Old 04-18-2018, 12:58 AM   #1
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
Which ac delete kit?
I'm looking to do the ac delete for the brz, I could only find 2 kits. The oem and raceseng one. I want to hear input from both please. The oem nearly cost $200 and the raceseng nearly cost $400.
Dr. BRZ is offline   Reply With Quote
Old 04-18-2018, 04:38 AM   #2
22R
22R
22R's Avatar
Drives: 2012 Camry SE 2017 Toyota 86
There is a free button on the panel that will turn it off..... Sorry can't resist as I live in South Louisiana where the heat and humidity can vaporize ya ! Best of luck with your project.
22R
22R is offline   Reply With Quote
The Following User Says Thank You to 22R For This Useful Post:
Kestrel (04-19-2018)
Old 04-18-2018, 06:38 AM   #3
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
It is not about closing the A/C with a button, it is more about weight reduction and better cooling. Porsche was adding also lately the option to remove the A/C in the 911 R car and more lately in the 911 Carrera T car.
Personally, I have the factory delete option. The A/C compressor will save most of the weight (~14 lbs). If you want to do it correctly, you should also remove the A/C radiator. You'll have better airflow in the coolant radiator and it'll be easier to keep the temperatures lower. Especially if you are using a lower temperature thermostat
The Following 2 Users Say Thank You to nikitopo For This Useful Post:
a_b.95 (07-12-2018), weederr33 (04-18-2018)
Old 04-18-2018, 09:47 AM   #4
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
OEM. There is not +$200 worth of benefit from the Raceseng part. I do like their parts, but this is a case of superfluous spending if you go with it.
If you're in a race class where you're hunting ounces at any cost, by all means grab the Raceseng part. Otherwise, that $200 is much better spent elsewhere. Like track time, tires, brake pads, fuel...
JazzleSAURUS is offline   Reply With Quote
Old 04-18-2018, 12:18 PM   #5
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
If only I didn't live in Texas, deleting the AC would be a pretty quick weight reduction mod.
MS, CSCS, TSAC-F, CPT
The Following 2 Users Say Thank You to weederr33 For This Useful Post:
nikitopo (04-18-2018), Tristor (04-25-2018)
Old 04-18-2018, 03:59 PM   #6
Jonsey
Jonsey's Avatar
I went with the Raceseng kit based on concerns GSpeed had with the factory kit. They may often take the overkill approach, but that's also because they tend to focus on big build racecars and not small scale street car stuff.
http://www.ft86club.com/forums/showp...&postcount=318
"It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt." Mark Twain
Jonsey is offline   Reply With Quote
The Following User Says Thank You to Jonsey For This Useful Post:
a_b.95 (07-12-2018)
Old 04-24-2018, 04:54 PM   #7
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Just from looks the Raceng would appear to have a lighter design and is made out of aluminum. Is it $200 lighter that is for you to decide. I will be following this as I am strongly considering deleted my AC for weight loss.
But first I got to repair AC in the Vette as I will need one car with good AC when its hot as balls
SuperTom is offline   Reply With Quote
Old 04-24-2018, 05:23 PM   #8
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
I see all kinds of problems with that test.
A: Outside runout means squat, he should have measured the inner grooves.
Even then....
B: More telling would be to see how much play is in the bearing itself. Wiggle the pulley left and right like checking for a bad wheel bearing.
And finally...
C: A comparison to say the stock pulley on the AC compressor would actually tell you how "crap" the delete is.
Old 04-25-2018, 04:59 AM   #9
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I confirm that there is a small play on the factory A/C delete pulley. Such kits are usually installed with other track focused changes, like aftermarket lightweight pulley kits. My assumption is that they introduced this play intentionally to support other changes. The play is quite evident to be a design issue and this part was not really intented for small scale street car stuff or daily drivers. Subaru is also building racecars and they have a huge experience to not have a blown motor in the duration of a race.
The Following User Says Thank You to nikitopo For This Useful Post:
x808drifter (04-25-2018)
Old 04-25-2018, 08:40 AM   #10
Timmy_Jones
Spun
Drives: 23' Supra
With a delete kit, do you run a smaller belt or do you retain a pulley in the spot it used to exist?
Timmy_Jones is offline   Reply With Quote
Old 04-25-2018, 09:10 AM   #11
Icecreamtruk
Drives: Track preped NA FRS
Same belt, the delete kit pulley is the same size. It is also a really easy installation, contrary to what it may look like at first, even removing the condenser was easy, 1hour in your driveway with a spanner and you are done.
Icecreamtruk is offline   Reply With Quote
The Following User Says Thank You to Icecreamtruk For This Useful Post:
Tcoat (04-25-2018)
Old 04-25-2018, 10:02 AM   #12
churchx
churchx's Avatar
Drives: 2014 GT86
Removal might cost quite a bit if car is pre-late-2014 and at some point owner will decide to reinstall. As early cars due EU regulations back then expensive gas (under bonnet, sticker 1234yf), at least now for me refill is 400eur. Worth keep in mind if at some point one wants to sell it off and put all stock parts back.
Old 04-25-2018, 12:32 PM   #13
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Same belt for the factory A/C delete.
Old 04-25-2018, 12:35 PM   #14
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I stored the condenser and compressor, but I agree that it would be expensive to put the parts back.
Custom Muffler Delete vs Berk Dual Tip Muffler Delete eric2523 Engine, Exhaust, Transmission 7 07-27-2015 09:40 AM
WTB: Berk Track Pipe Muffler Delete or Nameless Muffler Delete Hollwood_lives Canada Classifieds 5 04-12-2015 07:02 PM
Delete or not delete sound generator? pepe Engine, Exhaust, Transmission 11 11-14-2014 05:38 AM
WTB: Berks dual tip muffler delete and cat delete pipe Black86 Want-To-Buy Requests 0 09-27-2013 09:31 PM
WTB Berk Dual Exit Muffler Delete or Works AB Delete Admired Want-To-Buy Requests 2 09-10-2013 04:20 PM
