Old 09-20-2017, 05:44 PM   #1
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
FT86SF's Performance Package Brembo Info Thread
We've been getting a lot of inquiries lately pertaining to the Performance Package brakes on MY17 cars. Guys looking for new rotors, Pad compounds, and wheel clearance mostly. Well, we finally found some time and brought in a caliper in-house to get tested on our own 86. So, we wanted to share the info we found today and hopefully build on that a bit with more info or info that everyone else is finding as well.
First thing we found out is standard STI pad compounds drop right into the caliper. The backing plate and shape are identical. Along with thickness, these slide in perfectly against the 326x30 DBA rotor we tested.
Second is we do have some aftermarket rotor options from DBA, as these are dual drilled and for STI application. The 5000 series rotor we tested is 326x30 and dual drilled for 5x100 and 5x114 application, making these a nice upgrade for anyone looking for replacement rotors on a PP equipped vehicle. That also means DBA's other offerings that are dual pattern drilled will work as well. The T3 4000 series and T2 Street series will also be direct replacements as their STI applications are also dual drilled, signified by the "-10" on the end of their PN.
Third is wheel fitments. These will continued to be tested, but we do have a round of wheels that we have fitted to ensure clearance on these calipers. Only photos of the 17" 57CR, but tested wheels that clear are listed below.
Gram Lights 57CR - 17x9+38
Gram Lights 57DR - 17x9+38
WedsSports TC105N 17x8+42
WedsSports SA-10R - 18x9.5+40
Volk CE28N - 18x9.5+38
Apex ARC-8 - 17x9+42
Ambit RE02 - 17x9+35
949 Racing 6UL - 17x9+40
Enkei RPF1 - 17x8+45
FT-86 SpeedFactory is offline
The Following 12 Users Say Thank You to FT-86 SpeedFactory For This Useful Post:
Alltezza (08-06-2018), jmark (09-20-2017), jubella2 (09-21-2017), Lonewolf (09-23-2017), mrderp (10-04-2017), SuperTom (09-15-2025), tacos (09-20-2017), Thedishdoc (05-24-2019), TofuJoe (09-21-2017), tony-brz (01-07-2018), Tristor (02-28-2018), Viking42 (10-13-2017), weederr33 (09-23-2017)
Old 09-20-2017, 05:48 PM   #2
tacos
Drives: 09 impreza, 01 crv, 17 brz PP
Thank you!!!
tacos is offline
Old 09-20-2017, 06:07 PM   #3
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Wow that is some extremely tight clearance, no better than the stock PP wheels, imo.
Originally Posted by humfrz
I'm old and lazy
Clipdat is offline
Hicklinc (02-04-2018)
Old 09-20-2017, 06:14 PM   #4
FT-86 SpeedFactory
Photo angle makes it look closer that it is, honestly. We are looking at about 2.5mm of clearance at the closest point of the wheel to the caliper. Which is about the minimum you want for thermal expansion.
All wheels tested have this or more clearance.
The Following 3 Users Say Thank You to FT-86 SpeedFactory For This Useful Post:
Clipdat (09-20-2017), ryann.mendoza (09-23-2017), Tristor (02-28-2018)
Old 09-20-2017, 06:38 PM   #5
churchx
churchx's Avatar
Drives: 2014 GT86
Would be better to see some brake template, so that wheel fitment can be DIY for whatever wheels one has. Also, are there any compatible blank rotor choices too? Imho blank, or at least just slotted might be a bit more reliable.
As for brake kit itself, what do you think of maybe assembling all the changed parts in kit and selling it for ones, that may want to retrofit it on older twins?
P.S.
Regarding fitment, imho worth checking clearance with older stock wheels, as most common ones, and eg. tell, how thick spacers they may need to fit. Pitty, that given limited clearance on 17", most probably fitment with different 16" wheels will be impossible feat.
churchx is offline
Old 09-21-2017, 04:18 AM   #6
SquireCVP
Drives: MY17 BRZ Premium Sports Pack
Great info been trying to work out brake options. BTW Enkei RS05RRS 18x8.5 +42 do not clear.
