvecchi's Avatar
I’m looking for a 10 spokes 8x18 that fits Brembos. Any suggestions, please?
gpvecchi is offline
Old 04-01-2018, 05:51 AM   #88
yohuan
Drives: 2017 BRZ :)
Originally Posted by NeedsBoostt View Post
Enkei Raijin 18x9.5 +45 square will not clear front brakes; needs 10mm slip on at minimum cant do 15mm bolt-on due to no stud pockets so... I recommend you don't lol
Tested first hand with Neal @ The Racers Line
I have seen one of those run no spacers in a picture; not sure which spec. If i find it I will keep you posted
Yeah i think it might be the 18x9.5 but not many run RS05rr's in 18x9 so its hard to find any info on it.
yohuan is offline
Old 04-10-2018, 06:29 PM   #89
Barefootdan
Barefootdan's Avatar
Drives: 2017 BRZ
Is this list up to date for 17x9?
Barefootdan is offline
Old 04-19-2018, 01:26 PM   #90
Daedex
That One Guy
Daedex's Avatar
Drives: White 2017 BRZ
I, too, would be curious if anyone has RS05RR 18x9's on the PP and if they clear.
Man, deciding on wheels without using spacers it tough as hell for me. :\
"I am not bound to win, but I am bound to be true."
Daedex is offline
Old 04-19-2018, 04:20 PM   #91
gpvecchi
gpvecchi's Avatar
I made my mind on XXR 527 18x8: will they fit? Thanks!
gpvecchi is offline
Old 04-19-2018, 05:56 PM   #92
bmxr
bmxr's Avatar
Drives: 2017 BRZ PP WR Blue
Originally Posted by FT-86 SpeedFactory View Post
[CENTER]Gram Lights 57CR - 17x9+38
Gram Lights 57DR - 17x9+38
WedsSports SA-10R - 18x9.5+40
Volk CE28N - 18x9.5+38
Apex ARC-8 - 17x9+42
Ambit RE02 - 17x9+35
949 Racing 6UL - 17x9+40
Enkei RPF1 - 17x8+45
Have you guys tested fitment for any of the other Enkei 17x9 wheels aside from the RPF1? How about the TS6 and Kojin?
What do you think about those Apex wheels, and do you have them in stock?
bmxr is offline
Old 04-24-2018, 06:48 PM   #93
perryair
junior mafia
Drives: ‘20 sti limited
Third is wheel fitments. These will continued to be tested, but we do have a round of wheels that we have fitted to ensure clearance on these calipers. Only photos of the 17" 57CR, but tested wheels that clear are listed below.
would i be right in assuming that rpf1 17x8 +35 would fit because the spoke shape is the same as +45, just pushed out 10mm?
20 sti limited | 17 bmw m240i | 16 scion im |15 brz limited {prokit, 17x8 +35 rpf1, bfg comp 2 a/s, stg 2, jdl uel, voodoo knob} | 05 honda civic | 06 scion tc | 95 mustang gt | 89 chevy s-10 cameo
perryair is offline
Old 04-26-2018, 01:17 AM   #94
yohuan
Drives: 2017 BRZ :)
Yeah i know right? Thinking if i should take the dive, get RS05RR's in 18x9.0 and see if they fit or not. I could always try other brake kits if PP Brembos don't fit but i'm hoping it does.
yohuan is offline
The Following User Says Thank You to yohuan For This Useful Post:
Daedex (06-25-2018)
Old 05-24-2018, 03:14 AM   #95
spicyricecake
spicyricecake's Avatar
Drives: 2017 CWP BRZ Performance Package
does anyone know if the 18x10 +40 ze40s clear the performance package brembos?
spicyricecake is offline
Old 05-29-2018, 04:01 AM   #96
Turbo86
Drives: '13 Whiteout FR-S
So are the performance package calipers the exact same as the STI calipers? If it takes the same size pads and rotors, and looks the same from the outside, is it pretty much the same thing?
Turbo86 is offline
Old 05-29-2018, 08:36 AM   #97
cjd
cjd's Avatar
Drives: 2017 BRZ
Are the pistons exactly the same size? That's the detail that matters most, along with rotor diameter.
cjd is offline
Old 06-25-2018, 12:22 PM   #98
Daedex
That One Guy
Daedex's Avatar
if you do, keep us updated on the outcome either way.
Daedex is offline
2017 BRZ Performance Package Brembo Brakes Part Numbers Veloist Suspension | Chassis | Brakes -- Sponsored by 949 Racing 146 04-27-2023 09:36 AM
Real STI BREMBO package upgrade - DIY Trap63 DIY (Do-It-Yourself) Guides 40 06-15-2022 09:25 PM
Will The Brembo BBK of the Performance Package BRZ fit into the wheels of Series Blue DaJo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 09-25-2018 05:12 PM
To get the Performance Package or Not? Thread Zaku BRZ First-Gen (2012+) — General Topics 141 12-06-2016 10:04 PM
Someone tested the Performance Package... small but SOME info at least ~el~jefe~ BRZ First-Gen (2012+) — General Topics 13 11-29-2016 04:21 PM