SquireCVP is offline
The Following User Says Thank You to SquireCVP For This Useful Post:
Caspeed (02-04-2018)
Old 09-21-2017, 07:01 AM   #7
jmark
Drives: '97 NSX-T, '18 Type R
Pics of the Apex ARC8 wheels on the PP BRZ purchased from FT-86.
http://www.ft86club.com/forums/showp...3&postcount=42
jmark is offline
Old 09-21-2017, 08:16 AM   #8
airindia33
airindia33's Avatar
Drives: 2020 BRZ PP
What about ss brake lines?
airindia33 is offline
Old 09-21-2017, 09:20 AM   #9
rns294
Drives: 13 BRZ
Unrelated but what alignment are you running with that wheel and suspension setup? I want to grab those wheels from ft86speedfactory but I thought they would rub on stock struts.
rns294 is offline
Old 09-21-2017, 09:27 AM   #10
jmark
It is my son's car but I can speak to this question. He was able to get -.8 front camber with the 245/40R17 Pirelli P Zero AS + tires, whiteline camber bolts & RCE Yellow springs. Anymore camber and it could rub the strut tower. I think it is largerly depend on the tire brand as well. For example the Michelin Sport AS 3+ is wider than the Pirelli and may have issues. If you wanted to be safe you can go with a 235/40R17 tire or use a spacer up front.
jmark is offline
Old 09-21-2017, 12:30 PM   #11
jamal
jamal's Avatar
Drives: Legacy GT
Did you happen to measure the piston sizes?
jamal is offline
The Following 2 Users Say Thank You to jamal For This Useful Post:
JazzleSAURUS (11-09-2017), Racecomp Engineering (09-21-2017)
Old 09-21-2017, 01:19 PM   #12
Jad_BRZ
Drives: 2017 Subaru BRZ (PP)
For at least the front rotors, I believe that early 2000's rotors (like the 2004 STI with 5x100 pattern) with 326x30 dimensions should fit. The blanks are pretty cheap, so I may just pick one up to check soon.
I think this person has already done it though:
Originally Posted by BRZ17 View Post
Early 2000s front rotors will work as long as they are 326X30mm. The rear however won't work. Park brake shoes are smaller I believe. I'm buying a set of aftermarket 2017 WRX STi rotors and redrilling the bolt pattern to 5X100. The BRZ and WRX STi use the same park brake shoes.
I was hoping this thread would have more information for rotor size, especially the rears. Does anyone know any rotors that'll fit the rear?
I'd just like another blank rotor option other than OEM or a drilled/slotted rotor.
Jad_BRZ is offline
Old 09-21-2017, 01:49 PM   #13
jamal
jamal's Avatar
Drives: Legacy GT
If the front rotors are the same as the sti I would wager the rears are too. 316x20, It needs to be an 08-17 sti rotor drilled to 5x100 (kns brakes I know has them), the earlier ones like from 04 do not work. And not because of the parking brake, they are all 190mm, it's the offset from the rotor to the hat that is different between older (strut rear suspension) and newer cars (multi-link).
jamal is offline
Old 09-21-2017, 05:38 PM   #14
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
So ft86speedfactory, where were you able to get hands on the PP calipers? I would be greatly interested if we can convert nonPP cars to these
Instagram: trevor.parque
MisterSheep is offline
chaoskaze (01-03-2018)
2017 BRZ Performance Package Brembo Brakes Part Numbers Veloist Suspension | Chassis | Brakes -- Sponsored by 949 Racing 146 04-27-2023 09:36 AM
Real STI BREMBO package upgrade - DIY Trap63 DIY (Do-It-Yourself) Guides 40 06-15-2022 09:25 PM
Will The Brembo BBK of the Performance Package BRZ fit into the wheels of Series Blue DaJo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 09-25-2018 05:12 PM
To get the Performance Package or Not? Thread Zaku BRZ First-Gen (2012+) — General Topics 141 12-06-2016 10:04 PM
Someone tested the Performance Package... small but SOME info at least ~el~jefe~ BRZ First-Gen (2012+) — General Topics 13 11-29-2016 04:21 PM
